Prius plug in generation 4 of prius but 2 of plug in. Do you feel that the AC in the car takes long
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Tony1988, Jun 14, 2025.
  1. Tony1988
    Tony1988 Junior Member
    27
    Sweden
    2020 Prius PHV
    How do you feel about the air heat pump in the cars? Effective and fast? I feel mine is slow and poor compared to other cars I have owned before. Now that the sun has been out it is about 40 degrees Celsius in my cabin and it will probably take at least 100 kilometers of driving before I have a comfortable temperature, maybe around +20 degrees in my car.
    51,040
    i don't own one, but that doesn't sound right. i have not read many complaints about the heat pump cooling efficiency
  3. Mendel Leisk
    40,495
    Have dealership do an evacuation and recharge of the system, test for leaks?
    regarding describing your vehicle’s gen as 4 versus 2, I think the latter is a misstep, inherently confusing. Was this started by Toyota? I would call it gen 4 with plug-in.
  4. bisco
    51,040
    i think they called it prime to differentiate. now they have reverted back to plug in mid stream gen 5.
    someone's nephew must be running toyotas badging department
  5. MikeDee
    MikeDee Senior Member
    1,572
    596
    San Francisco Bay Area
    This. The a/c in my [emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji6]][emoji[emoji6]]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]]]] Prime works great. It's even too cold at times.
  6. Mendel Leisk
    40,495
    Well that clears it up. :)
