Red Square Warning Light
Discussion in 'Gen 5 Prius Main Forum' started by daisy555, Jun 21, 2025 at 6:25 PM.
  1. daisy555
    daisy555 Senior Member
    1,651
    692
    CT
    This is the second time I’ve had a large red square warning light pop up on my dash screen. It takes up almost the entire left side of the screen. Happened a while ago and I thought it was just a glitch but it just happened again. It says something but it turns off too quickly for me to read it.
    Of course I took my manual out of the car to read about the AC and can’t look it up. Just curious if anyone is familiar with this. Googling was NOT a good idea. : } It just flashes on and then disappears. Thanks
  2. Gokhan
    Gokhan Senior Member
    5,658
    2,230
    Paramount CA
    Probably automatic emergency braking (AEB) or automatic parking braking.
  3. daisy555
    1,651
    692
    CT
    While I’m driving? I forgot to mention that detail.
  4. Gokhan
    5,658
    2,230
    Paramount CA
    Yes, that red “BRAKE!!” warning would only come up while driving.
  5. daisy555
    1,651
    692
    CT
    Well there are no cars in front of me when it happens and no auto breaking occurring.
  6. Gokhan
    5,658
    2,230
    Paramount CA
    It can still get confused or detect something you didn’t see.
    daisy555 likes this.
  7. Trollbait
    12,321
    Or detect something that isn't there.
  8. schja01
    schja01 Senior Member
    1,816
    1,205
    Chicagoland
    2024 Prius
    Limited AWD-e
    Doesn’t even have to be in front of you. Thinking garage walls, etc.
  9. daisy555
    1,651
    692
    CT
    This happened on a road I travel often. No one in front of me and no one coming towards me. It seems crazy that it would flash such a large warning so quickly that it can’t be read.
  10. Trollbait
    12,321
    slight curve with a car in a turn lane is where the Subaru has falsely alerted to something in front. The warnings and exceptions in the Toyota manual for these systems is probably longer than the about part.
  11. daisy555
    1,651
    692
    CT
    Thanks for correcting my spelling. I’m often voice typing and don’t catch every mistake. If that warning is for braking or avoiding a collision the sensors are quite confused.
    Gokhan likes this.
  12. Gokhan
    5,658
    2,230
    Paramount CA
    Maybe, maybe not. There are already threads about this such as this:
    Gen5 Prime suffers from phantom brake syndrome. | PriusChat
  13. otatrant
    otatrant Active Member
    183
    121
    San Francisco
    2023 Prius Prime
    XSE Premium
    My 'sub-battery system malfunction visit your dealer message similarly popped up and disappeared'. I keep my phone mounted on the dash so was able to record a video. You could keep your phone camera app open and ready so if happens again you can grab a photo.
    Gokhan likes this.
  14. Gokhan
    5,658
    2,230
    Paramount CA
    That sounds like a temporary voltage glitch in the 12-V system, with the DC–DC converter voltage dropping too much due to a high-current demand such as when using the electric power steering all the way to the stops etc. Usually, the system will raise the voltage to 14.3 V to prevent that from happening during high electric loads. You can ignore it unless it becomes a permanent message.
    otatrant likes this.
  15. otatrant
    183
    121
    San Francisco
    2023 Prius Prime
    XSE Premium
    I did ignore first happened in April. Both times it happened while using dynamic cruise control which abruptly turned off. First time soon after it happened I pulled over turned the car off and back on again and the message went away. When it happened another time in May the dealer ended up calling me right after it happened and set up an appointment. They replaced the INTEGRATION CONTROL SUPPLY under warranty.
