Nutz About Bolts Prius Maintenance Videos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Feb 17, 2016.
  1. johnHRP
    johnHRP Active Member
    645
    189
    KA, DE
    Excel
    @NutzAboutBolts will you also change the piston and rings? I don't remember if yours burn oil or not.
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,734
    1,771
    Bay Area
    Might not… it’s my working car so I might just have the head resurface at a machine shop if it’s out of specs. Hopefully I caught the misfire in time before it caused a bent rod. So far there isn’t coolant in the oil because it didn’t look milky. So far I’m not half way there yet. Will resume tomorrow.
    johnHRP likes this.
  3. johnHRP
    645
    189
    KA, DE
    Excel
    Thanks for the dedication to our PRius community. The head is not know to wrap in Prius. The new redesign head gasket should has less problem. Car Care Nut has video on CT200h, He removed the inverter to give him more room.
    Mendel Leisk and NutzAboutBolts like this.
  4. NutzAboutBolts
    1,734
    1,771
    Bay Area
    that’s good to know, I’ve been reading up on some people here sanding the head down with 1000 and 1500 grit wet sand paper. I’m wondering if I can get away with just cleaning the head and block with a green pad to get rid of the old gasket and carbon and lay a new headgasket on… but I’ve also read how sensitive the head is if the gap is out of spec that it’ll cause issues in the future again… :sick:
  5. ASRDogman
    ASRDogman Senior Member
    7,838
    3,992
    Since you caught it early, and will be changing it soon, it's doubtful the head if warped.
    Clean it and check it with a straight edge. Most importantly between cylinders....
    NutzAboutBolts likes this.
  6. NutzAboutBolts
    1,734
    1,771
    Bay Area
    yep, I got a straight edge and a feeler gauge :D
    Maximum thickness seems a lot, so we’ll see where my feeler gauge goes to.
  7. ASRDogman
    7,838
    3,992
    I did mine at 301,000. It knocked twice, I wasn't really sure if it was loosing coolant.
    Until a day or two later. And it was very minor. But I knew.
    Once I cleaned the old gasket off, I couldn't even see light between cylinders.
    I just turned 371,000 miles last week.... Coolant was still at the same mark when I changed it
    at 350,000. And it's still the same at the same place since replacement.
    johnHRP and NutzAboutBolts like this.
  8. NutzAboutBolts
    1,734
    1,771
    Bay Area
    mine misfire the first time it knock and I resented the cel, then I drove it another 400 miles before the knocking got worst with loss of coolant and then I decommissioned it lol. Hopefully it’s not too late
    did you just clean your head? You didn’t wet sand it?
    #488 NutzAboutBolts, Jun 22, 2025
  9. ASRDogman
    7,838
    3,992
    That's about what I did.... Highway miles, mostly.
    I used a razorblade to clean it, then superfine steel wool.
    I had one valve, exhaust I believe, on the #4 cylinder just seeping wd40 after 15-20 minutes.
    I decided to re-seat all the valves, since I was replacing the valve guide seals anyways.
    And of course I cleaned off the all the carbon from the valve chamber and intake and exhaust ports.
    I also cleaned off the piston heads. Intake manifold, cooler, egr valve.....
    I had forgotten to connect the connector on the manifold, so I got an error code when I started it.
    It didn't run so smooth. I only ran it for few seconds. But after I connected it, it ran smooth after
    several seconds....
  10. NutzAboutBolts
    1,734
    1,771
    Bay Area
    what compression tool did you use to compress the valve stem springs? Did you replace the springs too or just the stem oil seal?
    My head gasket kit came with the stem oil seals too. Looking at the manual the exhaust and intake has different color seals specific for it.
  11. johnHRP
    645
    189
    KA, DE
    Excel
    Usually we only change the stem seals and nothing else are replaced in the head. Gasket Master recommend Felpro for the head gasket, he claimed it has thicker lips on the edge around the cylinder.
  12. NutzAboutBolts
    1,734
    1,771
    Bay Area
    any valve stem tool you recommend?
    I bought my kit from the dealership, costed 302$ and came with a bunch of gaskets, including the stem seals
  13. ASRDogman
    7,838
    3,992
    All my valve seals were the same color, if I remember correctly. Did you get the FULL kit? It will come with the crank shaft
    seal also, and a few others, I forget what they were. I had to buy them separately, which cost more.
    You will need a SMALLER valve spring compressor. Mine was for larger valves. I had a washer that
    I was able to use to compress the springs to get the keepers out. The springs are small.
    Be careful, my compressor slipped and one keeper shot off. After removing everything on my porch,
    Then putting things back, I found it on my metal ladder!
    NutzAboutBolts and johnHRP like this.
  14. NutzAboutBolts
    1,734
    1,771
    Bay Area
    I just watched a video on how they lap the valves and cleaned it up… I don’t think I got enough time for all of that, I think I’m just gonna send it out and pay the 150$ for them to change the seals, lap the valves and maybe resurface the head if it needs to be. I need to get this car up and running soon :(
    johnHRP likes this.
  15. ASRDogman
    7,838
    3,992
    $150 is not bad for that work!
  16. rjparker
    10,563
    6,626
    Smart move
  17. NutzAboutBolts
    1,734
    1,771
    Bay Area
    Almost there, EGR was a PITA as always :ROFLMAO:.
    intake manifold looks dirty and gummy by the pvc area.
    still got a bunch of bolts and connectors to remove before removing the valve covers, and so on.
    johnHRP likes this.
  18. johnHRP
    645
    189
    KA, DE
    Excel
    Yes, we do and sell what we are good at and let others do what we cannot do. But $150 is a good deal.
  19. NutzAboutBolts
    1,734
    1,771
    Bay Area
    yeah, I just asked to get it resurface and check for leaks. Hopefully it’s not more if I asked for other services :ROFLMAO:
  20. rjparker
    10,563
    6,626
    Don't have it resurfaced if it does not need it especially if it never overheated. More than a few have ended up with timing errors that can't be corrected by removing too much surface.
