Nutz About Bolts Prius Maintenance Videos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Feb 17, 2016.
  1. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,524
    1,622
    Bay Area
    yeah, I think they know how to resurface if it doesn’t need it. I’ll probably ask them to clean the mating surface so it’ll bite the headgasket nicely so it doesn’t cause a leak. I’ll let you know how it’ll go in a couple of days.
  2. ASRDogman
    ASRDogman Senior Member
    7,145
    3,735
    You do NOT have to disconnect that AC lines, just move the compressor out of the way.
    After disconnecting the power cable.
    johnHRP likes this.
  3. NutzAboutBolts
    1,524
    1,622
    Bay Area
    which AC line?
    are you referring to the thermostat housing?
    #503 NutzAboutBolts, Jun 23, 2025 at 11:17 PM
  4. rjparker
    9,531
    5,834
    He is talking about the compressor and its refrigerant hoses.
  5. NutzAboutBolts
    1,524
    1,622
    Bay Area
    yeah I didn’t remove any AC component. The only one I need to remove is the AC line bracket that’s near the coolant reservoir to get access to the engine motor mount bolts.
    ASRDogman likes this.
  6. johnHRP
    johnHRP Active Member
    568
    169
    tally, fl
    I don't recommend resurfacing since the timing is really tight these days. It will cause mild pinging at light throttle when the timing is at full advance > 40 deg at around 1500 rpm. A very common result after resurfacing head in modern engine.
    Clean the head meeting surface with razor scraper for glass stoves should be enough. There should be not much deposit, usually squeaky clean, only head gasket coating residue.
    NutzAboutBolts likes this.
  7. ETC(SS)
    6,924
    Especially if your engine hasn't experienced a high-temp event......
    Besides, gaskets are cheap - eh? :whistle:
  8. ASRDogman
    7,145
    3,735
    I meant either ac line, so you don't lose refridgerant.
    Yes, the bracket for the line, but not the lines, which I take it you already knew...
    Hopefully, they can get the head back quickly.
  9. johnHRP
    568
    169
    tally, fl
    Gasket is cheap, but head gasket job is pain in the butt.
  10. Mendel Leisk
    40,505
    This TSB has part no’s for Toyota gasket kit, head bolts, and the revised piston/rings. Not sure if it’s the latest, but good starting point.
  11. NutzAboutBolts
    1,524
    1,622
    Bay Area
    lol I think it’s only a pain in the butt since I’m filming it too, taking longer than expected. I wouldn’t mind doing it again in the future, but the valve stem oil seals definitely need change since it can go bad, but let’s see how bad is the carbon build up in the head.
  12. adrtho4
    adrtho4 Junior Member
    26
    Houston, TX
    Yeah, when I checked the valves on my car and doing the leak test, the valves looked good still even at 161k miles. That said, if I have this car at the next 100k miles, I'm going to replace all the valves with new ones.
  13. NutzAboutBolts
    1,524
    1,622
    Bay Area
    mines at 284k miles… wish I had that easy valve compressor tool that Toyota has, would definitely make it easier to do it at home lol.
    adrtho4 likes this.
  14. adrtho4
    26
    Houston, TX
    Heard that. Found a video on YT and ordered the Lisle Valve Keeper Remover & Installer Kit (36050). Seems like it may work. Way to early for this tool but like the saying goes, I'd rather have it and not needed it....
  15. NutzAboutBolts
    1,524
    1,622
    Bay Area
    yeah I saw that tool… people complain the magnet is too strong lol… I think I’ll do that next time when this is a project car. As for how, I’m gonna just bring it in and see what they’ll do to the head. Maybe by next week I’ll be able to do that.
    adrtho4 likes this.
  16. Mendel Leisk
    40,505
    Is that correct?
