Left Rear Wheel Well -- how does this clip work???
Discussion in 'Gen 3 Prius Technical Discussion' started by MrPete, Jun 24, 2025 at 2:18 AM.
  1. MrPete
    MrPete Active Member
    456
    178
    Colorado, USA
    (I'm preparing to add some sound deadening to my Gen3 wheel wells.)
    As I clean the wheel wells, I noticed some things I've never seen before:
    • There's a cover on the back side, with two green clips. Having removed it, I found some pipes... using the P/N on the cover I learned the pipes are the gasoline filler pipes ;)
    • Then there's a lower cover on the outside edge, approximately behind where my mud flaps are normally mounted (see photo). I have no idea what this cover is for...
    • AND, it is held in place with two clips unlike any I've ever encountered before:
      • The clip "cap" is rubbery
      • There's a round hole in the center.
      • On the back side is a square plastic post, and at least one squeezable side bit.
    I have utterly failed to remove these clips, yet I need to (to add sound deadening to the metal behind it.)
    I have not yet found these clips nor the cover in any parts list.
    QUESTION: does anyone have any ideas or insight?
  2. Mendel Leisk
    40,498
    They’re very tricky to get off, likely the “official” method to remove is to just destroy the locking jaws and replace. Anyway:
    There’s two jaws, diagonally opposite in a square pattern. I used a pin in the centre hole, trying to catch the end of a jaw, press it toward the center, while prying up on the fastener’s flange at that same zone.
    If you’re successful in releasing the jaw, the flange will stay a little raised. Keep something in the gap and repeat the process on the diagonally opposite jaw.
    it helps to be myopic, and/or use good reading glasses and good light. Still you’re mostly going by feel. I believe one of the two you can see ‘round the back, get a better understanding of how the jaws are oriented, maybe even release one of the jaws.
