Nutz About Bolts Prius Maintenance Videos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Feb 17, 2016.
  1. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,522
    1,619
    Bay Area
    yeah, I think they know how to resurface if it doesn’t need it. I’ll probably ask them to clean the mating surface so it’ll bite the headgasket nicely so it doesn’t cause a leak. I’ll let you know how it’ll go in a couple of days.
  2. ASRDogman
    ASRDogman Senior Member
    7,141
    3,734
    You do NOT have to disconnect that AC lines, just move the compressor out of the way.
    After disconnecting the power cable.
    johnHRP likes this.
  3. NutzAboutBolts
    1,522
    1,619
    Bay Area
    which AC line?
    are you referring to the thermostat housing?
    #503 NutzAboutBolts, Jun 23, 2025 at 11:17 PM
  4. rjparker
    9,528
    5,833
    He is talking about the compressor and its refrigerant hoses.
  5. NutzAboutBolts
    1,522
    1,619
    Bay Area
    yeah I didn’t remove any AC component. The only one I need to remove is the AC line bracket that’s near the coolant reservoir to get access to the engine motor mount bolts.
    ASRDogman likes this.
  6. johnHRP
    johnHRP Active Member
    568
    169
    tally, fl
    I don't recommend resurfacing since the timing is really tight these days. It will cause mild pinging at light throttle when the timing is at full advance > 40 deg at around 1500 rpm. A very common result after resurfacing head in modern engine.
    Clean the head meeting surface with razor scraper for glass stoves should be enough. There should be not much deposit, usually squeaky clean, only head gasket coating residue.
    NutzAboutBolts likes this.
  7. ETC(SS)
    6,924
    Especially if your engine hasn't experienced a high-temp event......
    Besides, gaskets are cheap - eh? :whistle:
  8. ASRDogman
    7,141
    3,734
    I meant either ac line, so you don't lose refridgerant.
    Yes, the bracket for the line, but not the lines, which I take it you already knew...
    Hopefully, they can get the head back quickly.
  9. johnHRP
    568
    169
    tally, fl
    Gasket is cheap, but head gasket job is pain in the butt.
  10. Mendel Leisk
    40,502
    This TSB has part no’s for Toyota gasket kit, head bolts, and the revised piston/rings. Not sure if it’s the latest, but good starting point.
  11. NutzAboutBolts
    1,522
    1,619
    Bay Area
    lol I think it’s only a pain in the butt since I’m filming it too, taking longer than expected. I wouldn’t mind doing it again in the future, but the valve stem oil seals definitely need change since it can go bad, but let’s see how bad is the carbon build up in the head.
