Left Rear Wheel Well -- how does this clip work???
Discussion in 'Gen 3 Prius Technical Discussion' started by MrPete, Jun 24, 2025.
  1. MrPete
    MrPete Active Member
    466
    184
    Colorado, USA
    (I'm preparing to add some sound deadening to my Gen3 wheel wells.)
    As I clean the wheel wells, I noticed some things I've never seen before:
    • There's a cover on the back side, with two green clips. Having removed it, I found some pipes... using the P/N on the cover I learned the pipes are the gasoline filler pipes ;)
    • Then there's a lower cover on the outside edge, approximately behind where my mud flaps are normally mounted (see photo). I have no idea what this cover is for...
    • AND, it is held in place with two clips unlike any I've ever encountered before:
      • The clip "cap" is rubbery
      • There's a round hole in the center.
      • On the back side is a square plastic post, and at least one squeezable side bit.
    I have utterly failed to remove these clips, yet I need to (to add sound deadening to the metal behind it.)
    I have not yet found these clips nor the cover in any parts list.
    QUESTION: does anyone have any ideas or insight?
  2. Mendel Leisk
    40,534
    They’re very tricky to get off, likely the “official” method to remove is to just destroy the locking jaws and replace. Anyway:
    There’s two jaws, diagonally opposite in a square pattern. I used a pin in the centre hole, trying to catch the end of a jaw, press it toward the center, while prying up on the fastener’s flange at that same zone.
    If you’re successful in releasing the jaw, the flange will stay a little raised. Keep something in the gap and repeat the process on the diagonally opposite jaw.
    it helps to be myopic, and/or use good reading glasses and good light. Still you’re mostly going by feel. I believe one of the two you can see ‘round the back, get a better understanding of how the jaws are oriented, maybe even release one of the jaws.
    MrPete likes this.
  3. MrPete
    466
    184
    Colorado, USA
    Any idea what the part number is? I haven't found this at Amayama etc :(
  4. Mendel Leisk
    40,534
    Grit likes this.
  5. BiomedO1
    2,774
    1,473
    SacTown, Ca
    Get some stiff wire, paperclips in there - they'll act like 'ramps' as you pry them out????
    You may still destroy them, but it's worth a shot.....
  6. MrPete
    466
    184
    Colorado, USA
    Huh! Mine are different. But Mendel's trick worked. I used a sharp ice pick to pull one side at a time into the center hole. Not sure what part they used in mine. Here are some photos.
    Grit likes this.
  7. Mendel Leisk
    40,534
    In the left-side thumbnail, you're squeezing the jaws together with your fingers? That's basically the release trick, get something through that hole, pressed on the jaw head, push it towards the center, simultaenously prying the flange on that side. Keep that flange lifted (can take a few tries), then repeat on other side, which usually goes slghtly easier.
  8. MrPete
    466
    184
    Colorado, USA
    Naw, just showing it. Already removed.
    Usually I could get one side to pop up by pushing in from the side, then pull in from the end...
