After Gasket repair, got "Check Hybrid System..." error
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by adrtho4, Jun 24, 2025.
  1. rjparker
    10,188
    6,334
    It is doubtful the AC works if it won't go to Ready.
    Brian1954 likes this.
  2. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    It's blowing, but the air isn't getting cooled so yeah, good callout. Even when it's turned on the lowest setting, the ac temp isn't changing.
  3. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    Update: That Nexas Link arrived 10 minutes ago. Curious, I when and loaded up the Dr Prius app, and checked.
    Battery codes it reported was P0A09, P0A0D, U0110.
  4. Brian1954
    Brian1954 Senior Member
    2,252
    891
    South Central PA, USA
    Did you disconnect any wires from the inverter?
    One reason for the P0A0D code is that the orange safety disconnect plug for the hybrid battery was not inserted correctly. Did you do all three steps when putting that plug back in?
  5. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    Yes. I had a stripped bolt on the egr.
    For the main harness, I've tested the voltage and got 0 volts before I disconnected anything. Once I read that, I just disconnected the main connector to get to that stripped bolt. After that was removed, I reinserted the connector.
    I went on and finished the gasket job.
    The 12v dc batter was unplugged and the safety disconnect plug was also removed before hand.
  6. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    Codes from the Dr. Prius app.
  7. ASRDogman
    ASRDogman Senior Member
    7,618
    3,923
    Check the service plug, remove and reinstall it.
    Check all the connections, again, even ones your think you didn't disconnect.
    Was everything working before hand? I can't remember.
    It's either the service plug not installed correctly, or a loose or bad connector.
    #27 ASRDogman, Jun 25, 2025
  8. Brian1954
    2,252
    891
    I did not ask you any questions about the EGR. I asked if any wires were disconnected from the inverter when you worked on replacing the head gasket.
    I also asked about the orange safety plug. Did you do step #3, which is to slide the handle. The diagram I posted is for a Gen 2 Prius. The Gen 3 is very similar.
  9. ChapmanF
    18,257
    The safety interlock circuit that P0A0D refers to includes the pair of small contacts on the orange service plug (the ones that only mate when the handle is slid sideways in the last step) and also includes contacts beneath some of the inverter covers. If any of those covers were off, double-check those too. There are some good threads here about P0A0D troubleshooting.
  10. Brian1954
    2,252
    891
    I read this again and now understand that you disconnected the large orange cable from the inverter. Did you disconnect any of the low voltage wires from the inverter?
  11. ChapmanF
    18,257
    Sure, but there's a trap I often see people falling into here. While waiting for the scanner to arrive, it feels important to be doing something. But other than a quick check of the charge on the 12-volt and a reasonable check for cable connections you might have disturbed in the work that you did, you can end up "systematically narrowing down" a long list of things you have guessed belong on the list. (And sometimes, in doing all that, you can introduce new problems.)
    While waiting for a scan tool to arrive, it can be worthwhile to do the thing that feels counter to the urgency of working on your car, and just look at whatever other things are on your plate (dishes? lawn mowing? bills?), and when the tool does arrive the car may end up fixed just as quickly when you are able to see what problem it is telling you about, and you haven't created any new ones.
  12. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    And your question was answered. I might have messed up on the formatting but your query was answered. The stripped egr bolt lead to me removing the big cable to the inverter for more clearance space. And the orange safety plug as asked and answered many times before.
    No.
  13. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    I'll take a video during my lunch break to go over the safety interlock plug. I'll post the vid link here once it's uploaded. I'll look at the other threads in regards to troubleshooting the P0A0D error. Thanks.
  14. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    I get you.
  15. ASRDogman
    7,618
    3,923
    Since it's showing the error code for the inverter no producing the correct voltage,
    perhaps that cable you removed is not on properly????
  16. rjparker
    10,188
    6,334
    One of the biggest traps in troubleshooting is assuming steps that passed your initial test or inspection are correct and never retracing your steps. It leads to an ultimate frustration and a sense of nowhere to go further.
    The ac compressor runs on high voltage and you have none until Ready is achieved.
    Doing a major repair without a good Techstream scanner or equivalent is really a recipe for frustration.
  17. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    Could be. I will unplug the battery, remove the safety latch, wait for 10-20 minutes or so, do a voltage check again, and inspect if it's latched or not. I got ahold of the service manual and currently reading through it to ensure that I follow the steps properly.
  18. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    Yeah. I have what I have. That being said, I'm going to order a mini vci j2534 and techstream. Will have to get a cheap laptop to install techstream on and just have that as a portable diag station whenever stuff breaks.
  19. rjparker
    10,188
    6,334
    Waiting on the video
  20. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
