Nutz About Bolts Prius Maintenance Videos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Feb 17, 2016.
  1. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,725
    1,762
    Bay Area
    :cry::cry:
    that’s good to know, hopefully they do light resurfacing and not a lot of shaving. Will let you all know when it’s put back together lol.
    as for the brake booster, I’ll tackle that when the time comes, like this headgasket lol.
    I had the cold start knocking about 80k miles ago, only this time, it caused misfire and coolant leak. So when you do get the first symptom, you’ll likely need a new HG in the future. (y)
    I did have a partner to film with but we live too far apart and so it didn’t work out :cry:
    ASRDogman likes this.
  2. NutzAboutBolts
    1,725
    1,762
    Bay Area
    So out of all the gasket and o-ring left, I’m stumped on where this o-ring goes.
    I think it may be the ECT sensor o-ring, but my old head has a welded gasket on the side, the new head doesn’t have a welded gasket sticking out, it’s flushed. So I assume this o-ring is for the ECT sensor, what do you guys think???
    EDIT: ok after checking, it might be it :ROFLMAO:
  3. Mendel Leisk
    41,850
    Some documentation from Toyota would be nice. Always puzzles me: they put together this kit, and all the pieces have a part number and purpose, so why the heck not tag each item with those two bits of info, plus a summary sheet.
  4. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    What was the issue when I got my kit. Figuring out which gasket goes where apart from obvious ones like valve cover, intake, timing chain tensioner. There were a lot where I had to hunt and figure out what went where.
  5. NutzAboutBolts
    1,725
    1,762
    Bay Area
    don’t worry, I got you! I’m filming and will be showing you where all the gaskets and o-rings are located at.
    It looks intimidating at first, but it isn’t so bad. I do agree they should’ve listed the names of each gaskets and o-rings.
    ETC(SS), Mendel Leisk and adrtho4 like this.
  6. NutzAboutBolts
    1,725
    1,762
    Bay Area
    Disregard that o-ring for the ect sensor, I believe that o-ring was for the oil dip stick tube. The ect sensor has a metal flat gasket on it. Gotta go to Toyota and get one tomorrow.
    edit: my old copper gasket was stuck onto the head. lol make sure you guys remove it if it is.
    ETC(SS) likes this.
  7. NutzAboutBolts
    1,725
    1,762
    Bay Area
    Just finished the headgasket install. No misfire, running clean.(y)
    time to edit the videos :cry:
  8. ETC(SS)
    7,330
    Yeah, but think how nice it will be to get to 100,000 subs...... :)
    NutzAboutBolts likes this.
  9. NutzAboutBolts
    1,725
    1,762
    Bay Area
    :ROFLMAO::ROFLMAO: I’m still waiting for the 100k sub plaque :)
  10. ASRDogman
    ASRDogman Senior Member
    7,788
    3,975
    Wellll, that was easy wasn't it? :rolleyes::rolleyes::rolleyes:o_O(y):whistle::whistle::whistle:
  11. NutzAboutBolts
    1,725
    1,762
    Bay Area
    it was :ROFLMAO::ROFLMAO::ROFLMAO: I was working on the car from 9am-2pm for 9 days or so. Filming and cleaning everything took most of the time, if I was just going to replace the 2 o-rings on top of the camshaft housing and the 2 o-rings on the left side of the head and 1 on the block, everything would’ve been faster.
    I replaced all the o-rings, gaskets and oil seals. Good thing I didn’t have to work on the head valve train, or else that’ll add more hours to this job :ROFLMAO::ROFLMAO::ROFLMAO:
    Overall, I wouldn’t mind doing it again, with out filming it, glad I got that out of the way.
  12. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    I mean, if you had to do it again and got stuck some where, I'm sure there would be a Nuts about Bolts video that could help you out. :ROFLMAO::ROFLMAO::ROFLMAO:
  13. NutzAboutBolts
    1,725
    1,762
    Bay Area
    :ROFLMAO::ROFLMAO::ROFLMAO: True true.
  14. NutzAboutBolts
    1,725
    1,762
    Bay Area
    Just purple power, pressure wash and 303 protectant the engine bay. :)
    ETC(SS) and johnHRP like this.
  15. johnHRP
    johnHRP Active Member
    645
    189
    KA, DE
    Excel
    Wow, you have "double catch can". One before PCV valve (buffle) and 1 after. Did the additional catch can reduce the carbon deposit in the intake ports?
    I just cleaned my intake manifold and EGR elbow pipe. The intake ports are a bit crusty at 112k miles.
  16. NutzAboutBolts
    1,725
    1,762
    Bay Area
    I decided to break down the headgasket video into 3 installment so it’ll be easier to watch since it’s going to be 2+ hr long if I condense everything together. I still got a couple of weeks left to go until I’m finish with the rest. Hopefully it’s informative :ROFLMAO:
    ASRDogman, adrtho4, Joele3 and 5 others like this.
  17. NutzAboutBolts
    1,725
    1,762
    Bay Area
    Here’s the videos of the head gasket replacement.
    part 3 is still processing, will post once its done uploading.
    johnHRP, ASRDogman and Mendel Leisk like this.
  18. Mendel Leisk
    41,850
    (y)(y)(y)Thank you!(y)(y)(y)
  19. Mendel Leisk
    41,850
    part1,32:30: you call for 12 mm triple-square driver for the head bolts. It's work but isn't optimum. Toyota spec is 10 mm double-hex. The latter isn't hard to get, available on Amazon.
    #559 Mendel Leisk, Jul 19, 2025
  20. NutzAboutBolts
    1,725
    1,762
    Bay Area
    interesting, I never tested the 10mm, I used the 12 and it fit snug. Maybe 10 would work but I can’t check it out :ROFLMAO:
