I Need to Fix The Rear Defroster
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kent10, Jun 29, 2025.
  1. Kent10
    Kent10 Junior Member
    Flagstaff, AZ
    I have a 2007 Prius and the rear defroster no longer works. I took it to Toyota and they said the connector has come off and needs to be put back on or the window needs to be replaced. They do not fix windows.
    I thought I would try this kit 1st and see if I could fix it myself.
    Permatex 21351 Electrically Conductive Rear Window Defogger Tab Adhesive
    I need to know how to get access to this connector. Where is it located? Do I simply pull off the side panels at the rear window? Is there one that needs to come off 1st? Any tools needed?
    Thanks very much, Kent
  2. PriusCamper
    PriusCamper Senior Member
    12,723
    5,143
    Pacific Northwest, USA
  3. ChapmanF
    18,127
    I bet it's pretty visible and accessible once the hatch inside trim is pulled off. I've pulled off the hatch inside lower trim on a gen 2 (easily), the part that's behind the garnish piece that always breaks. But I don't remember if that was one piece for the whole inside of the hatch, or if other piece(s) go up the sides of the window.
    I suppose the tab adhesive might do the trick, looks like that's exactly what it's made for.
    I haven't ever reattached a tab. I did fix one or two rear defoggers with the silver paint for fixing where something scratched through one of the traces.
  4. Tombukt2
    12,924
    2,322
    The lil tang is off remove it file down pads this is important . Youcan use permatex but the real stuff is Atom you can buy on eBay it's what I use . Don't mess w glass clean pads take atom cement popsicle stick onto pad area on glass a dab on pads wait 25 or seconds apply pads of tang to glass hold a few seconds . Let stand overnight Before attempting to add wire connector done . Atom cement. Is the standard
  5. Kent10
    Flagstaff, AZ
    Thanks PriusCamper. I'll take a look at the links.
    ChapmanF. Thanks. I'll just have to start pulling and see how it comes off. I am always worried about breaking something but it is probably quite rugged.
    Tombukt2. Thanks for the recommendation. I might just try the Atom. The Permatex gets mixed reviews. Is this the one you would recommend? Auto Glass Rear Window Defroster Defogger Grid Repair Kit -By Atom Adhesives 5g | eBay
    Thanks again, everyone. It will be nice to get this working again.
  6. Tombukt2
    12,924
    2,322
    Atom adhesives . Clean posts w sanding whistle clean test feet pad angles dry get em flat they bend easy . that is all
  7. ChapmanF
    18,127
    It's an open-book test, you don't lose points for looking in the repair manual to see how many clips are holding it on and where they are:
    Toyota Service Information and Where To Find It | PriusChat
    Generally, the idea is the clips stay in the trim piece and pop out of the holes in the sheet metal.
    There are usually a few clips that get other ideas, and slip out of their notches in the trim piece and stay in their holes in the sheet metal. So then it's a matter of popping those out separately, and sticking them back into their notches in the plastic.
  8. Tombukt2
    12,924
    2,322
    Yes in gen2v a scraper slips in black plastic trim the lower part the glue points are level with wiper in the corners with opaque plugs.you will see one hanging or you touch one and it loose gently rock it off .
  9. Kent10
    Flagstaff, AZ
    Thanks very much everyone! I ordered the Atom Adhesives and will give it go when I have some time.
    PriusCamper likes this.
  10. Kent10
    Flagstaff, AZ
    Unfortunately, I failed. Thought I could do it. Got the trim off. Got the tab off. Cleaned both the tab and window surface. Put the Atom adhesive on after thoroughly mixing. And then held it in place a long time but after releasing gravity would have the tab slowly fall off. I put more Atom on and held again and same thing. Finally tried masking tape but that was very difficult to use in a tight spot. The tab got slanted. I tried repositioning it and it fell into a crack on the frame of the rear door. No way to get it. I know I can order a new tab but I don't think the Atom will hold it in place for me. Maybe it was too warm so not thick enough.
    At least I tried. Thanks for all the help. If I get a new window from Safelite will they have a new tab for the new window or is that something I should buy beforehand.
    Thanks, Kent
  11. Kent10
    Flagstaff, AZ
    I just emailed a local auto glass store. Not open on weekends so couldn't call. But asked them if they can supply a tab and fix it. I don't really need a new window.
  12. Tombukt2
    12,924
    2,322
    A new tab maybe a thing if you can't get your original extremely flat and all the adhesive off of it like with the Dremel with grinder on its end you should be able to buff the flat ends that go against the glass so smooth they almost form a seal on glass by itself wen I. Mixed the stuff it seemed ok and held no tape used and left plug off 24 hrs no touch . Seems ok and works . I did order new metal connector mine was not good not str8
  13. PriusCamper
    12,723
    5,143
    Are you saying you have to scratch down to clean glass in order for product to work?
  14. Tombukt2
    12,924
    2,322
    No me thinks atom says not to do that or if attempted be very careful not to damage the contact wires on glue on glass use like glue softener or such at must to smooth old atom or cement and apply new to that area attach metal tab watch glue start to set . I left glass up an hour . Then closed gently connected next day.
  15. Kent10
    Flagstaff, AZ
    I haven't heard back from the auto glass store and the fix has been on my mind and bugging me. So... I may try again.
    Thankfully I took a pic of the tab before losing it and this is the closest I could come up with (see link from Amazon and my last image below). The part that goes into the power cord looks the same. I see there are 2 holes in each of the parts that touch the window. This might help it stick with the Atom. The original tab holes are filled in.
    Then I am going to try to flatten the area on the window and buy more Atom. I'll get more than the one use Atom this time.
    From Amazon
  16. dolj
    dolj Senior Member
    8,437
    4,288
    Wellington, New Zealand
    I presume this Atom adhesive is conductive, is that correct?
  17. Kent10
    Flagstaff, AZ
  18. Kent10
    Flagstaff, AZ
    The new tab I bought does not have holes as I thought. There are small knobs on the surface that make contact with the window. So now I hope that helps by keeping some of the Atom on the bottom instead of all being squeezed out with a flat surface like what happened with my old one. If I use enough Atom it should stay on the bottom and create good contact. We'll see.
  19. Kent10
    Flagstaff, AZ
    The new tab would not fit in the electrical part. I had to file it down. Now it fits but it is very stiff to get in. To get the old one out I recall having to use pliers. Very difficult to remove. There was nothing to push to release the tab, like on some videos.
    Now I am concerned that if I do get the tab to stick with the Atom, that when I attach the electrical, it may come off with the pressure needed to fit it on. I might not fully insert it and then use electrical tape to hold it in place. Tough not knowing how strong the Atom is. If I have any left over I could put some on top to try to secure it more strongly.
  20. ChapmanF
    18,127
    You could solder a short wire to the new tab that ends in a terminal that does fit the car's wiring connector.
    (If the car wiring has a female terminal, the trick is to get the part number of a corresponding male terminal. A trick I've used is to look in the online electrical wiring diagram and find the part number of the female one. Then browse through the various wire-harness-to-wire-harness junctions looking for one where that terminal part number is used on one side. Buy the male terminal whose part number you find on the other side of that. Of course this only works if the terminal in question also gets used in a harness-to-harness junction somewhere.)
    I would not advise leaving the connection partly connected and held with tape. There's a fair amount of current involved, and you could heat up that terminal and make bigger headaches.
