Another EGR thread, where the focus is NOT having to clean it, preventative care.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by h1ph0panonymous, Jun 30, 2025.
  1. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    OP, feel free to do as you wish, it's your car. But to tell others that EGR circuit cleaning is totally unnecessary if you use some kind of magic additive/cleaner, and you'll be fine with regular maintenance, then that's where it's your opinion(s).
    Don't try to convince others to do as you do. You be you.
    SM-S936U ?
    ASRDogman likes this.
  2. h1ph0panonymous
    258
    36
    Please show me where I said this was a cure all?
  3. h1ph0panonymous
    258
    36
    Yeah and when the 5 year old daughter doesn’t want to, you just leash them to the garage right?
    There seems to be many questions I’ve asked being non-answered or gas lighted away because “I can clean the EGR manually” mentality.
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,699
    1,746
    Bay Area
    Just buy an electric vehicle, you won’t have to worry about the EGR system (y)
  5. bisco
    51,999
    we can't even agree on whether the egr is the cause of head gaskets failing.
    without testing, it's all conjecture
    h1ph0panonymous likes this.
  6. bisco
    51,999
    i did, now i have other worries :ROFLMAO:
    NutzAboutBolts likes this.
  7. NutzAboutBolts
    1,699
    1,746
    Bay Area
    :ROFLMAO::ROFLMAO::ROFLMAO:
    I think all 3rd gen will have a bad headgasket. It’s by design, doesn’t matter 2010-2015, you will eventually have to replace the Headgasket. Mines at 284k and still end up replacing it. Some replace it at 300k, some earlier at 100k. Eventually, you will all have to replace it. Read too many people replacing it and it’s a common issue on the 3rd gen. I doubt the EGR has anything to do with the headgasket.
    the EGR will get caked up regardless of what you use, it’s in the egr cooler and no additives will be able to break down what’s in the cooler. It’s not in any engine compartment for the additives to coat the cooler to clean it from the inside. The only thing that goes through the egr cooler is recirculating exhaust gas.
    let me know if you find one that works without taking the egr out and cleaning it. I would like to try :D
  8. h1ph0panonymous
    258
    36
    I would’ve if could’ve, I went from a 2017 Ford Fusion SE from 7k miles to 93k miles with only having to change the brakes and rotors as my one and only maintenance, that thing got 37 mpg average when fully unloaded on the way to CarMax to trade her in for this 2014 Prius with 38k miles during the trade in as a down payment for the Prius. So far, 36k miles later, (75k miles now) I’ve had to replace both rear wheel hubs, front and back rotors as well as pads as of these two last weeks. I think I should’ve kept the Ford.
  9. NutzAboutBolts
    1,699
    1,746
    Bay Area
    not bad on the ford fusion.
    I’m surprised your brake system’s been serviced. Im still on my original brake pads and rotors, and wheel hubs, and my vehicle is a 2012 Prius IV.
    I’ve been just doing regular routine maintenance and it hasn’t given me any trouble, besides this misfire cylinder 1, and coolant leak, which is the headgasket that im fixing now.
    honestly, im gonna keep this Prius till it dies, and even then, i might just drop in a new used engine if the engine blows up on me. But the only thing im afraid while driving the Prius is people stealing my Cat or my hybrid battery.
  10. h1ph0panonymous
    258
    36
    Thanks, it was an okay car, the payments were a hundred less and I had another year of payments before trading her in.
    I don’t know the person or history of the previous owner of my 2014 Prius so who knows what happened or where it was in the 39k miles I bought it at.
    When doing the rear hubs, it took ten minutes of banging it with a hand mallet, half a bottle of WD40 sprayed in the cracks of the mating between the hub, frame and dust shield. Some shimmings were missing on the brake pads and the anti-rattle clips were missing. (Who knows who did them, hopefully not CarMax mechanics) the hubs were factory, both failed at the same time which is actually good to hear. I live in Minnesota so she went two years in the rust producing environment. The lower slide pins on both rear calipers were seized with rust, if I didn’t have a culinary torch to use to heat them and twist them out with a socket wrench using a twist and pull technique I would’ve cried and went ape shit on the car. (I’m ordering new slide pins and bushing next pay)
    By the way I’d like to formally thank you for the rear brake job video you posted, it came in handy during my brake job.
    The main reasons I wanted this prius was gas mileage and the fact you can van life in it or camp/sleep in it incognito which I haven’t tried or set up for yet but really want to even as a 6 foot tall person. I can see the car being able to pay for itself if used as a van life, rent money can go towards all these extraordinary repairs and preventative measures from major repairs but I can’t live that life as I got into a pickle with my pickle (got a second child coming soon) so nesting in my car between two baby mamas isn’t an option, I’m in good terms with my current partner too so don’t want to abandon living with her. Although sometimes it would be nice to just get away from life in the prius.
  11. ASRDogman
    ASRDogman Senior Member
    7,607
    3,915
    Some people just aren't happy no matter what. They just like being unhappy, and want to spread that
    to other people so they can feel better in there unhappiness.
    If you don't like the car you're driving, get rid of it, and get something you like.
    You will still have issue with that vehicle.
  12. h1ph0panonymous
    258
    36
    That’s what you inferred from the chain of comments in this thread?
    I feel like I’m arguing with theists in an atheist versus theist debate forums at this point, just making non-evident inferences, using intuition as a high horse.
  13. ASRDogman
    7,607
    3,915
    I rest my case! (y)(y)
  14. h1ph0panonymous
    258
    36
    Is this your happy place? LOL
  15. NutzAboutBolts
    1,699
    1,746
    Bay Area
    :D
    that’s my fear of buying a used car, I don’t know the history of it, but I’d definitely would do all the maintenance as preventative before I even drive it around. It doesn’t help you’re in a colder climate so things will rust under there. California weather don’t have that issue unless you live near a beach :ROFLMAO::ROFLMAO:
    yeah I like the Prius because it’s easy to get around city to city and parking in smaller places without issues. Other vehicles are medium size and hard to park. Camping life style in a Prius is doable, since you can drop the back seat down and have a futon in there without issue. (y)
    be on the look out for the headgasket video in a couple of weeks. Thanks for watching my videos :D
  16. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    You physically can separate the material easily with bare fingers. It will leave the catch can into the egr cooler clogging it up
  17. xliderider
    8,140
    3,277
    Honolulu, HI
    Not if you use the stainless steel potscubbers.
    In addition to the SS potscrubbers, I made filter screens out of multiple layers of a fine mesh stainless steel. It acts like an oil saturated gauze filter (like K&N) to condense out the vaporized oil in the PCV circuit on its way to the intake manifold.
    There is still oil that gets through to pool in the intake, under the throttle body, and the inside of the hose attached to the intake manifold is coated in oil as well. 20211202_114442.jpg 20211109_112505.jpg
    SM-S936U ?
    Grit and h1ph0panonymous like this.
  18. h1ph0panonymous
    258
    36
    You a magician? What’s holding your media in the second pic...
  19. NutzAboutBolts
    1,699
    1,746
    Bay Area
    looks like the oil catch can top cap…
    I did a cleaning on the intake manifold since I had the occ and there wasn’t any pooling of oil behind the throttle body plate under the intake manifold.
  20. ETC(SS)
    7,184
    For an eleven-year-old car?
    Easy.
    A time machine. ;)
    It's like asking how you prevent......um.... 'aging' in a 50-year-old male.
    You can't.
    You have to start out with a ONE year old male - or deal with the....um...'aging' that occurs with some poorly maintained 50-year-old males or that which WILL occur later in some of the better cared for examples.
    The great philosopher Robert "Rocky" Balboa once said:
    Time is the all time champ. Time knocks everybody out.
