backyard swing set frame hoist
Discussion in 'Gen 2 Prius Technical Discussion' started by Tombukt2, Jun 29, 2025.
  1. Tombukt2
    13,441
    2,418
    I lifted a complete Prius w no tyres w lifting strap thru door holes lifted by roof completely off ground so a trailer could slide under it . This is 4x4 beans legs and a 4x6 cross beam w a electric winch rated for 1000 pounds the car was engineless no trans either . But still I'm surprised it held no pics it happened sooo fast
  2. pasadena_commut
    pasadena_commut Senior Member
    2,856
    850
    Southern California
    Sounds like that contraption was being used at roughly twice its rated capacity. It may have held but still a very bad idea, at least if you expect it to keep working reliably.
    I would be surprised if this didn't deform the roof, but perhaps this vehicle was on its way to the junkyard so that wouldn't matter?
  3. Tombukt2
    13,441
    2,418
    Yes it was on its way to the junkyard this is ganyard out of 4x4 legs and 4x6 x beam and steel swing set corner assemblies I guessed it might do 4k pounds it's just used for trans and engine pulls. The electric winch is only rated for like 1500 max but still works .
  4. Mendel Leisk
    41,907
    Is “ganyard” a typo ?
  5. rjparker
    10,518
    6,600
    Gantry as in Gantry Crane
    Tom uses voice to text and swing sets for gantry cranes.
  6. Tombukt2
    13,441
    2,418
    I cannot have wheels unfortunately.
  7. rjparker
    10,518
    6,600
    Dang, around here guys who can't have wheels have dui's. Most drive anyway.
  8. Tombukt2
    13,441
    2,418
    Yeah I meant on the swing set frame lift with the winch . No concrete . But the new trailer receiver mounted hoist is a breeze no need move hoist it has a boom just one hand swivel engine and trans around to side of engine bayswing boom 280 to other side and pickup other engine n trans assy swing it right over chassis and drop in car . Hoist stays out boom moves . Makes it fassst.
  9. Mendel Leisk
    41,907
    I was thinking backyard swing set, guess I’m getting conversant in voice-dictation.
  10. Tombukt2
    13,441
    2,418
    That's exactly right Mendel these are the backyard swing metal brackets 4x4 legs 4c6 top beam no swings attached instead an electric I beam type hoist w yellow box w buttons . The brackets are green sold all over a 12 foot 4x6 w piece of unistrut attached to bottom of 4x6 should be able to hold 4k dead weight it seems . No humans under it
  11. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Reported to mods for thread title change.
    SM-S936U ?
