2016 Prius 3 Touring Brake Actuator Noises
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Iron Man Prius, Jul 1, 2025 at 12:48 PM.
  1. Iron Man Prius
    Iron Man Prius New Member
    Tuesday
    Fullerton
    Three Touring
    I know the Gen 3 issues with this, but how much pump cycling is TOO much for a Gen 4 if you're parked not pressing the brake? I hear it often, but nothing after the car shuts off (like a Gen 3 would if it was going out). No other brake issues or noises and everything else seems fine, and no codes..just have PTSD from the Gen 3. Car has 170k miles. Just ignore it and give it a brake flush and call it good?
    51,104
    you have nothing to worry about until you get trouble codes. hard to say whe too much is too much before then. you may never have issues.
    Iron Man Prius likes this.
  3. Iron Man Prius
    Tuesday
    Fullerton
    Three Touring
    It does run a lot just sitting there, it just freaks me out. If a Gen 3 does it that much, the inevitable is coming.
  4. bisco
    51,104
    it could be coming, but there's no way to know, unless tech stream has a testing procedure
    amos likes this.
  5. ChapmanF
    17,273
    Gen 4 has quite a different hydraulic system, if I remember right. I'm not sure how many lessons from gen 3 even carry over straight.
    amos likes this.
  6. Iron Man Prius
    Tuesday
    Fullerton
    Three Touring
    So because it's buzzing and charging up as much as a bad Gen 3 unit, doesn't mean it's bad and it's normal?
  7. ChapmanF
    17,273
    We have a thread somewhere that compares the gen 3 and gen 4 brake hydraulic systems. I'd want to review that before answering.
    IIRC, there's a generation where they did away with the accumulator altogether. but maybe that wasn't till gen 5.
