2007 model, hybrid warning light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SarcasticFringehead, Jul 5, 2025.
  1. SarcasticFringehead
    SarcasticFringehead Junior Member
    UK
    Last drove the car two days ago locally.
    Drove today on the motorway for just over an hour. Red triangle plus hybrid warning came on.
    I then had to drive for a couple of miles before I could find anywhere to pull up and park.
    The warning lights come on every time I restart the car. It’s not internittent.
    Nothing about the driving experience seemed off. Nothing in the car’s recent history seems like it could have caused this, though what do I know.
    I’m waiting for the tow truck now.
    I don’t have a code reader. I realize that without codes, anything you can tell me is no better than a wild guess.
    But my garage is closed till Monday and I could do with the emotional support. Please come at me with your best most wildest guesses as to the manner and extent of how screwed I am.
  2. fragglestickcar
    87
    47
    New York
    Inverter overheat due to a failed pump which might have died during winter but you'd only learn about it in summer. Car largely functional but loses upper-end power.
  3. SarcasticFringehead
    UK
    Wow! Thanks for that interpretation.
    Assuming you’re right, is it gonna be hell to fix?
  4. SarcasticFringehead
    UK
    Update: the yellow brake system warning light ((!)) is also on. I didn’t notice this before.
  5. SarcasticFringehead
    UK
    Update: following codes came up:
    ABS (Anti-lock Braking System)/VSC (Vehicle Stability Control)/TRC (Traction Control System)
    C1310
    HV System Malfunction
    Current
    CCS (Cruise Control)
    P3000
    Battery Control System
    Current
    HVB (Hybrid Vehicle Battery)
    P0A84
    Hybrid Battery Pack Cooling Fan 1 Control Circuit Low
    Current
    P0A84
    History
    HC (Hybrid Control)
    P3000
    Current
    HC (Hybrid Control)
    P3000
    History
    EMPS (Electronic Motor Power Steering)
    U0121
    Lost Communication With Anti-Lock Brake System (ABS) Control Module
    Current
    AC (Air Conditioning)
    B1421
    Solar Sensor Circuit (Passenger Side)
    Current
    B1400
    Normal
    History
  6. fragglestickcar
    87
    47
    New York
    Yeah, no it's not the inverter pump then.
  7. SarcasticFringehead
    UK
    I bet it’s corrosion of the hybrid battery from the leak last year. There would have been standing water in there for ages.
  8. Brian1954
    Brian1954 Senior Member
    2,194
    862
    South Central PA, USA
    Code P0A84 is the one that needs to be fixed. Check for corrosion in the electrical connector for the hybrid battery cooling fan. This is a very common problem for a Gen 2 Prius.
  9. SarcasticFringehead
    UK
    Thanks for that tip.
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,045
    1,969
    NJ-USA
    Specifically, there's a white connector behind the right side interior body panels near the battery fan. It's not uncommon to have a body leak allow water to dribble into that connector and corrode it.
    The repair is to hard splice each wire, eliminating the connector. Then clean and reseal the cracked body sealant around the tailgate hatch frame.
    Brian1954 likes this.
  11. SarcasticFringehead
    UK
    @Brian1954 and @mr_guy_mann are correct. It was a burnt out connector caused by corrosion from the body leak.
    The garage’s immediate reaction was that I had to replace the hybrid battery. The mechanic sounded *so happy* on the phone when he told me it was just a burnt out connector.
    bisco, Brian1954 and fragglestickcar like this.
