Question-2025 Prius in EV Mode: Reply quickly!
Discussion in 'Gen 5 Prius Technical Discussion' started by iRun26.2, Jun 13, 2025.
Tags:
  1. Quovadis007
    Quovadis007 Junior Member
    COVENTRY
    2024 Prius Prime
    Business Ed. Plus
    The Prius phev 2023, switches on the ice, in Ev mode, when you ask for more than 75% of the power.
    You can easily see this on the energy meter. There are 4 energy consumption blocks, 25% eco, +25% eco, then 25% power, this always goes electrically, but if you start the last block of 25%, the Ice always starts.
    Once the Ice starts spinning, it will continue to do so for at least 5 minutes.
  2. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    I attached a close-up picture of my ‘charge-evo-power’ meter (on the upper portion of the picture). Notice how both the ‘eco’ and the ‘power’ sections have a half way through position with a notch. I’m guessing that if you get past the 1/2 point in the power section, that is when the engine will turn on.
    Later today, I am going to try it out on my 2025 model. I should note, my car is in EV mode.
    #142 iRun26.2, Jul 5, 2025
    Quovadis007 and Gokhan like this.
  3. Gokhan
    Gokhan Senior Member
    6,561
    2,618
    Paramount CA
    You got too excited and accidentally hit the HV or EV-Auto button? I have done that. ;)
    It could also be a high-battery-temperature issue as the manual says.
  4. Gokhan
    6,561
    2,618
    Paramount CA
    I am not familiar with the Gen 5 display (darn, it is small and cramped!), but no, that cannot be. As discussed here, in the BEV mode (not in the BEV/HEV auto mode), the engine would not kick in no matter how much you press the accelerator as long as you are under 84 mph, except perhaps in unusual circumstances such as an overheated or too cold traction battery.
  5. Gokhan
    6,561
    2,618
    Paramount CA
    I do like how all the info was put together in that small display though.
    The Arene software platform (available in the Gen 6 RAV4 and probably also the Gen 6 Prius) will revolutionize these displays, as they will become highly customizable.
    Tolarian Academy likes this.
  6. iRun26.2
    824
    169
    United States
    I took a road trip tonight and drove 51.8 miles (50% highway) on pure electricity (one charge). I tried but was unable to force the gas engine on by really pushing hard on the accelerator (in EV mode). The maximum EV acceleration was amazing! Much stronger than anything I’ve experienced in a Prius before (and the gas engine was completely off). That’s really not what I was expecting. The gas engine must have turned on last night because I was accelerating so much AND it was hot (it is much cooler today in Minnesota).
    And, hey, I love my display! I thought it would make me not want to buy the car before I saw it in person (it was criticized by a few reviewers) but, as it tuned out, I like it quite a bit. I like the smaller one shown in my picture because the other half of the display (not shown in my picture) simultaneously shows my cumulative electricity efficiency in miles/kw-hr. (Something I’m always trying to maximize)
    Gokhan likes this.
  7. KMO
    KMO Senior Member
    2,014
    740
    Finland
    2023 Prius Prime
    The maximum power you can ask for in EV mode is 75%. Try it.
    Power demand is limited to 75% even if the engine is running!
    That never happens in EV mode. Full pedal travel won't enter the last block of 25%.
    Any engine start will be due to some other condition, such as the system feeling the battery can't currently supply the full 75%.
    #147 KMO, Jul 6, 2025
    otatrant and iRun26.2 like this.
  8. iRun26.2
    824
    169
    United States
    I am in complete agreement. It is what I found myself last night driving my new 2025 version. I am amazed at how strong you can push the EV motor/battery and not see the engine come on. In my 2012 model you had to be very careful when in EV mode or you’ll start up the gas engine. I much prefer my newer model: Much more available power in EV mode (it feels like a sports car to me) :)
  9. Gokhan
    6,561
    2,618
    Paramount CA
    Well, Gen 3 PHEV didn't really have a decent BEV mode. Gen 4 PHEV and Gen 5 PHEV are very similar.
    The other poster who claims the engine kicks in at high throttle is confusing the EV mode with the EV-Auto mode.
    All that said, in the owner's manual, Toyota doesn't recommend using the EV mode on the highway. They recommend the HEV mode for highway, which is usually cheaper at high speeds and prolongs the traction-battery lifespan, and the EV mode for city, which is cheaper at low speeds and not hard on the traction battery.
  10. iRun26.2
    824
    169
    United States
    I don’t remember anything from the manual about EV driving (at highway speeds) being hard on the traction battery. I would think that if it was that bad, they wouldn’t let you go past 60 mph in EV mode.
    I certainly do not care if gas is cheaper to use. I didn’t buy my car to save money. I bought my car to burn less gas (yet still have choice to use gas). I primarily drive 20.8 miles back and forth when I go to work. I don’t need to drive 65mph (highest speed limit) but I will definitely not be turning on the gas motor when I go back and forth to work in the warmer months of the year . Right now I can make it both ways in one charge and that is awesome!
    Maybe my traction battery won’t last as long. I guess I will have to live with that.
  11. Gokhan
    6,561
    2,618
    Paramount CA
    Both high traction-battery currents and high traction-battery mileage will reduce the life of the traction battery.
    Don’t forget that the traction-battery life is based on the number of charge cycles. For a 13.6-kWh PHEV battery, you will get 1/4 of the mileage life of what you would get with a 54-kWh BEV battery. So, if a BEV-battery life is 400,000 miles, you might end up only getting 100,000 miles of BEV driving with a 13.6-kWh PHEV battery.
    @bwilson4web only got 150,000 miles out of his Tesla Model 3 BEV battery, but his 2170 cells probably had the short-cycle-life NCA cathode unlike the Prius PHEV’s NMC cathode and he probably used fast charging a lot, which is also not available in the Prius PHEV.
    Battery life of 2019 Tesla Model 3 Std Rng Plus—Fuel Economy, Hypermiling, EcoModding News and Forum—EcoModder.com
    #151 Gokhan, Jul 6, 2025
    GcinFl likes this.
  12. iRun26.2
    824
    169
    United States
    I found the following study:
    EV Battery Health Insights: Data From 10,000 Cars | Geotab
    One of the interesting (and slightly surprising) result of the study was the following:
    Does high vehicle use impact battery degradation?
    Surprisingly, our research found that high-use electric vehicles do not experience significantly greater battery degradation than lower-use vehicles. This is encouraging news since EVs deliver better value when driven more frequently.
    The key takeaway? You can confidently use your EVs in high-demand duty cycles without worrying about accelerated battery wear, provided they stay within their daily driving range. However, frequent use of DC fast charging for high-use vehicles may contribute to faster degradation.
    Figure 5: Amount of use has a small impact on average degradation rates (~0.25% over 48 months)
    This is my use case exactly (lots of miles)! If I can extrapolate their finding to the Prius PHEV traction battery, I should be able to get more mileage out of my battery if I use it more often (which I plan to do).
    Battery aging (and heat from the many forms) still will degrade the battery so I will not be driving really fast or accelerating very strongly. I am encouraged by their findings for heavy use and look forward to seeing what the results for my Prius PHEV battery will be.
    otatrant and GcinFl like this.
  13. bisco
    52,421
    the trouble with these studies is that manufacturers use different lithium chemistries, and differen types and levels of battery protections.
    Gokhan likes this.
  14. iRun26.2
    824
    169
    United States
    They did claim to have over 10,000 EV’s worth of data. I wouldn’t think they would have needed to compare data from mixed chemistries to produce their results with that many available samples to choose from.
  15. Gokhan
    6,561
    2,618
    Paramount CA
    There is something called cycle life, which is well-studied for different batteries.
    As far as aging due to time, the best practice is to never store the battery at high SOCs, which means that you should charge the car only immediately before you drive. The ideal storage SOC is about 25%. You should never store at over 70%, and even that is too high for longer than overnight. Also, avoid charging immediately after you drive when the battery is hot.
  16. Hammersmith
    Hammersmith Senior Member
    2,329
    2,388
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I just want to point out that overly prioritizing HV battery health could lead to behavior that negatively impacts ICE health.
    If you're doing everything possible to drive ONLY in EV, you're letting all the thin 0W-16 oil drain down from the cylinder walls and bearing surfaces. After enough time, you're going to lose seal around your pistons, letting fuel leak down into the oil when the engine finally does start. And letting the bearing surfaces "dry" out means increased wear during engine start. Now, it only takes the engine about a half second to build oil pressure, but it's still not good for the lifespan of the engine to repeatedly let it start dry.
    It's also not great practice to let the fuel always sit at around 1/4 tank just to reduce weight. The fuel pump needs to be immersed in fuel to help keep it cool while operating. It can handle occasionally running down to a 1/4 tank(and the 1gal buffer after "empty" certainly helps), but always operating at low fuel is a good way to reduce the lifespan of the fuel pump. And these aren't cheap pumps any more.
    Personally, I'd run the engine at least once a week to keep everything lubricated properly if I had a Prime. And I'd never go longer than two weeks without running the engine.
    Trollbait likes this.
  17. Gokhan
    6,561
    2,618
    Paramount CA
    Well, even SAE 0W-8 is thick when it is cold.
    I think the Prius Prime/Prius PHEV has a failsafe that periodically turns on the engine to maintain it even if you only use the BEV mode.
    I use the BEV mode only for city driving.
  18. Hammersmith
    2,329
    2,388
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The safe mode is a lot longer interval than you'd think. I think it's on the order of multiple months. And all oil will eventually drain away from from cylinder walls and other wear surfaces. It's why dedicated engine rebuild shops use assembly lube while ordinary mechanics shops can use motor oil for the same thing. Motor oil works fine if the completed engine is only going to sit around a day or three before being installed and started. But dedicated engine shops don't know how long their finished engines will sit around waiting for the rest of the project to be completed. It could be a week or a year. So they use the much, much thicker assembly lube that will stay clinging to the wear surfaces and still give initial startup lubrication.
    For a humorous thought, you could put iRun's and Mendel's behaviors together to see how quickly you could destroy an engine. iRun wants to try never using his ICE, so every time it actually does start, it dumps lots of fuel past the rings and into the oil. And then Mendel's behavior of "well, I'm not putting many miles on, so I can go a year or more between oil changes" would just mean the oil getting more and more contaminated with fuel. I wonder how long that poor engine would last. lol
  19. Gokhan
    6,561
    2,618
    Paramount CA
    Well, if I drive with the engine (in the HEV mode), I make sure that I drive for at least fifteen miles so that the fuel is completely cleared from the oil.
    See, that is the nice thing about the Prius Prime/Prius PHEV. You can completely avoid short trips, which reduce the engine life significantly, by using the BEV mode for short trips. You can’t do that with a Prius HEV. That’s one reason I wouldn’t want to buy an HEV instead of PHEV, the former compounding the problem over an engine-only vehicle by slowing the warm-up for short trips. Moreover, if you make short trips only, then the best choice by far is a BEV.
    #159 Gokhan, Jul 10, 2025
  20. iRun26.2
    824
    169
    United States
    Oh, I definitely will be using the ICE! I drive 150 miles (each way) to visit my parents about once per month (or sometime longer). They live in a small town in central Minnesota and there are no charging stations around. Thus, a pure electric car for me would be a royal pain. My parents are still functional but they are getting pretty old and I never know when something might happen and I need to jump in my car and immediately go see them (hopefully not for the last time). I love that part about the gas engine: I can leave immediately whenever I want to because gas stations are everywhere. You have given me a good reminder, though, that I’m going to have to use the gas engine now and then just to keep it in shape. I never had to worry about that with my 2012 PHEV because I got less than 10 mile on EV and always needed gas both ways on my 21mile trip to work and back. I’m just tickled that now my daily work trip can be gas-less. I can’t tell you how much I yearned for better range on the battery of my 2012 Prius plug-in.
    I hope I don’t ruin my ICE by not using it often enough. I do take other trip where gas will be needed. In the winter I probably won’t have much choice because I expect the battery will demand to be warmed up before it allows me to use it. I actually didn’t park my 2012 in a garage. I’m sure those -20F nights were not good for the traction battery. I remember some trips to work were so cold that my gas engine refused to ever turn off (and I couldn’t and probably shouldn’t have used the EV) I’m sure I’ll see that again.
    Note: That I’m working feverishly on cleaning out our garage so I can now park inside this winter (for the sake of my traction battery). :)
