Are the 17" tires really that much better for Gen 5?
Discussion in 'Gen 5 Prius Main Forum' started by GeoJ, Jun 29, 2025.
  1. PriusTech
    PriusTech Member
    98
    58
    Reno
    The 16" Prius touring wheels weigh 15 lbs. A 17" CT200H wheel weighs 25 lbs.
    All factory wheels have to meet Japanese and USA standards for strength. Besides being weaker magnesium corrodes more easily and if it catches fire in a crash it cannot be extinguished. One fault of the Prius touring wheel is that they corrode at the tire bead area and it causes slow leaks.
    Gokhan likes this.
  2. Gokhan
    Gokhan Senior Member
    5,734
    2,268
    Paramount CA
    Just be happy with what came on your car. LOL Besides, I haven’t seen a single aftermarket wheel that looked good on a Gen 5 Prius yet. Moreover, when people remove their wheel covers, the bare wheels under them also don’t look good. But then, beauty is in the eye of the beholder.
    PriusTech likes this.
  3. Hammersmith
    Hammersmith Senior Member
    2,004
    2,000
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Modallista Wing Dancer XX. Stock OEM 17" size(17x6.5).
    I still might consider them when my original tires wear out in a couple years. The CrossClimate 3 will be coming out in at least 205/55-17, which will do if it doesn't come out in either 195/60-17 or 195/50-19.
    Gokhan likes this.
  4. Gokhan
    5,734
    2,268
    Paramount CA
    Not bad, and kinda like the Gen 5 PHEV wheels!
  5. Hammersmith
    2,004
    2,000
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    They're a dealership option in Japan. Modallista is a Toyota partner. I'm not nearly as big a fan of the 19" Modallista option(WingDancer XIX).
    Gokhan likes this.
  6. Zeromus
    Zeromus Active Member
    509
    269
    Ottawa Canada
    2024 Prius Prime
    SE
    If I wanted to spend the money to put these on for winter, or to let my other rims be for winter with these for summer, I'd grab these. They're nice. But as is, I'm okay with steelies for winter tires, as ice and snow and hidden curbs behind the snow can beat up steelies and I won't shed a single tear.
    GcinFl likes this.
