Build Hybrid Battery Maintenance Gear For Under $100
Discussion in 'Gen 2 Prius Main Forum' started by PriusCamper, Mar 25, 2021.
  1. JON KIRKEGAARD
    JON KIRKEGAARD Junior Member
    Knoxville, Tn
    Will a CBA II load test an data log? Or do I need a new version?
    What is the Ah of a single 8.2V module?
    #161 JON KIRKEGAARD, Jun 16, 2024
  2. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    I don't have a CBA II but from my own research, it should data log if you connect it to PC.
    If you just want to load test a module, all you need is 12v/55w light bulb. Sylvania Xtravision 9003 H4 would work perfectly, especially if you connect two light bulb together = 55w+60w (high beam + low beam) = 115w/8v = 14-16 Amps of current, which is enough to load test a module. The pack of 2 light bulbs at Walmart should be around 20$.
    The initial voltage of a module is 7.2v, there is 6 NiMH cells inside of a module, each cell is 1.2v. The Ah of new module is 6.5Ah, after years of use, it can drop to anywhere from few hundreds to 4000-5000mAh. Hope this helps)
    JON KIRKEGAARD likes this.
  3. JON KIRKEGAARD
    Knoxville, Tn
    Thanks, I've been doing a 50 W load test and trying to record voltage drops every 5 minutes and recording 2 A charge voltages up to 14 V then separating back to the single battery and charging it to 8V at 1.5A. Very long process, and easy to miss the 6 V stop point.
  4. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    So, you are trying to cycles all the modules to regain some capacity by charging and discharging?
  5. JON KIRKEGAARD
    Knoxville, Tn
    Cleaned the nuts bus bars and battery connections with CLR and yes tiring to find any bad batteries and regain some capacity.
  6. StephenJ
    StephenJ Member
    209
    60
    Birmingham, AL
    Four Touring
    Hey guys, since you guys are charger experts you'd know better than me.....Id like to build one of these but it feels a bit over my head. Someone local to me bought a barely used MaxxVolt for $200 used it once and willing to sell it to me for $150. Would there be a substantial difference between the DIY setup versus the MaxxVolt?
    Also, would it be worth it to hold out for a used Prolong and pay more for it?
    Is there a substantial difference in the charging method between DIY, Prolong, MaxxVolt? At the end do they all get the same results?
    Thanks!
  7. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    I wouldn't think so.
    Yup.
    I don't think there is a lot of merit to doing that.
    That sounds like a good deal.
    The difference would be your capabilities verses having a turnkey solution ready to go. You're talking about $50 for that advantage.
    StephenJ likes this.
  8. StephenJ
    StephenJ Member
    209
    60
    Birmingham, AL
    Four Touring
    Thanks for that info! Sorry it took me so long to get back, we've been helping my daughter move. Do you know if there's a difference between the dischargers from MaxxVolt/Prolong versus just the two light bulb method? Their dischargers are expensive so surely they do something like drain in some kind of way that helps the battery?? I guess do they run the fan while discharging?
  9. dolj
    dolj Senior Member
    8,209
    4,180
    That's no problem, sometimes life happens!
    I can't offer any advice/knowledge about either discharger as I use light bulbs. I don't think they do anything special or magical. They do, however, allow the process to run unsupervised and keep everything within the correct parameters of current and voltage cutoff – and they do run the fan. Although, using low current (as I do – 2000 mA down to 250 mA), it shouldn't cause any heat-related issues.
    I hope that helps some.
  10. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Hey man, I have a Maxx Volts Grid Charger and as a discharger i use two lightbulbs connected together. The Prolong discharger is a good one because you don't need to babysit a battery during the entire discharge process, but if you have a limited budget you can build one for $30-$40 bucks.
  11. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    The cheapest way to do a discharger is to go to Dollar Tree, buy 2 Night Light (for $3.25 or so) connect one wire from one light to another wire from the other light (see the picture) now either way you can do what I did or connect the end of the wire straight to the battery. What i did instead of connecting them straight to the battery is, I connected them to the end of a plug (you can use the same that you cut off earlier), I got a cheapest extension cord from Home Depot cut the end of it and then connected an O-ring terminals to it. Now I can connect ring terminals to the battery, put a plug into extension cord and that's works well for me. You would also need 2 x 200 watt incandescent light bulbs and 2 x 25 watt incandescent light bulbs (about 20$ in Home Depot), you can try and look for 75's but I didn't find them. Also I recommend watching some videos before doing all of this, just for the sake of safety.
  12. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Here some more pictures.
    P. S. Remember this is high voltage, be extra careful especially if this is your first time working on something like this.
  13. Fury6z
    Fury6z New Member
    Paris
    Hi guys,
    I am from France and we have 230v instead 120v like the US is that okay ?
    Thanks...
  14. PriusCamper
    PriusCamper Senior Member
    12,053
    4,893
    Pacific Northwest, USA
    The Meanwell or similar low amp high voltage DC device bought in your country or online for your country will have 230V AC input compatibility.
  15. Fury6z
    Fury6z New Member
    Paris
    Hi I am from France and I saw you are from Europe to. I was wondering if you can give any update of your charger ?
  16. Fury6z
    Fury6z New Member
    Paris
    Thank you for your reply :)
  17. A.J
    A.J Junior Member
    Worldwide
    I bought the adjustable DC charger KUAIQU SPPS-D3001-232 (0~300v, 0~1A) for charging the battery and 90980-12474 4P wire connector harness plug too to hook up with a 12v charger for the fan.
    Haven't tested yet though.
    #177 A.J, Jul 11, 2025 at 1:15 AM
  18. PriusCamper
    12,053
    4,893
    Wow! That device is only $67 and can be used for so many different things beyond a charge and balance for NiMH... What you did pretty much makes this thread obsolete. I think I'll ask moderator to close this thread so it end with pointing to Jack's link and your link: https://www.aliexpress.us/item/3256806709273120.htm
