Thermostat Question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MSB87, Jul 11, 2025.
  1. MSB87
    MSB87 Junior Member
    40
    Phoenix
    To cut to the chase...do the thermostats function like all the others I know of? Full open or full closed are the only two possibilities or is there now a partial open function? TIA!
  2. BiomedO1
    3,436
    1,790
    SacTown, Ca
    The thermostat operates on a termanally sensitive spring. It softens when it warms up; allowing fluid pressure on the other side to pass as it gets up to the designated temperature. Any contaminants or rust can impair it's operations. (ie. get it stuck closed, open, or partially open)
    Hope this help
    MSB87 likes this.
  3. ChapmanF
    18,022
    If you're talking about the one in the hose elbow down by the water pump, I think it functions like all the others I know of. A spring holds it closed, and a pellet of wax trapped in a cylinder expands with heat and pushes it open. It's a slowish effect, nothing sudden about it. The thermostat starts to lift a bit above 80 ℃, definitely opening by 85 ℃. It should be fully open (10 to 14 mm lift) by 95 ℃.
    House thermostats on the wall, now those frequently are just on / off (though even that has been changing in these modern days of variable-rate furnaces, A/Cs, and heat pumps),
    #3 ChapmanF, Jul 11, 2025
    MSB87 and Brian1954 like this.
  4. MSB87
    MSB87 Junior Member
    40
    Phoenix
    Car has 152,000 miles. Yep, looking at the engine t-stat.
    I was headed to Denver when I got the dreaded coolant dummy light that turns off quickly on a long steep climb out of Phx on a very hot day. I usually push the engine to the pwr section during these climbs but after that I backed off and crawled up with the slower vehicles. Everything was fine until the final long steady climb on I-70 right before the descent into the Denver area and then it came on again and did its thing so I backed off and made sure to stay out of the pwr range.
    Did some research and changed the water pump in Denver. Drove all around the Denver area for a week without issue. Drove home via I-25 and I-40 route at 80 mph with no issues until the final climb into the Flagstaff area on I-40 which is not steep but long and constant. Same thing, light on/off so I again went to staying out of the pwr area. Did the same thing and crawled up the last but very steep climb on I-17 out of Camp Verde and never saw the light.
    So now that I am home and have all my tools available it is time to figure it out. I just purchased a reader and used it all day yesterday and the temps never got above 195 F. (On a side note the strange thing was that on the first trip it gave me the water pump rpm stats but nothing since. I've read that it normally doesn't read the rpm.) So now I'm thinking the thermostat may not be opening fully since it seems that it only happens in extreme engine use and what I can only assume is the upper temps of the t-stat range.
  5. ChapmanF
    18,022
    That's a weird part of your story. What reader did you buy? The car's ECM will answer the pump-RPM question any time the reader asks.
    The easy test for that is to take the stat out and suspend it in a pot of water on a stove with a suitable thermometer, and heat the water up. You are looking for noticeable opening between 80 and 84 ℃, fully open (10 to 14 mm lift) by 95 ℃, just as in the picture.
    If it doesn't do that, replace it. If it does do that, your problem is something else. (This is a better approach than just saying "I'll replace the stat and see if that fixes it", because then if it doesn't recur right away (say, the conditions are somehow different on your next climb) you can go around for a while with a false sense of having fixed it, and then later see that you still have some other problem.)
    Other problems could be restricted coolant flow, restricted airflow through the radiator (lots of bent-over fins or trapped debris). Check the operation of both radiator fans; they shouldn't be needed much when the car's in motion, but they should definitely both be running at HI speed well before that light comes on.
    If the coolant ever went unchanged a really long time, there could be corrosion products in the passageways reducing flow. If a stop-leak product was ever put in, passages could be gunked up with that.
    It would definitely be nice to get a continuous scan-tool display of temperature and pump RPM.
    Brian1954, MSB87 and BiomedO1 like this.
  6. BiomedO1
    3,436
    1,790
    SacTown, Ca
    Yep; at a minimum I'd install a continuous ECT monitor, to keep you out of the danger zone and avoid blowing a head-gasket; while trying to figure this out.
    MSB87 likes this.
  7. Mendel Leisk
    41,256
    It's common for third gen water pumps to fail around 150k miles. It's prudent to change the pump and thermostat, say every 100k.
    Ever cleaned the EGR system?
    m.wynn and Tommgb like this.
  8. MSB87
    MSB87 Junior Member
    40
    Phoenix
    Not the cooler and valve. Just did the tube and as far as possible on the intake and EGR side. On my list and the timing of it will depend on what I see on the scanner.
  9. Brian1954
    Brian1954 Senior Member
    2,131
    825
    South Central PA, USA
    Did you save the old water pump? Did you inspect the impeller on the pump and did it spin easily?
    The new pump that you installed. Was it Toyota OEM, or was it an aftermarket pump?
  10. MSB87
    MSB87 Junior Member
    40
    Phoenix
    Verified those when I put the pump in. Coolant looked good coming out. I changed it and the inverter coolant when we bought the car used from the dealer even though they said they did it. I can't remember how many miles but my best guess in the moment is that it was due (100,000) over minimally overdue.
    The car has a lot of highway miles as we did a biannual trip from Phx to PNW every year for 4 years. And now multiple trips to Denver over the last two years.
  11. MSB87
    MSB87 Junior Member
    40
    Phoenix
    I'm using Car Scanner Pro (paid version) and Veepeak scanner
  12. rjparker
    10,054
    6,221
    Was the new water pump oem Toyota? Lots of aftermarket units are suspect.
    No head gasket sealer in your ownership? Radiators do get compromised with sealer.
    Use your Car Scanner to display both coolant temps so you know if both agree or one is high causing the alert.
    The 7C0 thermistor is monitoring the output of the exhaust heat system, which is only in full use during warmup. It also has a mechanical thermostat which allows exhaust to bypass the exhaust heat system's heat exchanger. I have heard of one case where that mechanism failed causing too much heat to 7C0. It's not clear to me that would actually overheat the engine since it's a small flow which is always picking up some heat from the exhaust no matter what.
    It does not take a mountain climb to raise the temperature as a test. Just find a half mile steep hill (the kind with the high grade warning sign), usually in a rural neighborhood, and drive it aggressively with max ac. It should not exceed 205f with a good cooling system.
    The most common problem is an aftermarket water pump replacing a failing oem pump.
    memory and Brian1954 like this.
  13. MSB87
    MSB87 Junior Member
    40
    Phoenix
    I did spin it and it was not as easy as the new OEM one but I wouldn't say that it was jammed or really hard to spin. The first drive with the scanner showed the rpm as slightly higher than the request value. Now the only value I get is the WP duty @65%
  14. MSB87
    MSB87 Junior Member
    40
    Phoenix
    Lots of good stuff there! It is OEM from Toyota. I about dropped my phone when they told me the price! No sealer since I've owned it. I will be testing it on some kind of hill, not many in Phx meet the requirements.
  15. rjparker
    10,054
    6,221
    In Car Scanner that value is for the inverter water pump.
  16. MSB87
    MSB87 Junior Member
    40
    Phoenix
    Any thoughts on why Car Scanner isn't showing the WP rpm after it showed it on my first trip? I was thinking of deleting the car from the app and unplugging the reader to see if that fixes it.
  17. ChapmanF
    18,022
    Now that rjparker mentions it, I think I remember some discussion around here about whether Car Scanner even has the PIDs for the engine water pump target and actual RPM, or only those for the inverter water pump.
    MSB87 likes this.
  18. MSB87
    MSB87 Junior Member
    40
    Phoenix
    Pretty much what I am finding is that Car Scanner does not have it but I swear I saw the data on the first drive but maybe it was the Inverter. Regardless...it has not shown it since!
    @ChapmanF @rjparker - Chapman I read through a thread where you tested the ICE shut down upon overheating. You had mentioned the sensor that sends the signal to light up the coolant light on the dash. Do either of you know what sensors cause that light to come on? I've been monitoring both of the sensors that rjparker mentioned and they are usually close but the 7co rises faster and higher than the engine 7e2. No dash light on this drive. Ambient temp was 106-108, although not a "hill" elevation was increasing going due south to north in Phx, cruising speed mostly but you can see the increases during merging and/or more ICE effort. I just don't know what would be "normal" for the 7co data. The trends for both are pretty darn close. I appreciate all the time you have spent helping me with this.
  19. Brian1954
    2,131
    825
    Both of the temperature sensors that you are now monitoring can turn on the high temperature warning light on the dashboard.
    MSB87 likes this.
  20. ChapmanF
    18,022
    The light is built into the combination meter. The 7C0 exhaust heat recovery system sensor is wired straight to the combination meter, which directly turns the light on at 248 ℉ (120 ℃).
    The 7E2 cylinder head outlet sensor is wired to the ECM. The ECM and the combination meter are connected over a communication network, and messages pass over the network to turn the same light on when this sensor reads too hot. I assume "too hot" is probably also 248 ℉ (120 ℃) for this one also, but I have never gone out and tested that like I did for the EHRS sensor, so for all I really know it could come on at some other temperature for that one.
    MSB87 likes this.
