Wrapping stock intake with tinfoil bubble and then heat resistant wrap?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by h1ph0panonymous, Jul 11, 2025.
  1. ChapmanF
    18,096
    Ah, perfect. You've got a link, right?
    Brian1954 likes this.
  2. frodoz737
    frodoz737 Top Wrench
    4,693
    2,493
    33
    Your project, your call. You're not done yet?
    As to you next post...I do this for a living and because I love what I do. All we are hearing from you is talk.
  3. Brian1954
    Brian1954 Senior Member
    2,165
    843
    South Central PA, USA
    Well I learned something today. This morning I hooked up Techstream to my 2011 Prius which has the latest ECM firmware. The car had been sitting all night so the coolant temperature was 81F and the ambient temperature was the same. I started the car and watched the coolant temperature and engine water pump speed. As soon as the engine started, the water pump turned on to about 2600 rpm. When the coolant temperature got to 104F, the engine shut down and the water pump continued running for ~13 seconds and then shut off. I would like to note that the heat and fan were tuned off. This was exactly like rjparker described.
    I used the car to run an errand and came home. I connected Techstream again to see how the water pump behaved when the coolant was between 185F and 190F while sitting in my driveway. The water pump behaved the same at those coolant temperatures. I could not get the engine coolant higher then 190F while sitting in my driveway. When the engine was not running and the water pump was off, I then turned the heat to maximum (HI) and turned on the fan. As soon as the fan turned on, the water pump also turned on. When I turning the fan off, the water pump immediately turned off.
    This may have been common knowledge by some in this forum, but it is new information to me. I have been reading the Gen 3 forum for the last 5 years and do not remember see this previously. I should note that my memory is getting worse as I age, just like most people.
    Thank you rjparker for the information about the engine water pump behavior. This thread has now become more then entertainment for me. It has also become informative.
  4. h1ph0panonymous
    258
    36
  5. frodoz737
    4,693
    2,493
    33
    Shouldn't you be turning wrenches?
  6. h1ph0panonymous
    258
    36
    Haven’t bought the material yet.
  7. rjparker
    10,101
    6,266
    My v water pump shuts off immediately with the engine until full warmup. Then the short delay. I am sure it helps mpg but is likely to cause cylinder hot soaking. It's something I noticed maybe ten years ago when I observed significant thermal cycling of the engine when not moving but still in Ready.
    Using throttle to run engine in Ready
    Which was the reason to start realtime coolant monitoring with a 210f alarm.
    No tin foil but frequent coolant changes.
    #107 rjparker, Jul 12, 2025
    h1ph0panonymous likes this.
  8. ChapmanF
    18,096
    Great, thanks for linking to a thread I'm sort of familiar with.
    Can you be specific about what in that thread you are basing "1800-2200 RPM is it’s sweet spot. Just enough intake suction to keep it at 188 degrees" on?
  9. h1ph0panonymous
    258
    36
    Based on the posters exact experience that matches mine.
    This post that we are in right now is about how to get that 188 to 186 or 184 degrees during 1800-2200 RPM driving methods. (Babying it)
    My idea is to wrap intake and other areas with an insulating material (tinfoil/aluminum bubble wrap) and then gold wrap over that to create an insulating and isolating barrier between the radiating thermal energy from engine. One could say well all of that is still trapped inside the engine bay so its black body radiation will equalize the whole and all of its parts of the engine bay to the same temperature but the intake isn’t generating heat itself, when the air it picks up is cooler than the engine, the insulating material will start to cool down creating a mini cold soak of the intake.
  10. ChapmanF
    18,096
    Which poster? This shouldn't be hard. Asked for a link, you linked to a thread. So the post you're talking about ought to be somewhere in that thread, right?
  11. h1ph0panonymous
    258
    36
    The person who posted it LOL all you have to say after that?
  12. frodoz737
    4,693
    2,493
    33
    So...this day is just about over now. Are you done with the mod yet?
  13. ChapmanF
    18,096
    Can somebody else take a look? h1ph0panonymous made this claim:
    and was asked just where "in these forums" that was "brought up", and replied by linking this thread:
    That's a short, one-page thread, 19 posts, so I read it through and asked h1ph0panonymous to identify any post in that thread that could be the origin of that claim.
    That's produced neat non-response responses from h1ph0panonymous like "Based on the posters exact experience that matches mine." and "The person who posted it LOL"—all without locating any such post.
    Anybody else see such a post there that I'm somehow missing?
  14. h1ph0panonymous
    258
    36
    The “poster” means the person who posted the post. Do you not see his inquiry based on his Gen 2 driving methods? Even the graphs you commented with are not much different than the Gen 2.
  15. ChapmanF
    18,096
    Please either:
    (1) identify the post that supports your claim (each post on PriusChat is directly linkable, this is easy), or
    (2) wait for someone else to see whether I have missed such a post, or whether I'm right that you're blowing smoke.
  16. Brian1954
    2,165
    843
    Yes, the person who made the post. Or just tell us what the post number is. The thread starts with post #1 and increments up to the last post, which is post #19. Just say what the post number is that you are referring to.
  17. Brian1954
    2,165
    843
    I will answer this for the OP.
  18. h1ph0panonymous
    258
    36
    Naw you don’t get to play the role of pedant and then play ignorant.
  19. ChapmanF
    18,096
    Well, there are only 19 posts in that thread. so maybe someone else will find there's one in there that supports your claim and you haven't made it up. I do miss things now and then.
    Of course this is, just to keep track, your fifth time in a row dodging simple requests to just say which post.
  20. Hayslayer
    Hayslayer Active Member
    390
    219
    This alone makes most people not pay attention to anything else you write......
    but..the great thing about the forum is .....it's your story, make it as crazy as you wish........
