Now I get my wheel back .... brake issue.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ccna101, Jul 12, 2025.
  1. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    So the gen2 was away with college kid for few year: ABS aftermarket been replace (1-2 years) ..
    On my long drive back from TX the brake make alot of noise during stop and go, but it going smooth during freeway speed ( not step on brake).
    So I make it home, start manual bleed by step on the brake and bleed FL,FR, RR all dirty/air fluid coming out.
    RL is nothing coming out ... the solenoid valve do make noise, but no fluid...
    Is there a detail process to utilize TS to turn on/off the valve for RL troubleshooting ? the last thing I do is kill the ABS (again).
    TIA,
  2. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    So stick in TS and run ECU procedure ... clean up all noise and bleed RL ok .
    Now the display pop up VSC and ABS, code show C1345 and C1368...
    I known we replace the ABS with used one couple year ago... darn .
  3. PriusCamper
    PriusCamper Senior Member
    12,668
    5,111
    Pacific Northwest, USA
    Can you give lots more details on what the noise was like?
    Also is your fluid level showing normal?
    If you thoroughly examine the entire brake line for RL and find no damage then perhaps you can find a way to actuate the RL brake in the opposite direct to see if it increases the amount of fluid in the reservoir? Doing this with disc brakes is fairly easy, though not sure its possible with Gen2 drum brakes... But what I'm getting at is were is the brake fluid being stopped?
    The kid in me who took auto shop in the 1980's is saying the problem with drum brakes is always bad wheel cylinders and you have to replace them before they start leaking but this is 40 years later and your problem is the opposite and I've never read of clogged wheel cylinders in Prius, or whatever they call that particular part these days.
    ccna101 likes this.
  4. ChapmanF
    18,035
    Is the situation now that everything bled ok, but you have the C1345 code saying to run the linear solenoid learning procedure? That would be the next step then.
    Or have you already tried that, but C1345 and C1368 came back anyway?
  5. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    Thanks Chapman...
    No: the above after I reset memory, then 3 step in ECU/ABS funtion.
    I also perform Test and learn the Yoln rate (?) ...
    After all successful completions, still display acclamation and ABS light (yellow)..
    Code now had C1248 in addition to the other 2 codes ..
    I dont think we replace with a decent ABS unit ...
  6. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    So just to narrow down a failed process and not shootgun any decision ...
    1. Reset memory done with no issue.
    2. ) Perform the zero point calibration of yaw rate and acceleration sensor seem complete with no error.
    3. Linear offset seem to fail (120 secs duration) : the initial -acclaimation- and ABS flash at difference rate .. brake warning (yellow acclaim) slow at 2 blinks/sec while the ABS flash at 4 blinks /secs. . At the end of 60 secs countdown, It failed and display solid , we are expecting both blinked fast at 4 blinks/sec or so.
    So definitely, my initializing and calibrating the linear solenoid valve not working somewhere .
    I will try to disconnect the battery for 30 mins to help reset the ABS control module ... and retry the process tomorrow .
  7. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    So this is the TS codes, and zoom in detail ...
  8. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
  9. dolj
    dolj Senior Member
    8,413
    4,282
    Wellington, New Zealand
    You likely don't need a new 12 V battery; just keep a charger that can supply 6 to 10 Amps on it while you do the various procedures.
    I skimmed through that linked thread and don't see where you would come to the conclusion that you need a new battery. But each to their own.
    ccna101 and Brian1954 like this.
  10. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    No, my # 8 respond to the battery trick : remove the 12V battery for 30 minutes in hope to clear up the ABS before I can try to perform linear offset code failed (C1345)...
  11. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    So this is how it is...
    ABS made squeaky loud sound during trip return to town, less during travel 70mph down I-40. No ABS light, all clean.
    Cross AZ at 115F and yellow light for tire ... I pull off and check, all tires are good, continue.
    Once I am home: pull all tire off and start manual fluid brake change, start with RR then FL... then RL (issue-no drain) .. I stop here.
    I pop in TS (v17) and start under ECU/ABS : 1. clear memory, 2. Linear offset ...this is where it was NOT completed and failed. ABS and Warning Brake,plus Red Brake light are on... I can heard the ABS chatter at every 20 seconds or so after an engine ON - even with or without applying the brake.
    I can complete the manual bleed on all 4 sides now.
    Code C1345, C1368 on TS.
    I been pull the 12V battery off (+30 min) in hope of clearing / able to relearn the linear offset ... no luck.
    From the chart, it seem my RL wheel cylender are high, which is consistent of the -stuck- on fluild ? coincident ?
    I will pull all ABS wheel sensors and inpect now , just for kick of it ...
    --- I am running out of idea other than the ABS is not hold presure , and spit out codes.
    I am looking at a used unit in couple days .... darn .
  12. dolj
    dolj Senior Member
    8,413
    4,282
    It would be interesting to note what the 12 V battery voltages were doing in real time as you attempted to do the linear offset relearning.
    Is there any chance you have monitored that and not mentioned it?
    ccna101 likes this.
  13. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    I did not keep 12V monitoring ( too many thing to watch ! LOL) , since I use my portable booster charge during test, and manual bleed.
    On the snapshoot (above) ... it did collect and printout Voltage of difference stuffs ... you would think they spell out the battery voltage somewhere ... I could be wrong .
    I am looking into TS linear offset troubleshooting ...
    #13 ccna101, Jul 16, 2025
  14. rjparker
    10,061
    6,229
    Number one issue
    Odds are good you need a new one this time.
  15. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    Ya, but for a 4-7 thousands buck car with the risk of hyb. battery and, many other ...I dont think I have the justification for new investment.
    Used again: for sure... the "new" one from CN are at 700 bucks + but I think they do it to avoid tariff ... don't think I am ready .
    EV-
  16. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    Pick up a unit @ pick-n-pull... will start the ez work tomorrrow.:)
  17. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    Done ...total time for replaced about 3.5 to 4 hrs... not bad of a task once you review all the cheatsheet and youtube... thanks the internet and PC.
    Now: I need to manual bleed the ABS system before turn power on ( READY mode) ... Can I bleed all 4 brakes via manual ( clamp push on brake) ??? I think there also a linear offset solenoid technique via OBD2 pin ? ...
    I will not turn it on until I am at least flush to the brake system ...
    TIA, EV
  18. ChapmanF
    18,035
    Linear solenoid offset relearn does have a no-scan-tool alternate method involving a jumper at the OBD-II socket.
    Bleeding does not. Scan-tool-only, especially the longer bleeding procedure needed when the underhood components have been replaced. Scan tool doesn't have to be Techstream; there are other tools that can do it. Autel AP200 is one, for example.
    ccna101 likes this.
  19. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    Darn ... my TS just acting badly - the cheap Xhorse obd2 is not getting me into utility -> no air-bleed ... the freaking thing do work just few day ago so I do know my software /laptop work ...
    I am order an VCX nano .. it coming next week ...will have to wait then.
    TIA for a quick reply and confirm what I found / read ..
    EV-
  20. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    FYI ... i got the new VCX and TS 18 working : turn out that I have a blown fuse (#8 -7.5A) that cause the obd2 not to talk with anyone !!!
    So ECU/ABS-> Utility -> Offset ... bingo ! all clear ...no C1345,C1368 ... !!! yah00000!!!
    Gen 2 do give you a feast ! but now ya know ...
    EV-
    Brian1954 and Danno5060 like this.
