14 C4 current codes, help please
Discussion in 'Prius c Technical Discussion' started by Adventurer2112, Jul 10, 2025.
  1. Adventurer2112
    Adventurer2112 Junior Member
    55
    Urbana
    2014 Prius c
    Hi 2014 C level4 175,000 miles.
    I replaced MAF sensor.
    I replugged orange plug under rear seat.
    Thanks Brian.
    Car goes into ready, ice starts, car moves.
    These are now the current obd2 codes per Techstream ver 17.
    Current codes p0101 MAF circuit low,
    P0101D a/f sensor heater circuit performance bank1 sensor 1 stuck on
    P2118 throttle actuator control motor current range / performance
    P261C engine coolant pump B control circuit low
    U0293 Lost communication with hybrid vehicle control.
    How do I clear these DTc please?
    TIA
    Jack tickled she was running.
  2. Brian1954
    Brian1954 Senior Member
    2,351
    948
    South Central PA, USA
    Please post a screenshot of Techstream showing Health Check and the trouble codes detected.
  3. Adventurer2112
    55
    Urbana
    2014 Prius c
    Also C1231 steering angle sensor circuit
    C1311 open circuit in main relay 1
    C1345 Linear solenoid valve offset learning undone
    U0293 lost communication with hybrid vehicle control/ev control system.
    going to recharge 12v aux battery overnight.
    Jack
    Brian1954 likes this.
  4. Adventurer2112
    55
    Urbana
    2014 Prius c
    Hi Brian,
    That’s where I’m
    Getting these DTC.
  5. Adventurer2112
    55
    Urbana
    2014 Prius c
    Posted
  6. Brian1954
    2,351
    948
    You need to be concerned with the four current trouble codes that you listed in post #3. You do not need to worry about any of the history trouble codes.
    Charge the 12v battery tonight and run a new Health Check tomorrow. Include another picture showing the trouble codes (take a picture that shows the complete computer screen).
    Has any work been bone on the brake system since you owned the car?
    #6 Brian1954, Jul 10, 2025
  7. Adventurer2112
    55
    Urbana
    2014 Prius c
    Changed rear brake shoes.
    That’s it.
  8. Adventurer2112
    55
    Urbana
    2014 Prius c
    Hi All,
    Current conditions see. I don’t know how to clear them.
  9. Leadfoot J. McCoalroller
    8,123
    7,619
    Pennsylvania
    2018 Prius c
  10. Adventurer2112
    55
    Urbana
    2014 Prius c
    Just bought a months access.
  11. Leadfoot J. McCoalroller
    8,123
    7,619
    Pennsylvania
    2018 Prius c
    Cool, good luck!
    With the c model not having a lot of problems to begin with and most owners using dealer service options, there isn't a lot of community knowledge going around.
    I hope the documentation leads you to a swift cure, and maybe think about sharing the story after?
  12. Adventurer2112
    55
    Urbana
    2014 Prius c
    if when I find the solutions I will share. jack
  13. Adventurer2112
    55
    Urbana
    2014 Prius c
    Hi All,
    Reading all data. Going to attempt
    Linear solenoid valve init. & calibration to clear the code.
