Squeaking noise from engine on stage 1a
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Abarnabe, Jul 13, 2025 at 7:11 AM.
  1. Abarnabe
    Abarnabe Member
    151
    91
    Netherlands
    I recently noticed a squeaking noise coming from the passenger side of the engine bay on stage 1a, while transitioning to 1b I can't hear it anymore.
    I can't reproduce the sound in inspection mode.
    I thought it could be the engine coolant pump, but I turned it on with engine off with techstream, and there is no squeaking, so I would rule it out.
    The car has 310k KM.
    Transmission oil changed every 90k Km
    Virtually no engine oil consumption.
    No DTC codes.
    What could it be?
    #1 Abarnabe, Jul 13, 2025 at 7:11 AM
  2. Brian1954
    Brian1954 Senior Member
    1,813
    717
    South Central PA, USA
    Does the seaking sound occur when the car is stationary or when the car is being driven on the road?
  3. Abarnabe
    Abarnabe Member
    151
    91
    Netherlands
    it occurs when the car is stationary
