Squeaking noise from engine on stage 1a
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Abarnabe, Jul 13, 2025 at 7:11 AM.
  1. Abarnabe
    Abarnabe Member
    154
    91
    Netherlands
    I've recently noticed a squeaking noise coming from the driver / transmission side of the engine bay on stage 1a, after transitioning to 1b I can't hear it anymore.
    I can't reproduce the sound in inspection mode.
    I thought it could be the engine coolant pump, but I turned it on with engine off with techstream, and there is no squeaking, so I would rule it out.
    The car has 310k KM.
    Transmission oil changed every 90k Km
    Virtually no engine oil consumption.
    No DTC codes.
    What could it be?
    #1 Abarnabe, Jul 13, 2025 at 7:11 AM
  2. Brian1954
    Brian1954 Senior Member
    1,813
    718
    South Central PA, USA
    Does the squeaking sound occur when the car is stationary or when the car is being driven on the road?
    #2 Brian1954, Jul 13, 2025 at 9:18 AM
  3. Abarnabe
    Abarnabe Member
    154
    91
    Netherlands
    it occurs when the car is stationary
  4. Abarnabe
    Abarnabe Member
    154
    91
    Netherlands
  5. Abarnabe
    Abarnabe Member
    154
    91
    Netherlands
    If I understand well in S1a MG1 and MG2 are not turning, the only thing spinning is the ice and torque limiter ( the clutch on the flywheel ).
    My theory is that the coil springs on the clutch developed some play and squeak, since they have no lubrication and they absorb the infamous startup shudders caused by shut off while the ice is still charging the hv battery.
    I can confirm the squeaking stops as soon as the ice is under load i.e. charging the hv battery
    #5 Abarnabe, Jul 14, 2025 at 3:38 AM
  6. ASRDogman
    ASRDogman Senior Member
    7,241
    3,780
    I don't hear a squeak. I hear rattling.
    Check all connections/brackets, perhaps a clip holding a line broke.
    Maybe a motor mount is broken, or the heat shield rusted out?
    The shocks/struts don't squeak when the car is not moving.....
    Abarnabe likes this.
  7. Abarnabe
    Abarnabe Member
    154
    91
    Netherlands
    i
    I also thought about the heat shields, I mended them a week ago, but the sound persits, it' s really high pitched, like the sound of worn drill trying to perforate some hard metal, but quite hard to hear, and I think it comes from the flywheel location.
    When MG1 engages at S1b the noise stops, it' s like it absorbs the vibration.,
    I was tempted to spray some wd40 on the flywheel springs if they can be reached from the plastic cover , but what if the cutch starts slipping?
    Here are some pictures of the mended heat shields.
    #7 Abarnabe, Jul 14, 2025 at 10:09 AM
