Thermostat Question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MSB87, Jul 11, 2025.
  1. MSB87
    MSB87 Junior Member
    40
    Phoenix
    Would it be logical to make the assumption that when my light came and went that it wasn't the EHRS sensor causing it since your test caused a shutdown of the ICE? Mine never shut down, I immediately took the foot of the accel. and the light immediately went off; which may or may not have been just a coincidence.
  2. ChapmanF
    18,418
    No, if you read my posts in that thread carefully, you will see that the only automatic engine shutdown that is mentioned in the manual, and the only one I tested and confirmed, is that at a significantly lower temperature, 221 ℉ (105 ℃), the ECM will shut down the engine if there is a current active water pump trouble code.
    When there is no current water pump trouble code, of course the temperature can rise right past 221 ℉ (105 ℃) with nothing special happening, and later at 248 ℉ (120 ℃) the warning light comes on, and the manual doesn't say anything about any automatic shutdown for that, and I've never tested for one either.
  3. BiomedO1
    3,968
    2,091
    SacTown, Ca
    You may have some sort of flow restriction within the 7CO coolant pathway loop or there's corrosion, wire, or connection damage on that sensor. Those sensors are variable resistance temperature sensors; so oil or any contaminate in the connector will change it's reported value.
    Hope this helps.....
  4. MSB87
    MSB87 Junior Member
    40
    Phoenix
    Yep, sorry, forgot about that parameter. Is there any other sensor that can set off the coolant light that I should be monitoring or is it just those two?
  5. ChapmanF
    18,418
    No other that I know of, but I'm not claiming to know everything.
  6. rjparker
    10,374
    6,493
    The Car Scanner app developer is routinely changing the custom "connection profiles" that decode manufacturer specific points. He had an update about three days ago and the water pump rpms don't work even though the points are there. I sent the developer an email yesterday. The problem is he configures this app for almost all cars so I don't know how he can properly test changes.
    I would expect the exhaust heat recirc sensor 7CO to be slightly hotter since its source of coolant is the output of the engine. So it starts with coolant at engine temp and heats it more until a separate thermostat bypasses the exhaust. This flow is small compared to the larger engine to radiator flow and is further split between the egr cooler and the exhaust heat recirc system. I suspect the warmed up secondary flow heat increase is negated by the egr cooler. I normally find both sensors to be within a few degrees of each other when both mechanical thermostats have operated, eg at full operating temperature.
    Part of the problem with visualizing these flows is Toyota does not have an official flow diagram for gen3. There are sketches from the gen4 to gen3 engine experiments but each ends up being a compromise solution for those engine swaps.
    As noted earlier, the exhaust recirc thermostat could be stuck in the heat exchanger position adding unnecessary heat after warmup. This was reported at least once. The engine temp could be fine but the exhaust heat exchanger sensor could trigger the light.
    Testing the thermistors is as simple as verifying their readings after an overnight cooldown. They should read within a few degrees of the car's outside ambient temp as displayed on the ac controls. The connections are unlikely as it takes 40 or more ohms resistance to change ten degrees in most temperature ranges.
    Your engine sensor is well within normal but you may not be monitoring at high engine load. Outside temperatures have little impact with a normal cooling system. But reduced cooling capacity is always possible as noted in Chapman's earlier post. If it's reduced cooling capacity I would expect the engine sensor to rise significantly above 204f under high load and be slow to recover.
    I don't have access to the v today, it's on its daily 90 mile round trip commute. But when I do I will warm it up and test the exhaust heat recirc sensor vs engine sensor on a high slope hill.
    Brian1954 likes this.
  7. ChapmanF
    18,418
    The flow is from the output of the engine, through the cabin heater, then splitting off between the EHRS and the EGR cooler. So, during heating season, it will have given up heat to the cabin and will be coming in cooler than at the engine outlet (which is desirable, to increase the rate of heat exchange into the coolant from both the EHRS and the EGR cooler). During cooling season, of course, the cabin air mix will all bypass the heater core, and the coolant should be coming out still close to the engine outlet temperature.
    I'm not sure what you meant there, but the direction of heat exchange is from the exhaust gas into the coolant, in both the EHRS and the EGR cooler. In one case the purpose is to raise the coolant temperature, and in the other the purpose is to lower the EGR gas temperature, but the effect of both is that the coolant temperature goes up.
  8. MSB87
    MSB87 Junior Member
    40
    Phoenix
    @rjparker @ChapmanF @BiomedO1
    You all are amazing, thank you! I will take a look at the prestart temps tomorrow morning. I always see them and they are the same but I never compared them to ambient, just assumed that they were the same. Load test coming. The flow info was great and I had figured the EHRS would be higher due its function. I will leave it here until I can get the load test drive done. Hank you again!
  9. rjparker
    10,374
    6,493
    Your two temps with the Exhaust Heat Coolant Temp 7C0 exceeding normal Engine Temp
    Same two on my v with full ac and periods of steep grades. Note Exhaust Heat Temps essentially at or below Engine Temp. Engine temp briefly reaches 204f under load. IMG_8918.jpeg
    Time ~8 minutes per horz x axis interval
    Detail of Engine Heat Recirc System
    I also verified with Techstream the 7C0 Car Scanner point comes from the Combination meter.
    Might be time to check the Exhaust Heat Recirc System especially if the Engine sensor never significantly exceeds 204f.
    #29 rjparker, Jul 14, 2025
    Brian1954 and MSB87 like this.
  10. MSB87
    MSB87 Junior Member
    40
    Phoenix
    TLDR; Replacement of exhaust heat exchange components coming up in near future. Will update after.
    Didn't want you all to think that I've just left for good. Been very busy and out of town these last couple of weeks. Now that I'm back I've ordered all the parts (stopper, actuator/therm, gasket and the casing. Once they are here the work will be performed when possible and I will update everyone. We have been driving it locally with no issues and as long as we stay out of the power range for extended amounts of time the temp rarely goes above 200F at the exhaust sensor but it is still usually higher than the engine sensor. It also cools to at or below engine sensor temp when stopped at a light. If the new parts don't fix it then I will conclude that it is internal with the valve and I will bypass it until we move to a colder climate or decide to have the exhaust section replaced.
  11. MSB87
    MSB87 Junior Member
    40
    Phoenix
    EHRS parts were replaced about a week ago. It has definitely made a difference to the temps. The EHRS temp is almost always under the engine coolant temps. When the EHRS does go higher it is under heavy load, maxes at 203. The engine coolant temp starts to increase to about 196 and then the EHRS temp falls to within a degree or two. As soon as the load is decreased to "normal" both fall back to 186. The slopes of both graphs are almost identical. Thanks everyone for the help with this!
    memory, rjparker and Brian1954 like this.
  12. memory
    memory Junior Member
    17
    Poland
    Witam, proszę za dziesięć postów, prawdopodobnie mam problem z systemem EHRS, proszę powiedz mi, aplikacja do pomiaru temperatury silnika i czujnika recyrkulacji ciepła płynu chłodzącego pid 7C0 .
    Krótko mówiąc, mam nową, oryginalną pompę wody i nowy płyn. Martwi mnie jednak temperatura, która średnio wynosi 95 stopni Celsjusza (91 C). Dzisiaj byłem pod samochodem i zauważyłem, że siłownik katalizatora, odpowiedzialny za sterowanie przepływem wody w nagrzewnicy, jest zablokowany. Dlatego chciałbym go przez jakiś czas monitorować za pomocą aplikacji. Siłownik jest zablokowany w pozycji całkowicie wysuniętej. Nie mogę go ruszyć, więc odpuściłem.
  13. rjparker
    10,374
    6,493
    The phone app I used above is "Car Scanner Pro" for Apple IOS. The Pro version is an upgrade within the app.
    95c / 203f is ok.
    The exhaust heat recirc system actuator does not block coolant flow to the heater, instead it reroutes it internally through a heat exchanger to warm the coolant faster.
    #33 rjparker, Oct 25, 2025
    memory likes this.
  14. Brian1954
    Brian1954 Senior Member
    2,351
    948
    South Central PA, USA
    English translation is:
    Hello, I'm sorry for the ten posts. I probably have a problem with the EHRS system. Please tell me the app for measuring engine temperature and the PID 7C0 coolant recirculation sensor. In short, I have a new, original water pump and new coolant. However, I'm concerned about the temperature, which averages 95 degrees Celsius (91 C). Today I was under the car and noticed that the catalytic converter actuator, responsible for controlling the water flow to the heater core, was blocked. Therefore, I'd like to monitor it using the app for a while. The actuator is stuck in the fully extended position. I can't move it, so I gave up.
    The app is "Car Scanner ELM OBD2".
    memory likes this.
  15. memory
    17
    Poland
    Dziękuję za szybką odpowiedź. Mam Car Scanner Pro, ale niestety nie wydziela się tego czujnika (poszukam jeszcze raz). Poznałem również schemat działania tego systemu jako atakującego w tym systemie. Martwi mnie jednak, że siłownik jest wypchnięty i nie mogę zrozumieć, jak działa. Jeśli jest silnik zimny, czy oznacza, że jest wypchnięty, czy ukryty? Czy jest jakiś film odprowadzający do? Dziesięć zamknąć zamykające klapkę wewnątrz katalizatora. Byłoby wiedzieć, czy wysunięty siłownik, czy klapkę; wpływ na wpływ na cały silnik, strukturę i układ wydechowy. Niestety, nie będę mieć dostępu do gniazda w przyszłości, ale kiedy będę mieć połączenie z innym urządzeniem, takim jak źródło dostępu lub inne części.:)
    Ups, spojrzałem jeszcze raz na schemat i wygląda na to, że wysunięty trzpień siłownika oznacza, że klapa jest otwarta, a spaliny swobodnie przepływają. Pytanie brzmi, czy mogę żyć z tą wadą.:)
    #35 memory, Oct 26, 2025
  16. rjparker
    10,374
    6,493
    Yes. The engine just warms up a minute or two slower.
    memory likes this.
  17. ChapmanF
    18,418
    Somebody reported a situation once where the rod had fully extended, but the lever it pushes on had slipped beside it, so the valve was in the cold position still.
    For clarity, just as the diagram above shows, the valve in question redirects exhaust flow, not coolant flow.
    memory likes this.
  18. memory
    17
    Poland
    Thank you for your answers, when I have a chance to use the lift I will take a closer look, maybe even undo the lever to make sure that the flap inside is working and that it is open so as not to choke the removal of exhaust gases from the system.
