Are the 17" tires really that much better for Gen 5?
Discussion in 'Gen 5 Prius Main Forum' started by GeoJ, Jun 29, 2025.
  1. PriusTech
    PriusTech Member
    98
    58
    Reno
    The 16" Prius touring wheels weigh 15 lbs. A 17" CT200H wheel weighs 25 lbs.
    All factory wheels have to meet Japanese and USA standards for strength. Besides being weaker magnesium corrodes more easily and if it catches fire in a crash it cannot be extinguished. One fault of the Prius touring wheel is that they corrode at the tire bead area and it causes slow leaks.
    Gokhan likes this.
  2. Gokhan
    Gokhan Senior Member
    5,749
    2,273
    Paramount CA
    Just be happy with what came on your car. LOL Besides, I haven’t seen a single aftermarket wheel that looked good on a Gen 5 Prius yet. Moreover, when people remove their wheel covers, the bare wheels under them also don’t look good. But then, beauty is in the eye of the beholder.
    PriusTech likes this.
  3. Hammersmith
    Hammersmith Senior Member
    2,015
    2,004
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Modallista Wing Dancer XX. Stock OEM 17" size(17x6.5).
    I still might consider them when my original tires wear out in a couple years. The CrossClimate 3 will be coming out in at least 205/55-17, which will do if it doesn't come out in either 195/60-17 or 195/50-19.
    Gokhan likes this.
  4. Gokhan
    5,749
    2,273
    Paramount CA
    Not bad, and kinda like the Gen 5 PHEV wheels!
  5. Hammersmith
    2,015
    2,004
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    They're a dealership option in Japan. Modallista is a Toyota partner. I'm not nearly as big a fan of the 19" Modallista option(WingDancer XIX).
    Gokhan likes this.
  6. Zeromus
    Zeromus Active Member
    509
    270
    Ottawa Canada
    2024 Prius Prime
    SE
    If I wanted to spend the money to put these on for winter, or to let my other rims be for winter with these for summer, I'd grab these. They're nice. But as is, I'm okay with steelies for winter tires, as ice and snow and hidden curbs behind the snow can beat up steelies and I won't shed a single tear.
    GcinFl likes this.
  7. thetoys
    thetoys Junior Member
    47
    Toronto, ON
    2024 Prius Prime
    XSE Premium
    IMG_2967.jpeg Glad that I put 225/50 R18 Zrated tires on the Prius. Cabot Trail is Awesome. Would recommend to anyone. Road has a lot of high speed corners in quick succession and elevation changes for hours on end. In Sport Mode the Prius got at least 10 to 15 miles of added EV range just from just regenerative braking while my daughter was driving in the last leg of the trail. Speed limit is 80 KPH (50MPH). Doubt that OEM 195/50 R19 would of handled the trail as well.
    #47 thetoys, Jul 14, 2025 at 2:22 PM
    otatrant likes this.
  8. GeoJ
    GeoJ Active Member
    185
    177
    United States
    2023 Prius Prime
    XSE
    I have been following this discussion (I should, since I started it!). Nothing here has really convinced me that the 17 inch (or 18 in the last post), or different size is that much better than the OEM.
    My two big problems are, no decent all weather (like a Michelin Crossclimate 2) and no spare.
    I have pretty much decided to solve both problems like this: buy Michelin X-ice in the OEM 19 inch size before winter (my Toyo OEMs will have roughly 30-35K on them) and keep the best OEM as a spare. I suspect this solution will not be liked by many here, but given that I only drive 12k or so a year, with maybe half of that in snow country, I think my solution is the most cost effective, easiest and will mostly get the job done pretty well.
    Thanks for all the suggestions and great inputs!!
  9. Hammersmith
    2,015
    2,004
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yeah, it's a pretty terrible idea to use winter tires in the warm months, but you'll figure that out come next spring. Bad handling, bad fuel economy, and significantly increased tire wear. But you seem to be locked into the idea, so you do you.
  10. GeoJ
    GeoJ Active Member
    185
    177
    United States
    2023 Prius Prime
    XSE
    Have you tried it? Wondering if you are speaking from personal experience. If you search Michelin X-Ice tires with question about running them year round, many posts say they do it without the negatives you mention. In fact, some of the posts are from Prius owners (earlier generations). I will see if I can find that to link.
  11. GeoJ
    GeoJ Active Member
    185
    177
    United States
    2023 Prius Prime
    XSE
    Here's one: Michelin IceX long term wear | PriusChat
  12. GeoJ
    GeoJ Active Member
    185
    177
    United States
    2023 Prius Prime
    XSE
    Or, maybe I'll just buy the crappy all-season tires that are available in the OEM size, which I guess I just the Toyo OEM and maybe a Michelin OEM that my car didn't come with. Less of my driving is in heavy snow anyway, and I will just avoid driving until roads are cleared, unless going skiing, then have to just go, go, go. With a crappy new tire with good tread, that will help in snowy conditions and I've been driving 40 years in snow and never had an accident or gotten stuck that I couldn't rock out of.
    Pretty ridiculous, this tire issue on the new Prius. Not enough for me to not buy the car, because so many other positives, but if I had known I might have thought longer about it.
    Thanks all.
  13. Mendel Leisk
    40,587
    OEM means Original Equipment Manufacturer, for what it’s worth. The 5th gen Prius roll out of the factory on both 19” and 17” wheels. Traditionally the smaller diameter come on base level, are considered “standard”, and the larger diameter is “optional”.
    Maybe that goes out the window with 5th gen though. Up here in Canada a non-plug-in 5th gen ONLY comes with 19” rims. :(
  14. Hammersmith
    2,015
    2,004
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Like I said, your choice. Personally, I'm not going to hasten the life off my X-Ice Snows for summer driving. If I were you, I'd hold off until winter to see what Michelin does with the new CrossClimate3. What you really seem to need is an all-weather tire, and that's what the CC3 is. Almost as good as a dedicated winter tire in snow and ice, and almost as good as a good all-season tire in the summer. Perfect for those of use that put on 12k miles or less a year.
    Michelin is currently rolling out the CC3 and CC3 Sport in Europe. They should bring it over to North America in time for the winter season. While the stock 19" size isn't on the list of sizes yet, there are about 80-90 sizes they haven't announced yet. Maybe they'll release something close enough by winter.
    If they do come out with a CC3, I'll probably swap my Toyos to them and keep using my X-Ice Snows in winter until they wear out. Then I'll go to the CC3 year round.
