2005 Prius diags, acceleration issues then parked for a year
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Grrrrrr, Jul 16, 2025.
  1. Grrrrrr
    Grrrrrr New Member
    I'm trying to help a friend. I've fixed my own cars for decades but have no Prius experience. I do understand electricity and safety. I don't necessarily expect to be able to fix this (maybe) but would appreciate guidance in troubleshooting so we can figure out which direction to go.
    History and symptoms...
    2005 Prius, 225k miles. A year ago it was parked for 2 months then only driven occasionally. One day it wouldn't start. Jumping it worked but after driving about 15 min it would go silent and only accelerate to about 10mph. Eventually it would accelerate normally again but each time was different, sometimes after a minute, sometimes several. After a bit more use it wouldn't accelerate unless you got speed (such as downhill). Then it stopped being able to start on its own, needing a jump every time. The 12V battery was replaced but it didn't help. It's now sat for maybe 8-9 months.
    This is where I got involved, here's what I did...
    The car was unresponsive until a 12v jump pack was hooked. I pulled codes P3000 and P3030. I ran Dr. Prius even though I haven't yet read how to use it or if it works with dead batteries. The bars on the left half were fluctuating, some red, some going between red and not red (colorblind). Screenshot attached.
    I understand P3030 could be damaged connections in the battery bus harness (battery monitoring system?) but also this car is 20 years old, how long do these battery packs live?
    My plan is to bring a plug in charger and get the 12v battery charged fully (if it's not ruined) before trying to collect more information, hopefully with guidance from this forum. I plan to also check connector BM1 in the rear right which I understand to be a common corrosion point.
    Advice is welcome. Thanks.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,062
    1,981
    NJ-USA
    You have failure of the voltage sensing wiring or the orange connector on the battery ecu.
    You still might have battery problems besides, but voltage sense is bad.
    Carall and Brian1954 like this.
  3. Grrrrrr
    Grrrrrr New Member
    Is that based on the Dr.Prius readings or the described performance symptoms, or both? The reason I ask is I thought I read the car would still function normal with the bad sense wires (might have misread though). Or are the performance symptoms why you said might still have battery issues? I'm just trying to get a picture of possible scenarios. Thanks.
  4. Carall
    Carall Active Member
    315
    104
    Harrisonburg, VA
    The orange plug In your battery connected to battery ECU for the sensor wires oxidized from the fact that the car was parked for a long time and this led to the formation of resistance on several modules and they discharged to zero volts. This usually happens with block 1 and 2. But the screenshot shows that there is also a problem with block 5, 6 and 7. You need to take care of your battery.
  5. dolj
    dolj Senior Member
    8,458
    4,294
    Wellington, New Zealand
    You can't make any assumptions about battery block voltages until the ECU pins and voltage sense wire loom (aka No. 2 Frame Wire) is replaced.
    Brian1954 likes this.
