Bad 12V?
Discussion in 'Gen 4 Prius Main Forum' started by Sung Woo, Jun 26, 2025.
  1. Brian1954
    Brian1954 Senior Member
    2,137
    828
    South Central PA, USA
    This thread is about the 12v battery in a Gen 4 Prius, which is located in the engine bay.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
    And that protects it from heat, how?
  3. Brian1954
    2,137
    828
    I did not say anything about heat. I was just pointing out that the Gen 4 12v battery is located in the engine bay. You wrote about the 12v battery being in the rear of the car and about high temperature back there.
    #43 Brian1954, Jul 9, 2025
  4. BiomedO1
    3,467
    1,800
    SacTown, Ca
    I've found the gen4 is pretty stingy about sending power to the 12VDC battery and prioritizes the current to the traction battery. These cars don't behave like a regular ICE, where the alternator is ALWAYS pumping 14VDC into your battery as long as the engine is running. Someone here in the past has charted the voltages going to the battery during several hours of operations. Sometimes it's a 14VDC and other times it's as low as 12.25VDC. Bottom line; you can't count on intermittent operations of your gen4 to maintain your battery at a decent level. If this was a daily driver, this wouldn't be an issue. Go to harbor freight and get a <$10 digital volt meter. Check the battery voltage on occasion, and charge it when necessary. It only needs a couple of hours @6A to get back up to 12.8VDC; a bit longer if your charging at a lower amperage.
    The problem with the cigarette lighter voltage meter, the car needs to be turned-on for it to operate - that's going to mess with your results. The lighter is on a relay and turns-off with the car, so you'll get invalid results.
    Hope this helps and slows down the cars' battery consumption.
  5. Paul Gregory
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
    I believe the battery management system responds to the temperature of the battery.
  6. Brian1954
    2,137
    828
    I agree with you for a Gen 3 Prius. I do not know enough about the Gen 4 Prius to know if that is true or not.
  7. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Paul,
    Most of the discussion here is about the 12v battery's ability to store energy as it ages. You voltmeter in the auxilliary outlet is measuring the charging system voltage as the auxilliary outlet is not active when the charing circuit is not running.
    JeffD
    BiomedO1 likes this.
  8. Paul Gregory
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
    I have only experience with a gen 3 and a gen 5, so my two cents might be worth zero cents for a gen 4.
  9. Sung Woo
    Sung Woo Junior Member
    70
    Washington, NJ 07882
    Four Touring
    Okay, battery installed, all is well. The only thing I could not figure out is the black plug that came with the battery. It was in a little plastic bag and stuck under the black terminal plug. Is this important? I could not find anything in the manual. See attached.
  10. ChapmanF
    18,057
    Is it a battery with a port that allows connecting a hose for venting (say, if it were installed in the cabin, like other Prius generations do)?
  11. Sung Woo
    70
    Four Touring
    Ah, that must be it. There is talk of a vent plug, but this is sitting under the hood so I think I'm fine to leave it as is. Thanks!
  12. Mr.Vanvandenburg
    1,352
    570
    2020 Prius Prime
    The only way to know more about your battery is with a monitor. Here is five day graph of voltage activity on my two cars with Ancel monitor. The purple is an alternator vehicle, green my 2020 Prime. There is a period of external charging the 12 v. Prime battery, showing what the charging curve is for that device.
  13. Paul Gregory
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
    I discovered a loose connection on my 100Ah lithium auxiliary battery, branded, "Li-Time." Because it was running the cooler all night, it had gone completely flat. When I connected my charger to it, it would not take a charge, the charger displaying an "err" message. This was disappointing, because the battery is only about 1 year old, and it was supposed to have battery protection to prevent such things. Later in the day, the battery began to take a charge. I suppose this is due to a bit of regeneration that can occur when the battery sits idle for a time.
  14. Rick Hanauer
    Rick Hanauer New Member
    Oxford,MA
    My 2016 wouldn’t start yesterday, dash warning said low 12v battery (original 9 y/o Toyota battery). Put a charger on it and got it started. Nearby Advanced Auto Parts just had this compatible battery:
    DieHard EV Battery: H4 Group Size, 570 CCA, 710 CA, 80 Minute Reserve Capacity.
    Bought it for $229 and they installed it for free. Works fine. I know it’s not AGM like the OEM battery, will it cause issues or just not last as long?
    #54 Rick Hanauer, Jul 17, 2025
  15. Rick Hanauer
    Oxford,MA
    Couldn’t edit original post to correct new battery info so I corrected it here:
    DieHard Gold Battery: H4 Group Size, 480 CCA, 600 CA, 96 Minute Reserve Capacity, Maximum Starting Power
    Bought it for $229 and they installed it for free. Works fine. I know it’s not AGM like the OEM battery, will it cause issues or just not last as long?[/QUOTE]
  16. Paul Gregory
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
    In short, I don't know, but my gut says it will not last as long, as the normal charging voltages will be higher than that for a typical lead-acid battery.
    $229 seems like a lot for a lead-acid battery. You think the dealer has a big markup?
    AGM batteries require between 14.6v and 14.8v when performing a full charge from the state of discharge. On the other hand, lead acid batteries require between 13.8v to 14.4v.
  17. BiomedO1
    3,467
    1,800
    SacTown, Ca
    The 2016 Prius, gen4 - I believe has a standard lead acid battery. All previous and future Prius has the AGM battery in the passenger compartment of the car. You should be able to get whatever warranty period that Die Hard provides. I'm pretty sure that's a sealed unit and the manufacturer makes sure it will last the warranty period, before they die (planned obsolescence, forcing you to buy another). While sealed unit are convenient, they don't allow for routine maintenance. I routinely get more than 10+ years out of non-sealed batteries by simply doing annual maintenance on them.
    Hope this helps....
    Brian1954 likes this.
