TEMP symbol on car's dashboard?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Mayank Jain, Jul 16, 2025.
Tags:
  1. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    Hi Everyone,
    I have a Prius Plugin 2012 with 130k miles which i've been driving mostly on HV/EV mode from last 3 months without charging the car (I try to maintain the electric range around 4miles range by not driving in EV). I don't have access to a charger where I live.
    Suddenly today, a symbol started flashing intermittently in white color on the car's dashboard which I couldn't find in the manual. It showed up on the dashboard which is next to the speedometer (where time is shown).
    It looks like a Car with an arrow coming inside it and word TEMP written on it (see attached picture of what I can recall)
    Any idea what this could be?
    Many thanks!
    51,538
    check the coolant level, gen 3 is notorious for blowing head gaskets around your mileage.
    i'm not familiar with that symbol, but other areas that are cooled include the traction battery through the rear seat vent (make sure it isn't blocked) and the inverter fluid and pump.
    if the battery intake vent isn't blocked, it would be worth opening the cooling fan up to see if it needs cleaning.
  3. rjparker
    9,884
    6,092
    Temperature warnings should not be ignored but there are different sources such as engine, hybrid system and battery.
    Most of us don't have an early plugin but the engine cooling warning looks like this:
    A Plugin Hybrid System (usually inverter) Warning
    A Prius v wagon has this "car" for hybrid system warning
    Attached is a section of the 2012 Plugin manual explaining warnings
  4. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    Thank you @bisco and @rjparker for quick responses. I've immediately reduced the vehicle's usage to bare minimum and am looking for a Prius technician in the bay area. I will also check coolant levels and the rear-seat vents. Will report back on what I discover.
  5. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    I took the car to mechanic who specializes on high voltage battery and engine - they offer a free ODB port scan.
    The scan came out green.
    Next, I'm going to a local mechanic to perform 130k miles servicing.
    I asked Gemini AI for what to replace/service for 130k miles and here's what it recommended (see attached).
    What do you think @bisco and @rjparker - is all in the list needed?
    Thanks!
  6. bisco
    51,538
    don't use AI, mistakes happen. if you don't have the maintenance schedule, go to toyota.com/owners and get one there.
    how many miles/years have you owned it? do you know any maintenance history?
  7. bisco
    51,538
    what does a green scan mean, no trouble codes? if you can't find the cause of the problem, try earthling automotive.
    can you post a pic of the temp warning you drew?
  8. rjparker
    9,884
    6,092
    No drive belts on your car. Fluids and plugs are all a good idea unless already done. Insist on genuine Toyota coolant and plugs.
    I would focus on the temperature issue. If your mechanic can check the two coolant pumps (engine and inverter) with his scan tool he should do it. It requires a Toyota hydrid capable tool.
    If there is any pushback, I would spend my first $150 at a dealer to track down the issue. If you need a water pump get a genuine Toyota installed by your shop. Then have your fluids and plugs changed.
  9. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    I've owned the car since 2018 as the 2nd owner and got it serviced once in 2022 at 110k miles.
    Right now, its 130k miles.
    Approximate warning sign image that came up in white color is attached.
    Also attached is the scan report I got. I don't know why RLDM and RRDM came as red, they both work well.
    Screenshot 2025-07-16 at 6.51.53 PM.png Screenshot 2025-07-16 at 10.12.46 AM.png
  10. bisco
    51,538
    are you not able to take a picture of it, or has it not come back?
    i suspect that scanner isn't adequate for prius
  11. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    No it flashed a few times and hasn't come back again.
  12. rjparker
    9,884
    6,092
    It almost has be a message on the multi function display that was misread or was added with some ecu update after the manual was released or it was a car symbol meaning something else like
  13. bisco
    51,538
    could just be a glitch. i would make sure everything is working properly in the cooling department, catch up on regular maintenance and not worry about it.
    btw, you're around the 'clean the egr circuit or blow the head gasket' mileage.
  14. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    Thanks for the heads up. I'll check more about it.
  15. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    I solved the mystery.
    It was a button on the steering wheel which I was pressing accidentally & unknowingly. The reason this symbol wasn't found in any warning signs manual because it's not a warning sign
    However this made me change all the important fluids. My hybrid transaxle fluid was practically black in color.
    Car is back to normal. Thank you everyone for the quick help!
    Brian1954 and xliderider like this.
  16. rjparker
    9,884
    6,092
    The good ol ac temperature control
    xliderider likes this.
  17. bisco
    51,538
    LOL, glad you got it sorted!
  18. ChapmanF
    17,763
    Funny, my 2010 has the "Touch Tracer" mimics that show up next to the speed, but I don't think it shows that status display on the MID. If you press the button, does it show your temp setting? I would like that better than having to look down at the climate display.
