Diagnosing Coolant Burning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tyler Pryjda, Jul 18, 2025.
  1. Tyler Pryjda
    Tyler Pryjda New Member
    Ohio
    Vehicle History
    Starting from the beginning, I bought this Prius at ~125 miles with a p0420 code.
    A new Hybrid battery was installed just before I bought it, and a converter may have been replaced at some point as well.
    Eventually, I got curious to the p0420, and started digging.
    My scanner reports regular voltages for the converter, although relatively warm operating temperatures. Cat and cylinder cleaner were run through to clean things out. I have reason to believe the cat is fine, and the sensors are fowled or detecting strange behavior.
    I noticed that on the car fax, the vehicle has oil changes only every 25k miles at a dealership. Perhaps there were others, not at dealerships, but, I believe poor oil changes were consistent in the first 125k.
    So, this brings us to the ‘Coolant Burn Event’
    Coolant Burn Event
    This vehicle frequents Pennsylvania, climbing and descending mountains frequently. Upon a descent, preceded by a slowly worsening exhaust smell over weeks, coolant began to burn and exit the exhaust. Sluggish acceleration and other issues were noted but seemed to self remedy, and when looking at the scanner, a high knock correction value was noted and the freeze frame for the event notes lean conditions.
    When this occurred, coolant was added with gasket sealant and an oil top off with cat cleaner.
    Oil and coolant are not mixing, no [consistent] misfires fuel trim self corrects and is running stoichiometric.
    So what’s happening here?
    Simplified symptoms:
    • Sluggish acceleration on steep inclines
    • Power loss
    • Coolant burn on steep descents
    • Lowered mpg
    • P0420
    My running theory
    Oil maintenance was neglected for far too long, too regularly, creating sludge and carbon deposits within the cylinders, crankcase, PCV valve, EGR passages, and converter. These deposits created pressure on the intake gasket via clogging the PCV, which led to a leak of coolant through the intake manifold gasket. This event occurs regularly under high vacuum, during descents, and oil is not contaminated, which seems to point towards coolant entering the intake gasket rather than the head gasket.
    The car has a brand new actuator, upgraded combo meter, new hybrid battery, and I believe a somewhat new converter.
    At this point, I would like to replace the pcv valve, intake gasket, spark plugs, and drain/clean oil and coolant systems.
    my questions are, firstly, does this appear to be a sound assessment? I am going to investigate tomorrow to see, but, I was having a hard time finding information about replacing the intake gasket on the gen 2. I have done some repairs before, but am not intuitive enough to know how to find this part myself, nor the torque specs or bolt ordering, least of all best practices.
    I was hoping for some guidance, I have access to a mechanic for labor if anything exceeds me, but wanted to know if I was on the right track and where to go from here for instructions on the intake gasket.
    thanks everyone!
  2. T1 Terry
    T1 Terry Active Member
    929
    478
    First, I'd invest the few $$ on a borescope that will plug into your phone. Pull the spark plugs and look at the piston crowns, if they are clean, water is entering the combustion chambers, if they have carbon deposits, then you can rule out the intake manifold gasket being the problem and look at other possible problems.
    Even if the pistons are clean, meaning water is entering the cycles, is it all of them, or only 1 or 2 cyls that are effected.
    Could the water be entering through the EGR cooler? I'm just throwing that one out there, we don't have EGR coolers on the Gen 2 Prius over here, so I have zero experience with them, nor do I ever want to experience such a backward technology response to a pollution problem, there are far better methods .... but that is a bit like bolting the gate after the horse has bolted ...... electric vehicles don't suffer this sort of nonsense ;):whistle: You could always dump the ICE out of it and covert the transmission to full EV (y)
    T1 Terry
  3. dolj
    dolj Senior Member
    8,428
    4,285
    Wellington, New Zealand
    There is no EGR system in any market on the Gen 2, so no need to worry about that.
    Brian1954 likes this.
  4. Leadfoot J. McCoalroller
    8,069
    7,552
    Pennsylvania
    2018 Prius c
    20 year old radiator + use of gasket sealant often = very little reserve cooling capacity, potentially insufficient vs. mountain climbing. Engine could well be overheating or near-overheating. High temps will increase detonation potential.
    I'd be checking the cooling system, not necessarily trusting onboard coolant temp sensors.
    BiomedO1 likes this.
  5. rjparker
    10,080
    6,248
    You bought it at 125k and have changed lots of parts with more scheduled.
    We don't know the current mileage.
    We don't know if it burns oil which is common on these cars as they age.
    We don't know why you think it has a changed "converter" or if you are talking about the "inverter converter" or the catalytic converter.
    If it's a cat then it may be an aftermarket with reduced capacity causing the PO420. Sensors have their own codes and an oem gen2 cat is one of the best ever used which is why people steal them.
    Cat cleaners don't and can't work. Even attempts to clean cats off the car fail.
    Head gasket sealer - a bad idea that usually lasts for a few weeks or a couple of months with collateral damage to radiators and heaters.
    The combination meter guys can and do adjust mileage and carfaxs can be manipulated such that "low" mileage twenty year old cars may not be what they seem.
    Intake manifold coolant leaks as you suspect are unlikely but one of the easier jobs. Get it done so the real problems can then be attacked.
  6. Tyler Pryjda
    Ohio
    Just a few updates before I go looking any deeper.
    the cat I trust because of voltage readings, but, I ordered a Magnaflow speced for Priuses, just in case the cat was bad - I believe it’s reporting p0420 from the strange air fuel mixtures caused from contaminated combustion.
    I know the gen 2 doesn’t have an egr cooler, but, its intake manifold has egr passages - could these foreseeably clog?
    sealant and cleaner - I know these are suspicious, but I had to drive 500 miles back home to investigate this, so, I had to make it far enough before then. I intend to fully flush, clean, and refill all fluids today.
    the car has 175k miles now, oil consumption is very minor at maybe .2qts per 1k miles
    Combo meter just needed a capacitor, so, I did that myself, mileage is maybe off by less than 5 miles.
    I mention the possible new converter because when I bought it it had an exhaust leak, I had that welded and the tech offhandedly mentioned they thought it looked like a poor weld from a replacement, and that the presence of a cat shield pointed at it being new. I haven’t looked inside with a camera yet, but, voltage readings seem correct from the sensors in the cat.
    Coolant temps never reach beyond ~190f, I believe the engine is maintaining temps, but coolant burning is certainly happening on descents.
    From here, I will get photos of each cylinder, and the cat too if I can. I intend to gather photos of the intake manifold too. Can someone provide some documentation for the intake gasket please?
    Additionally, where else should I be looking for problems in this car?
    Thank you!
  7. rjparker
    10,080
    6,248
  8. Hayslayer
    Hayslayer Active Member
    389
    216
    Don't forget the throttle body is also a coolant flow path...and many times the Gen 2 will shut the engine off on downhills when it's not needed, and also will sometimes allow the drivetrain to spin the engine with no "fire" to bleed energy.
  9. Tyler Pryjda
    Ohio
    I was mistaken thinking the intake gasket had coolant lines; learning a lot of information fast, overlooking things.
    I’m convinced it’s a head gasket. I was under the impression that it was only failing under pressure, so was looking for places that could be building pressure, but in the end, I believe poor coolant maintenance had led to the degradation of the now 20 year old part, and that the coolant leaking is triggering p0420 codes despite a healthy looking cat - I snaked a camera into the o2 port and the thing shines like brand new, save for a single small carbon scar.
    notably I couldn’t find my way into the a/f sensor to look pre-cat, and I do suspect some damage on that area (temps report at 1k at b1s1) though voltages from both sensors appear normal under regular loads.
    I’ve flushed coolant and oil replaced both and installed a new pcv valve for good measure. Head gasket will be installed in some months, hopefully the car can be saved - I want another 150k out of it, 50k I put on was expensive and hasn’t made me enough money in return.
    thank you all for the replies, this forum is such a great resource for this car and I’ve learned a lot just reading through the posts i find.
    While I’m at it, what could cause a knock correction value or 21 and the other value being -3? Does this indicate anything to be aware of? A/F lambda is nearly 1 but p0420 freeze frames have both low and high short and long fuel trims - trims are level under normal load.
    I can post scanner screenshots if anything sounds suspicious.
    cheers for the info and thoughts!
  10. dolj
    dolj Senior Member
    8,428
    4,285
    The exhaust leak on its own, as you reported, will cause catalyst efficiency problems that can result in a P0420.
  11. Tyler Pryjda
    Ohio
    that was welded shut when I bought it, just was putting out the condition I bought it in in case it helped indicate anything in its history
  12. rjparker
    10,080
    6,248
    A leaking head gasket left unrepaired can easily bend a rod or blow a hole in the block.
    A used Prius is never a good investment especially if you use it for income.
  13. Tyler Pryjda
    Ohio
    I don’t intend to drive it, I have a rental in the meantime, making money to buy an Audi or vw from a mechanic friend, but the car is still young in miles and I’m certain the engine isn’t warped or cracked and compression will likely be fine too.
    All that said, it’s certainly wise to invest In a known reliable car with double mpg at the entry cost of any other used vehicle (6k for this car). I used to hate the Prius, its handling is awful and its power is less than substantial. However, it’s well engineered, reliable, and intelligent, which are all wonderful traits for a work vehicle.
    I drive ~350 miles every work day, so whichever car I use it’s going to break quickly over few years, and require constant maintenance. This is what makes repairing even a head gasket over purchasing another used car absolutely worth it. On the Prius, for example, as I have now repaired every common point of failure (minus the two pumps) and have brand new parts for everything mechanically important, I can sensibly trust the vehicle going forwards. A new to me vehicle however, will be the Prius at 125k miles, quickly needing over 3k in repairs to bring up to code.
    somewhat unnecessary information, but pertains to the reasoning on why I would repair the car, or rely on it.
    I will update the thread if anything changes for the car, and if those obd2 readings seem strange please do lend your 2 cents!
    also, here are the photos I gathered from the 02 sensor. The dirty portion is on the front of the car, the clean is the rear.
  14. T1 Terry
    929
    478
    Our gen2 catastrophic inverter was blocked like that, it got to the point it was hard to drive and the exhaust back pressure would cause the engine pipe to push away from the manifold, against the springs, then bang back into place as soon as the pressure released ..... it sounded sort of like a timing chain rattle and sucked me into replacing the timing chain, it did have 680,000kms on it at that stage ..... but the problem got worse.
    When I finally dropped the cat, that whole area had carboned over, a replacement aftermarket cat brought it back to life .... along with a new fuel filter ..... the most likely cause, a lean burn heated up the exhaust sections and the molten carbon was deposited on the partially blocked face of the cat.
    The Australian version has a plastic fuel tank and a fuel filter under the left hand front, about half way along the front door, attached to the inner chassis rail.
    The poor old Gen 2 had a whole new lease of life after that and continued for another 100,000 kms before something strange happened to the drive line .... either a failed CV joint or judders in the drive .... so it became the parts donor for our '06 Gen 2
    T1 Terry
