Help deterring and preventing mice in car
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by AnnaBiJou, Jul 19, 2025.
  1. AnnaBiJou
    AnnaBiJou Junior Member
    22
    Willington, CT
    2013 Prius v wagon
    I'm very upset about this, one of my cars is in the shop with a nearly 8k bill of rodent damage, I might be losing that car. I'm trying to prevent the same thing from happening to my other car, both are the same model, 2013 Prius V trim five. The dealer's told me the mice were up in the headliner, and using the A pillars as their highway up into the headliner. I'm looking for ideas on preventing and deterring mice from getting into the A pillar.
    Has anyone experienced the same issue? Any ideas on how to block the A pillar, or put deterrents like scent sachets there? Any unique ways you've figured out how to keep mice away period, away from the car entirely? Yes I'm already using mint oil, it seems to work yes but I can't get it into the A pillar.
    Thank you in advance.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,217
    586
    Alberta
    2024 Prius Prime
    XSE
    I've had no luck with those mild remedies. They may deter mice for a few hours or a day.
    I prefer the good poison that may leave a smelly carcass, but I prefer that over a live one.
  3. rjparker
    10,412
    6,521
    Mice and rats can chew though 1" siding and enter. The rubber seals in a car are child's play for them. You have to get rid of the mice.
    Use green mouse blocks scattered around the property. They will last a long time and work.
    If you have a garage, clean it out enough to use it all the time. Install a garage door opener. Scatter the green mouse blocks inside the garage as well.
    There is a slight time delay after they chew on the green blocks which usually gets them after they leave for work.
    #3 rjparker, Jul 19, 2025
  4. Paul Gregory
    2,217
    586
    Alberta
    2024 Prius Prime
    XSE
    Some mice are immune to the green blocks. I have seen them pooping out green pellets in a live trap.
    That's what I meant by better poison.
  5. douglasjre
    douglasjre Senior Member
    2,199
    734
    Null, NL
    Get cat at shelter. Keep food and water in garage w door open 6 inches to come and go
    gatorback likes this.
  6. 2015V-BadHG
    2015V-BadHG New Member
    22
    Portsmouth NH
    2015 Prius v wagon
    MICE SUCK! Hate them. I've used Peppermint oil in a spray bottle to some success. BUT stumbled on to this one that perplexed me at first.
    Mice seek warmth, dry, food and material. ("Green" soybean oil based sheathing on wires was/is a stupid idea.)
    Eating in the car is strictly prohibited. Spill anything best you pull out the seats and rugs and clean it.
    Remove the insulation under the plastic Prius cover on top of the engine or remove that cover completely.
    They Seek Dry, warm, bedding.
    I trap mice with 5 gallon buckets of hot water set out at night. 4-5 inches deep, covered with leaves i shred with mulching mower. then spring sunflower seeds or some other light weight feed on top. plank to edge of bucket. quickly reduces breeding population.
    The 2015 V I have now I bought in SLC Utah and drove home to Maine. No signs of prior mice damage or current activity.
    But it has a unusual "defense". Apparently someone forgot to put the oil filler cap back on drove it. The under hood insulation is soaked in motor oil!. Learned this when I cleaned up engine compartment . new HG, valve cover and degunked engine and under compartment. With hood raised kept dripping oil in lower right corner of that insulation under the hood. LOL .
    No mice in under my hood. Sons Camry they pee and leave dropping on his valve cover all the damn time.
    Soon I am going to remove his under hood insulation and soak it in cheap oil. Hang it to let it drip out and reinstall it.
    Good luck
    Pete
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,497
    2,482
    Taylors, SC
    1. Remove the engine cover. This improves engine cooling and provides no place for a rat's nest.
    2. Add screens to likely entry points using steel mesh or 1/4 inch opening hardware cloth.
    - Add a screen over the intake air filter to prevent the rodent from chewing through to clog the intake.
    -Cut a 2 inch strip of hardware cloth and roll it up. Shove it into the intake snorkel.
    -Get a cabin air filter that has a built in screen. K&N reusable filter have a steel mesh screen that will prevent chew through.
    -Remove the plastic rear flow through air exit vents accessible under the rear side panels. They will pry out from the outside.
    Install screens and reinstall. A photo is attached.
    3. Rodent repellent.
    1. Cover all wiring and all surfaces in the engine compartment with a light petroleum based rustproofing aerosol spray. Rodents
    will not chew on soy based wire insulation covered with petroleum oil based wax.
    2. Spray peppermint oil and red pepper based rodent repellent over the petroleum based rustproofing.
    3. Lock in the rodent repellent with a light overcoat of petroleum based rustproofing.
  8. AnnaBiJou
    22
    Willington, CT
    2013 Prius v wagon
    I'm trying not to kill them with poison, since if another animal, like an owl, which I have two around my house, eats them, they get poisoned too, among other animals that may eat a dying mouse. Yes I want them gone, no I do not care if they die, but I'd rather not poison other wildlife doing it.
  9. Paul Gregory
    2,217
    586
    Alberta
    2024 Prius Prime
    XSE
    Once I found the hole they had gnawed to get in, I still had the problem of the live ones living in my car. I don't like poison either, but there was zero chance of another animal being poisoned by it.
  10. AnnaBiJou
    22
    Willington, CT
    2013 Prius v wagon
    I did get bucket trap tops after doing some research for effective mouse traps, it took some puffed crackers and a slice of dried fruit but I got one in the bucket after having it for a week.
    Thank you for the other tips, it's interesting about the motor oil, I'll keep that in mind!
    Thank you so much, I'll look into it and see what I can figure out.
  11. AnnaBiJou
    22
    Willington, CT
    2013 Prius v wagon
    As of right now, far as I know, there isn't any mice living in my car right now, I've been extremely good about minimal food, cleaning up if anything's spilled, opening the hood of the car to make nesting in the engine area undesirable. I'm focusing on keeping them away from the car as much as possible.
  12. AnnaBiJou
    22
    Willington, CT
    2013 Prius v wagon
    An idea I had, how would stuffing copper mesh into the A pillars work? That's the primary spot I'm trying to block/deter them from, has anyone figure out an effective way to block A pillar access?
  13. Paul Gregory
    2,217
    586
    Alberta
    2024 Prius Prime
    XSE
    I have had a lot of problems with my mice in my vehicles over the years. So far, they don't seem to be getting into my new car.
    My Dodge Ram had them, because one day I found a mouse dropping on my coffee cup. In my Prius gen 3, it was a roll of paper towel shredded into a nest. In my T-Bird it was a cache of seeds in the trunk. So yeah, I hate them too.
