Why do hybrid battery control module connectors get corroded?
Discussion in 'Gen 2 Prius Technical Discussion' started by gdanner, Jul 21, 2025 at 5:57 PM.
  1. gdanner
    gdanner Member
    87
    39
    Central Illinois
    I'm replacing some faulty NiMH modules in my 2005 Prius hybrid battery. Yes, this car is old, but it has only 111k miles on it. I've replaced failed hybrid battery modules in it successfully in the past, but this time around I noticed something new which really troubles me:
    The orange multi-pin connector which plugs into the front side of the hybrid battery control module has a lot of greenish-blue corrosion inside it. This connector is part of the wiring harness of 15 thin wires which the hybrid battery control module uses to measure the voltage from each pair of NiMH battery modules.
    Fortunately the PC board inside the hybrid battery control module looks fine. There are no leaking electrolytic capacitors or other visible damage. Although there is a bit of corrosion on the connector pins, that will be easy to clean.
    This orange connector is the only place near the hybrid battery control module where there is any sign of corrosion. The other connectors on the hybrid battery control module all look perfect. All other connections inside the "control" section of the battery pack are fine.
    I'm familiar with cleaning the hybrid battery pack busbars. I know these always get corroded.
    But this orange multi-pin connector is located at the other end of the voltage sensing wiring harness. How could corrosive electrolyte from a leaking NiMH module travel all the way through a thin insulated wire which is more than 12 inches long?
    What else could cause so much corrosion inside this orange plug and socket?
    Could it be the result of occasional bouts of high humidity where water vapor condensed inside the orange connector? This connector is always energized because the other ends of the wires are attached directly to the battery modules. Could even a tiny bit of moisture condensation cause so much corrosion? Perhaps it takes a very long time for it to dry out if it gets wet?
    Previously my car did have the roof gutter leak where rain water collected underneath the 12V battery and underneath the spare tire. But I fixed that a long time ago and it stays dry down there now. At that time my hybrid battery was working perfectly. I only began having problems with the hybrid battery recently. Now I am wondering whether I actually have faulty NiMH modules, or perhaps this corrosion inside the orange connector is what caused my hybrid battery fault codes and red-death-triangle?
    Searching on-line I discovered plenty of photos of hybrid battery control modules with corrosion on the connectors. So I'm not alone with encountering this issue.
    I plan to replace the voltage sensing harness. I will carefully clean and dry the socket portion of the orange connector. And I will measure all of it with a sensitive ohmmeter (insulation tester) to make sure there is no electrical leakage at all.
    But I would still like to understand what caused this connector to get so corroded. I'd also like to learn how to prevent this from happening again.
  2. ChapmanF
    17,411
    Way back when I had my first car, the rubber-sealed weatherproof connectors now used under the hood were not a thing yet, and terminals were more exposed, and I noticed a pattern to which ones seemed to grow the most malachite (the green stuff). They would be the ones on constant-powered circuits, 12 volts 24/7.
    I think malachite and azurite are both compounds of only copper, carbon, oxygen, and hydrogen, so all the needed stuff is there with a copper terminal in humid air, but it must help to have a voltage gradient to grow the stuff.
    There are voltages constantly present on those orange-connector wires. They're the same wires at the other ends where they attach to the battery modules, but those ends are spaced out farther apart. The ends in the orange connector have the same voltage differences in a tight group with much smaller distances, so the voltage gradients there are steeper.
  3. PriusCamper
    PriusCamper Senior Member
    12,073
    4,901
    Pacific Northwest, USA
    So I just asked Google AI and then Asked ChatGPT this question and as usual GPT one was better (enclosed below):
    Specific to Prius packs there lots of different humidity-based and electrochemical and akaline processes involved that lead to this corrosion from trace amounts of NiMH electrolyte leaking from the seals of the modules. No doubt severe changes in temperatures play a roll in these very tiny leaks that Toyota can't prevent in a cost effective way. But your original voltage sensor wires act a means for the corrosive process to reach the pins of the ECU and you can get a new higher quality voltage harness at a 10% discount if you use this link: http://www.acenbay.com/?ref=priuscamper
    If the corrosion on the pins inside the ECU goes on for too long you'll start getting micro-arcs between that first pin and one next to it and you'll see it first as a sudden voltage drop down to one or two bars on your charge screen even though pack hasn't lost charge, it's just the ECU sensor getting scrambled. Once it progresses you'll get smoke and melting of the voltage sensor plug at the ECU which usually destroys the ECU.
    Anyways, here's a taste of how this corrosion happens according to chat GPT:
    ChatGPT - Electrolyte corrosion process
  4. ChapmanF
    17,411
    What was the prompt you used to get that ChatGPT response? Did you hint that you wanted electrolyte leakage to be part of the answer?
    I've seen malachite dependably grow on copper terminals given just exposure to humid/road environment and constantly-applied voltage.
    A lot less of it in modern cars because the sealed, weatherproof connectors used under the hood have become much, much better.
    The orange connector in the battery isn't that sealed kind though.
