Just need confirmation that junking the car is the best option...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AJP, Jul 24, 2025.
  1. AJP
    AJP Member
    159
    Central Pennsylvania
    Last year, and independent mechanic diagnosed as below. I chose not to take action on these items as they weren't dire.
    Two weeks ago, felt a shudder on startup and then when it happened again, and out of town dealer diagnosed it as this:
    When I towed it back to my home dealer, they were NOT able to reproduce any issues but when I pressed them, this was their report:
    Since I bought the car used in 2012, I've put $12k into major repairs. Over the 161 months I've owned it, minus regular maintenance like oil changes and such, that comes to roughly $160/month which was far less than a new car payment. However...I am truly thinking that with this shudder and a possible major gasket/engine repair, it's time to sell it for parts and start fresh. I am NOT a mechanically-inclined person and this decision has huge financial ramifications for me. Are the majority here in agreement that it's time to let this one go? She's at 200k miles, was hoping to take it to 300k, but I think we may be at the end of the road.
  2. pasadena_commut
    pasadena_commut Senior Member
    2,343
    699
    Southern California
    Stop going to dealers! We call them "stealerships" for a reason. Find a reputable independent mechanic and see what they have to say. If they determine the motor needs a rebuild selling it for parts might make sense. Sending it to the junk yard would be the step after that, if you cannot find a buyer.
    All that being said, head gasket problems at 200k miles is probably less likely on this car than on many others.
    Also as cars age, and these in particular, they make a lot more sense for people who can do at least some of the work themselves.
    Iron Man Prius and PriusCamper like this.
  3. Leadfoot J. McCoalroller
    7,927
    7,399
    Pennsylvania
    2018 Prius c
    Time to start over with something younger.
    Good luck!
    Iron Man Prius likes this.
  4. PriusCamper
    PriusCamper Senior Member
    12,168
    4,941
    Pacific Northwest, USA
    The bad headgasket with coolant leaking into cylinders is only a problem with 2010-2015 Prius. Having a bad head gasket in a 2004-2009 is very rare and as most recent mechanic reported there's no coolant leaking into cylinders. And a hybrid car with 200K miles has a third or in some cases half the wear and tear of a regular car that's not a hyrbid.
    If I were you I'd get new plugs and coils and keep driving it... The slight shutter you're concerned about is still intermittent and even the very best most well cared for Prius will shutter from time to time. It's the nature of the Atkinson engine design.
    Just drive it till the engine fails and then swap out the engine with a used one. 2004-2009 are great cars and you'll miss how simple it was to deal with if you move on from it.
  5. AJP
    AJP Member
    159
    I know. Incidentally the first independent mechanic quoted nearly the same. The problem is I've been ripped off by the private guys too and I've lost trust in everyone at this point.
    bisco, PriusCamper and GoodOldBob like this.
  6. PriusCamper
    12,168
    4,941
    Any chance you have a friend or family member with a history of working on cars could work with you and us to help build trust and either get this car fixed for cheap or at least help you find your next car for a good price?
    I mean you're doing a really good job at learning all this stuff and figuring it out and I'm optimistic for you having success, but it'd be more likely if you have more support to ensure you're always maximizing the value of the money you're spending.
  7. Iron Man Prius
    Iron Man Prius Junior Member
    84
    Fullerton
    Three Touring
    How far are you from Pittsburgh? Butler County Hybrid is a decent shop and Tom the owner is a good guy, maybe go get his opinion on this. I've seen a couple G2's with head gasket issues, so probably cheaper to swap a JDM than fix that.
  8. T1 Terry
    T1 Terry Active Member
    807
    421
    My '06 Prius has a bit more on the clock than that, has suffered the misfire on start up for probably 2 yrs now ..... keep saying I should look at the plugs .... until it settles a few hundred yards down the road .... and that fix goes to the back of the que, more important repairs required on other vehicles in the fleet. It has been a reliable low cost workhorse since the '08 Prius was retired with a lot lot more kms on the clock and developed a serious shudder under power .... put a new traction battery in it, but that didn't help, , needed front brake pads for the '06 Prius on a holiday week end, so the '08 has been off the road since ..... but I did shift the new battery to the '06 .... it could have been an inner CV joint problem ..... but with a choice of vehicles to keep on the road, that one became a parts donor .....
    Drive it till it drops, keep up the oil, check the coolant level when the engine is cold, and drive value for milage back into the Gen2 ..... they really are a great vehicle
    T1 Terry
  9. AJP
    AJP Member
    159
    I don't have anyone who knows cars, but I am fairly confident in my ability to shop for a new one.
  10. AJP
    AJP Member
    159
    I have a friend in Butler and it wouldn't be out of the question. I'll be calling him this morning. Thanks for the lead.
  11. pasadena_commut
    2,343
    699
    Southern California
    A new new one or a new used one? Most new cars with gasoline engines these days are direct injection with CVT transmissions and it is a dubious proposition that those components are going to last many hundreds of thousands of miles. In addition they have ridiculous numbers of computers, which are usually specific for both the application and the vehicle. In short, the peak of "cars that last a long time and can be repaired at a reasonable cost" is somewhere in our rear view mirror, I'm estimating 10 to 15 years back.
    The drive trains in EVs should be more reliable, other than the guaranteed pack failure at some point, which will almost certainly be a "junk it" level repair since they tend to run 50% (or similar large fraction) of the value of the car new. These have just as many computers as the other vehicles.
