Had to have it towed.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius92, Jul 25, 2025.
  1. Prius92
    Prius92 Active Member
    592
    121
    Iowa
    Kept having the "p=lock error" appear on my screen and could not leave my garage. I forgot having the smartkey function turned on can drain the battery and it was indeed low. Put it on an 8A charge for several hours and it was fine again.
    Then a couple days later, as I was leaving the post office it did it again. I checked the battery and somehow did not have the negative cable at the post tightened completely, tightened it and it was fine again.
    This morning it did it again. But then I discovered something. There was 12.5v at the battery itself, 12.5 volts at the jumper point under the hood, and 12.4 volts at the headunit when going into the diagnostic menu, but my OBD scanner showed only 11.5 volts at the port, and when I checked the voltage at the transmission control unit, it was also only 11.5 volts as well.
    If I remember correctly, the p-lock error can also occur if the voltage falls under 12.1 volts.
    I dug up the wiring manual and checked both ground locations for the TCU and both were fine, no resistance or rust/corrosion.I thought a bit of corrosion at the connection was causing this, but cleaning it didn't fix it.
    I'm just disappointed at myself because I'm good with cars, heck I even rebuilt the motor in this thing myself, but there over a dozen computers in a Gen2 Prius and hundreds of feet of wiring, and dozens of added failure points from all that.
    I even put a booster pack on the battery hoping it would trick the TCU, but that didn't work either.
    I'm not sure what's causing a voltage loss of 1 volt going into the computers, but it's hot as heck outside and I spent 4 hours sweating my butt off and made no progress.
  2. ChapmanF
    18,070
    I'm not sure what you're remembering, but what I've seen of the voltage thresholds for most of the ECUs that flag low-voltage conditions are a lot lower than that. I don't have access to a gen 2 repair manual at the moment, but in gen 3 the threshold for the transmission control ECU setting the C2310 code is given as "8 V or less".
  3. bisco
    51,840
    a load test is important with a 12v. if you charge it fully, and it keeps dying, it's either bad, or something is draining it when the car is off.
    are you getting any trouble codes? sometimes corrosion at an ecu connector is a problem
  4. Hayslayer
    Hayslayer Active Member
    387
    216
  5. Prius92
    592
    121
    Iowa
    I did, there was no corrosion or anything on that plug at the front jump/fuse box location.
    When I took the lower panel off which covers the TCU, I noticed the wires going into it were awfully tight, meaning the entire harness was pulling on the connection. If I wiggled it, it started up even more error codes, including evap and ABS codes.
    But there is something causing voltage loss, oddly when the car was running, it showed the correct charging voltage on the OBD2 connector and at the TCU. But not when it was off.
    I've read other posts where there was maybe 0.1-0.3 volts of loss between the measurement at the front jumper location and the OBD2 port, so an entire volt is concerning.
    The only place the voltage source from the TCU and the Datalink/OBD port are even remotely near each other is the underhood junction block.
    I'm not going to have Toyota do to much if it's going to be expensive, but hopefully they can at least find the actual issue.
  6. pasadena_commut
    pasadena_commut Senior Member
    2,584
    765
    Southern California
    The maximum charging current for an AGM is usually given as 0.3 C, on this battery if brand new 45*.3=13.5A. Somewhere or other Toyota says to only charge this battery at 4A (a little less than 0.1 C), although that limit may be only from the jump post. Given the tiny amount of fluid between the plates and the unknown capacity loss of an aging battery I would err on the side of caution and try to keep it closer to 4A. (I think the car itself may try to keep it below that, which goes a long way towards explaining why it has such a hard time keeping the 12V fully charged.)
    Since temperature, depth of discharge, and I think high discharge currents reduce life, I would expect that there is some curve that shows battery lifetime decreases with increasing charge current, although the decrease between 4A and 8A might be only a few percent.
  7. Hayslayer
    387
    216
    That 4 amp limit is written on an information sticker on the TrueStart battery itself.
    The actual wording is:
    Never add water nor charge quickly. When you charge battery, charging current should not be higher than 4.2 amps and charging time should be within 10 hours. Never take off the upper cover.
    #7 Hayslayer, Jul 26, 2025
  8. Prius92
    592
    121
    Iowa
    From what I'm reading, the beeping with the door open has been linked to a low 12v battery or a low keyfob battery, and I checked both out and they were fine.
    Looks more and more like an issue at the underhood fuse panel.
  9. Prius92
    592
    121
    Iowa
    They have been on it a few hours and have not solved the issue yet.
    They are going to check over the battery with their tester, they said the ones Walmart uses "often give false positives so they don't have to warranty them".
    Not to mention the health of a battery for a Prius is more about resistance/shorts/sulfation/etc and less about cranking capacity since the 12v battery in a Prius doesn't need as much cold crank capacity as it plays no part in starting the engine.
  10. pasadena_commut
    2,584
    765
    Southern California
    I charged one once with a 750mA Battery Tender Jr. It took a lot longer than 10 hours.
    They probably meant "Do not charge at 4.2 A for more than 10 hours", as that would certainly blow one up. Even that isn't a very good description of the limits on charging the battery. Charging one from 50% SOC at 4.2A for 10 hours will also destroy the battery, and one discharged enough to survive 4.2A for 10 hours will already be damaged from the deep discharge.
  11. Prius92
    592
    121
    Iowa
    Update, now I'm even more confused...
    They charged the battery overnight and their machine stated it was heavily sulfated.
    They have replaced the battery and now their is proper voltage at the OBD2 port and TCU.
    How the heck would a bad battery cause an entire volt of drop at both locations?
    Wouldn't there be voltage loss AT the battery too?
  12. pasadena_commut
    2,584
    765
    Southern California
    This might be apples and oranges comparisons with respect to the voltages.
    If they measured the voltage at the battery only with the car off it would only have been pulled down (at equilibrium, long after the car was turned off) by the ~25mA constant parasitic draw which is normal, which would only negligibly affect the open circuit voltage, even on a really crappy battery. Assuming the battery was fully charged and with no surface charge it would be 12.7V or something similar. Presumably when they were measuring at the OBD2 it was with the car in some "on" state, and they probably used IG-ON, where the battery supplies all the current and most (all?) of the car electronics are on, other than the inverter and things that require it. The current draw at IG-ON is substantial and can be quite high if the cabin fan or headlights are on. I measured almost exactly 20A on mine in IG-ON at the 3rd highest blower setting with everything else turned off. A marginal battery's voltage will collapse under those conditions, in your case apparently enough so that some electronics don't work. If they were to measure the voltage at the battery at the same time it would be the same as at the OBD2 (or very nearly so) at 11.0V or 10.5V or something bad like that. There can be a tiny voltage drop in the circuit from the battery to the fuse box (either across the long cable or at the ground junctions) and it increases with current from the battery - but it is not enough to matter.
  13. Prius92
    592
    121
    Iowa
    So it did in fact end up being the battery.
    Though Walmart said it was good, and it was good at the cranking amperage, their own tester showed heavy sulfation present.
    Replaced the battery with a Toyota one (bloody expensive) and all is good, other than now the inverter pump has died, but that's not too big of a task to replace.
  14. bisco
    51,840
    there's a similar thread here where the guy swears it's not the battery and refuses to even try another one. batteries are difficult, especially on a hybrid where they don't have to do much
  15. Prius92
    592
    121
    Iowa
    They don't have to do much in terms of amperage, but they seem overly picky on the quality of the voltage.
    I don't get why they don't use some kind of voltage regulator.
  16. bisco
    51,840
    yeah, that's above my paygrade
