Hybrid battery - how bout just changing bad cells without "reconditioning"?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Andrew Vanis, Jul 22, 2025.
  1. JC91006
    JC91006 Senior Member
    16,806
    8,593
    the professionals are the ones that are bad. The ones doing as a Hobby, a true hobby and not for profit, will do a much better job than most "pros".
    And Toyota did have their own rebuilt batteries, it was discussed here many years ago. They no longer do it now, but they tried to do it, most likely for warranty reasons.
  2. Hayslayer
    Hayslayer Active Member
    436
    259
    From Post 14.... Any company that remanufacturers these batteries (other than Toyota themselves at one point), will not have the quality control to have consistently good product. Their job is just to put modules back together and sell them back out, fast turnover is the key to their business model.
    PC, allow me to help here. Toyota DID offer a remanufactured HV battery for Gen 2 for a very short period (I'm not sure about other Gens). That is what is being referred to when he wrote "at one point".
    because they profit off of any possible excuse to sell the customer a brand new pack
    Take it easy with the conspiracy thoughts...they tried it and didn't like the success rate. You think they want to deal with pissed off customers who are upset because a rebuilt battery didn't last 5-10 years? Because that is exactly what happens. When people go to a dealer for repairs, they expect to be able to drive the car forever without that problem. A reman battery pack isn't going to do that, and it didn't take Toyota very long to realize it. Joe Blow gets a rebuilt pack installed by third party? They're a bit more realistic with expectations. Once you put the Toyota name on the bill? Realistic expectations go out the window. The ONLY way to meet those expectations is with a new battery. That's also why they'll tell you a new ecu is required if they see even a bit of corrosion on the pins. They're covering their axx.
  3. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    Panasonic manufactured batteries for Toyota until 2009. Since 2010, Primearth has been the manufacturer. Until 2012, the weight remained the same, 1,040 grams. Sometime, in 2012 (I think in the second half of the year) Primearth started manufacturing batteries with a weight of 1000 grams. In 2015, they began to manufacture modules in a new housing for 2016 cars. It's all about factory-installed batteries. The batteries sold by Toyota have a different story. The 2016 battery may be built with modules in the old housing. The batteries sold by Toyota differs by multiple stickers on the steel cover.
    #23 Carall, Jul 29, 2025
    gdanner and PriusCamper like this.
  4. Andrew Vanis
    Andrew Vanis Junior Member
    34
    Albuquerque
    so did the quick dirty swapped Toy 1/2 to replace Dor 13/14 will install in vehicle tomorrow and (fingers crossed)
    Interestingly the Toy and Dor have the bottom bolts on oposite polarities - Toy on + and Dor on -
    after putting on the final cover and flipping over to install bottom bolts at first I thought I put the cells in backwards so removed cover and , whew, I confirmed cells were in correctly but this different bolt anomaly .... and all the Toy cells are the saem and all the Dor cells are the same (to say on opposite side)
    (pics) IMG_20250728_220943295.jpg IMG_20250728_220937849.jpg IMG_20250728_220122687_HDR.jpg IMG_20250728_214502415.jpg
  5. Hayslayer
    436
    259
    Can you post the serial numbers of those modules? Photos? I've seen thousands of these modules and never had any with the threaded insert on the negative side. The Gen 1 has them on both sides, but I've never seen (-). I've heard of these modules being used in applications other than automobile HV batteries. I wonder if these (-) term inserts are from one of those alternate uses? Maybe a sly way of IDing them. I know Dorman has used Gen 1 modules in some of their Gen 2 rebuilds, so it wouldn't be a total surprise if they had alternate sources of modules.
  6. Andrew Vanis
    34
    Albuquerque
    I can post photos tomorrow of the top of the cells. As far as serial numbers, please specify which/where are the SNs so I can transcribe them into text in my reply.
  7. Hayslayer
    436
    259
    Thanks!! This has really caught my interest! They are directly on top of the modules. Typically near the center, newer gens have the serial number positioned where it would be under the black metal bars on top. Just to make it more fun to read I guess.
    It should be white lettering, but sometimes they're a bit faded. Most cell phone cameras can make even the most faded numbers show up if you find the right angle.
  8. Andrew Vanis
    34
    Albuquerque
    re: serial numbers on the DOR pack (with the bolt holes on the - terminal side
    1) images attaching. I might transcribe off these pics when I have time. if anyone transcribes before then, please post the SN characters so folks can research off of them
    2) interestingly, there were 2 cells that were the "newer" type that had the SN under the black bars.
  9. Andrew Vanis
    34
    Albuquerque
    installed cells 1/2 from Toy into position 13/14 Dor. car runs.
    on initial start up Dr Prius app gave it:
    life expectancy test of - a 55.42% "fair" report
    full battery test - all good except for poor balance on blocks 4,11,12
    ...will see how it does as it goes along.
  10. JC91006
    16,806
    8,593
    This is typical of a refurbished pack from "professionals", considered a Frankenstein pack. I wouldn't keep your hopes up on this lasting long. They would be severely out of balance with the different years and capacities, all bundled together.
    From the few that I saw, It looks like you have modules from the 1st generation all the way up to the 3rd generation. This is pretty crazy.
    I think it's best you start off fresh, these are probably recyclable cores at best. Search for a used battery at wrecking yards, possibly from a later model Rav4. Those can be had for a few hundred bucks plus shipping. And it'll be reliable for many years to come.
    #30 JC91006, Jul 29, 2025
  11. Andrew Vanis
    34
    Albuquerque
    what vintage?
    a search on 2020 (and it pullsup more years) is $500-$2,200
    Car-Part.com--Used Auto Parts Market
  12. JC91006
    16,806
    8,593
    You can get them from 2019 and up, newer the better. Rav4 came in 2 offerings, Lithium and NiMH. so you have to make sure you don't buy the Lithium batteries.
  13. Andrew Vanis
    34
    Albuquerque
    that's interesting - since they are all from the Dor pack and all have the lower bolt attachment on the negative side which seems rare for Toy cells.
  14. Andrew Vanis
    34
    Albuquerque
    took it out for a 60 mi run. about 1/3 city speeds, 1/3 40-60, 1/3 70-85
    averaged 42.3 mpg which is better than my other Prius which has a 1yo/20k mi? new Toyota battery. that one gets 37-41mpg
    about half way though, the Dr Prius full test showed "Poor balance on Bank 5" which is different than the full test after initial installation. I didn't test it when I got home.
    Bank 7 (which has the replaced 13/14 cells) seemed to consistently be the lowest voltage bank but did not throw any codes.
    about 40mi into this 60mi trip the P0420 Catalytic code appeared. no other codes (yet)
  15. JC91006
    16,806
    8,593
    They might not be from a Toyota.
    you’ve mistaken Dorman for a quality product, they don’t have good refurbished batteries
    #35 JC91006, Jul 30, 2025
    gdanner likes this.
