Is My 2025 Solar Charger Malfunctioning?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by iRun26.2, Jul 25, 2025 at 4:22 PM.
  1. iRun26.2
    iRun26.2 Active Member
    815
    167
    United States
    Sorry. Another post from myself without a response from anyone else:
    The one thing that is most useful about the ‘charge percentage’ way of measuring the gains from the solar panel is that the ‘charge percentage’ can be seen without turning the car on (on the iPhone app). I think the other measurements must have the car powered on. That is one of the main reasons I wish the ‘charge percentage’ matches the others.
    51,249
    is there are charge percentage on the car screen as well? if so, does it match the app?
  3. iRun26.2
    815
    167
    United States
    Yes, that to me is the most discouraging piece of the puzzle: The percent of charge remaining on the car and the percentage remaining charge on my iPhone app are the same. Yesterday, charging from 6AM to 3PM (when I leave work for home) I see an increase of 3% on both my iPhone and the car. The message on the leaf screen says I received a 2.3 miles of charge from solar power since the car was last turned on. Driving home, the 3% of additional charge is gone in like 1/2 mile (back to what it said when I arrived at work).
    I did get remarkably good driving efficiency on the way home, going 20.8 miles while using only 40% of my charge (. So it does seem like I got more than I normally would out of the car on the way home. That may be the wind, though.
    As I stated earlier, I did enjoy the ride. I don’t know what to believe, though, as far as solar charging was concerned. I sure dissipated the 2.3 miles earlier than I would expected.
    #43 iRun26.2, Jul 30, 2025 at 3:30 AM
  4. KMO
    KMO Senior Member
    1,835
    607
    Finland
    2023 Prius Prime
    It doesn't make sense to assign that solar charge to the initial part of the drive - where there's maximum power draw with you getting up to speed and stabilising the climate, and then conclude you're not getting value.
    It would make more sense to look at your 20.8 miles on 40% and conclude you got 3/40 of 20.8 = 1.6 miles.
  5. iRun26.2
    815
    167
    United States
    That makes no sense. 3/40 = 0.075 = 7.5 %. That is not what it told me. For that it would have needed to go from 61% to 68% which it did not do.
    You are right though in that the amount of power it uses initially is more than later on. But 2.3 miles gone in 1/2 mile? That seems a bit excessive. I’ve noticed that the electric mode is more efficient after you have driven a little ways but it’s not like warming up a gas engine.
    #45 iRun26.2, Jul 30, 2025 at 6:28 AM
  6. KMO
    KMO Senior Member
    1,835
    607
    Finland
    2023 Prius Prime
    3/40 or 7.5% of 20.8 miles.is 1.6 miles. Don't start getting other percentages muddled with your percentage of SoC.
    And the electric usage varies massively. Haven't you looked at the efficiency trip view?
    Maybe it's less clear when using miles per kWh, but when looking at kWh/100km, you'll have some one-minute bars down at 6 and some hitting the display limit at 40.
    One acceleration to motorway speed.can consume the same as a couple of miles of slower cruise. So sure '2.5 miles' of charge can easily be used in half a mile.
    Over the long run it all averages out, but you're looking at a real micro level here with these tiny charge deltas.
  7. iRun26.2
    815
    167
    United States
    It is very incorrect for it to tell me 2.3 miles (you came up with 1.6 miles, that was never reported to me) with only a 3% of total 100% charge. That implies I would get 2.3 x (100/3) =76.667 miles on a full charge. Not happening!
    Also, I’m not driving on a motor speed way I’m going 30 mph without the air conditioning on.
  8. bisco
    51,249
    is there anything in the o/m explaing the battery percentage?
  9. BiomedO1
    2,872
    1,534
    SacTown, Ca
    Your car's sensor is probably reading the surface charge on the traction battery and yielding the 2.3 mile distance calculation. This is similar to taking a battery off a battery charger. If you take an immediate reading your going to get a higher voltage than waiting 15 minutes for the battery to "settle". Garbage in; Garbage out..... and a better reason for the 0.5 mile actual gain. Have you done the actual math; isolating the panel output and tried comparing it to the car's readout????
  10. LRO
    LRO New Member
    United States
    2024 Prius Prime
    XSE Premium
    Yes ...
    p. 156 calls that percentage item in the MID meter display the "EV energy remaining" with the added definition "Displays the amount of charge remaining in the traction battery".
    Just did a real-time check on my own vehicle:
    MID display = 57% (2:44 PM)
    Toyota App = 59% (App updated at 2:44 PM)
    And interrogating my CAN bus with an OBD2 scanner using three apps it seems related to the State Of Charge (SOC):
    Dr. Prius = SOC = 56%
    OBD Fusion - SOC = 56%
    Car Scanner Pro - SOC = 56%
    And while my OBD2 scans gives me way more precision and split second SOC values to multiple decimal places, the Toyota vehicle and app offers no decimal place.
    So 57% can mean 56.5% to 57.499%.
    This isn't about a percent here or there is it? Oh wait, maybe it has been all along.
  11. iRun26.2
    815
    167
    United States
    No. It is several percentage points. Why is this so hard to understand?
    I get 4.5 miles/kW-hr minimum. Thus a full charge on a (new) battery should be 10kW-hr worth 45 miles for 100% charge. I get 3% change in the charge percentage. That is only 0.03 x 45 =1.35 miles while the car tells me 2.5 miles gained. That is nearly double! (Nearly 3% off).
    Im tired of arguing (but I’m still enjoying my car). I’m sticking to my original request. I want someone that actually owns one of these units to look at the charge percentage gained and also quote the miles gained as reported by the car. I want to know if mine is any different than theirs.
    If I had to guess, I’d say it’s probably due to inefficiency of the solar voltage boost regulator that cranks the solar panel voltage to much higher EV battery’s voltage. Toyota may just measure power out of the solar panel (before the boost not counting what the boost regulator wasted). I’d be fine with that if a few other people said they see exactly what I’m seeing (simply verifying my car is no different than other people’s cars).
    I still would have bought the car if I only got 1.5 miles for a full days worth of solar energy. I just wait to know why there is such a big discrepancy.
  12. iRun26.2
    815
    167
    United States
    In about a week I will be parking my car in the open sky for 10 full days (at the airport). My charge will most likely be 40% remaining to start out with). I will eager await to daily see how much more charge has been added to my car. This will be a better test than anything I currently have data for. If I get the 3% (of 100%) I’m seeing daily and get it for roughly 10 days, that be 30% and I could make it home from the airport without charging at the airport (and not turn on the gas engine). Getting 2.6 miles per day to produce close to 26 miles (what the car will probably report) would be even better (60%). I will be thrilled my car is capable of either outcome.
    LRO likes this.
