Headlights feel dangerous
Discussion in 'Gen 5 Prius Main Forum' started by cool_prius, Mar 11, 2025.
Tags:
  1. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    These new headlights are awful. After driving my new car in the dark for the first time, I experienced how bad they are. High beams were brighter, but not higher, and most of what was in front of me was utter blackness. Definitely not a safe feeling. A decent bicycle light held out the side window would do a better job.
    Hopefully I can fix it with an adjustment...this sort of advice is exactly what makes PriusChat so useful. Thank you.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
    As a related sidenote, I've had vehicles which were nearly impossible drive at night in a snowstorm. Light from the headlights shines up into the falling snow, which is very disorienting. My new car doesn't shine light upwards, and driving in a blizzard is fine.
  3. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I've also experienced that tunnel-vision disorientation driving through falling snow. One solution that worked on a slow, winding road to a ski hill was to turn the headlights off...not really recommended, but the orange 'fog lights' were the right amount of light at the time. My solution to that problem now is not to drive in snowstorms. Which of course doesn't work for everyone....
  4. Paul Gregory
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
    Low beam also works, but not as well as some sort of visor along the top edge of the headlights.
  5. cool_prius
    cool_prius Member
    106
    United States
    2025 Prius
    So... anyone else here mistake the Daytime Running Lights for low beams? I'm guessing it's a lot of people, since "No improvement with high beams, as it only makes that same area brighter." could only mean I was comparing the DRLs and low beams, and nobody said anything.
    soft_r and Tande like this.
  6. Paul Gregory
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
    I believe the original North American laws called for headlights to be on whenever the car was running. I read that Ralph Nader pushed for this. I believe the compromise reached with the automakers was to run the headlights in series, so that they did not consume so much power.
    The updated legislation for LED lights is roughly equivalent in the amount of light output, I believe. At least that's how it seems when I switch off my headlights at night, leaving on only the driving lights.
  7. Hammersmith
    Hammersmith Senior Member
    2,462
    2,522
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Only the LE and SE don't have automatic headlights. So the rest of us don't even think about it.
  8. Johnny Appleseed
    Johnny Appleseed New Member
    Stock Prius headlights suck. I put some Clearwater lights on mine. Better than daytime visibility now!
  9. Gokhan
    Gokhan Senior Member
    6,707
    2,658
    Paramount CA
    How do you replace the Gen 5 headlights with aftermarket lights?
    Also, I believe aftermarket LED lights are illegal now.
  10. Hammersmith
    2,462
    2,522
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    This is too simplistic of a statement to be meaningful.
    1. All LED bulbs used in halogen housings are illegal in the US. (even though some do a fantastic job)
    2. Replacement headlight assemblies that use LEDs are legal as long as they're inspected and approved by the DOT.
    3. Extra lights that are LED may or may not be legal depending on how they're installed and used.
  11. Gokhan
    6,707
    2,658
    Paramount CA
    Vague, yes, but one of my points, which you ignored, was to ask if an aftermarket replacement was even available. And, sure, you can buy decorative and fog lights, chances of most of them being illegal, too. I find it very annoying when people hang such lights on their cars.
  12. Gokhan
    6,707
    2,658
    Paramount CA
  13. dbstoo
    dbstoo Senior Member
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    It has nothing to do with MPG. It does have miles per tank, but that's only relevant in areas that have few fuel sources or fuel sources that take a long time to fill.
  14. VelvetFoot
    VelvetFoot Senior Member
    1,407
    545
    New York State
    2026 Prius
    Thanks @mva for the video and the 8mm socket recommendation.
    I just adjusted mine 6 notches clockwise both side-we'll see tonight if it helped.
    I just have one question. The manual says to turn the TWO adjusters on either side of the car the same. So, a total of 4 adjusters, where only two were shown in the video-one on each side. Has a revision been made?
    The outside one is a little harder to get to with the socket, but totally do-able and you can see the notches easily.
  15. Paul Gregory
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
    I remember when fog lights were yellow, then blue, but now they are clear white. The notion that different colors penetrate fog better is just so much hokum, backed by research. But that doesn't stop such products being sold; colored light lenses and colored driving glasses.
  16. mva
    mva Active Member
    174
    102
    B.C. Canada
    2024 Prius Prime
    SE
    The adjustment that I show in the video is just for up and down movement. There may also be adjustments for left to right aiming which I haven’t messed with.
  17. VelvetFoot
    1,407
    545
    New York State
    2026 Prius
    Alas, I did both as the manual said. I don't know if I did good or bad.
    futurist likes this.
  18. mva
    mva Active Member
    174
    102
    B.C. Canada
    2024 Prius Prime
    SE
    It looks like the manual might be in error. Or, god forbid, I could be wrong! I only adjusted the “A” bolts.
    There’s a sticker on the car saying to adjust both “A” and “B” screws the same number of turns for vertical. Similar to the instructions in the manual.
    But …… beside the sticker there’s another instruction cast into the plastic showing the “A” screw is for vertical and “B” is for left to right horizontal aiming.
    It’s dark here now but I will have a better look during the day tomorrow.
  19. Gokhan
    6,707
    2,658
    Paramount CA
    You would think they wouldn’t make an error on something like this. Or could they have meant to adjust the other side the same turns?
  20. mva
    mva Active Member
    174
    102
    B.C. Canada
    2024 Prius Prime
    SE
    I just tried adjusting the “B” screw on the drivers side. I tightened it 20 teeth and didn’t see any increase in the height of the beam. It might’ve pulled the light more to the left but it was hard for me to tell.
    When I tightened the “A” screw just 6 teeth I definitely noticed the beam moving higher.
    There’s also a contradiction between the manual and what’s cast into the plastic on the headlight housing which indicates that the “B” screw is for left to right aiming.
    Velvetfoot you did do it correctly, per the manual. How is the night driving now? Any noticeable difference?
    Maybe someone else has a definite answer?
