2013 Prius Two Head Gasket Set Part Number?
Discussion in 'Gen 3 Prius Main Forum' started by pingd, Oct 22, 2022.
  1. Bill Norton
    Bill Norton Senior Member
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    You guys,,, have you ever heard of the expression, 'Once bit, Twice shy' ?
    And for another reference, when I had my head gasket replaced at a Gasket Master shop, he used, JUST the FelPro head gasket. Period. He reused all the other seals and gaskets.
  2. Mendel Leisk
    41,808
    Here's a pdf of @Carall's illustrated index pic in post #34: Maybe more portable, printable.
    Couple of missing bits, perhaps because they're readily apparent: the head gasket (not in the picture), and the unidentified large gasket, framing all the others, presumably the valve cover gasket?
    #42 Mendel Leisk, Jul 30, 2025
  3. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    What is the difference between the Fel-pro gasket and the original Toyota one? Just in its different color? It's made of steel with a coating that will also come off when its time comes. For me, the Gasket Masters is not an authority on this issue, at all. When I did my first head gasket job on my prius, I relied on other videos, bypassing the Gasket Masters video. The last time I did a head gasket job was sometime in 2011, on a Chevrolet Aveo.
    Regarding gaskets and o-rings. How stupid is it to be there and not replace all this, which has been there for many years and many miles? Reused used o-rings may not leak while it's warm outside, but there may be a surprise in the wintertime. I've dealt with it. But how would you know it's leaking when it's inside your engine?
    ASRDogman likes this.
  4. Mendel Leisk
    41,808
    I concur. The Toyota head gasket is an easy culprit, hey, it's what failed. But WHY it failed deserves attention. My hunch is "something" caused it to fail, and if not rectified in the repair, it'll cause the replacement (Toyota or FelPro) to fail, in short order.
    FWIW, Toyota has also revised the head gasket. Did you happen to take a pic of the one you got with the kit?
  5. Carall
    316
    104
    Harrisonburg, VA
    I found a photo of this kit and it is not quite suitable for working with a head gasket. It's missing the intake gasket for the EGR tube. Missing injector o-rings, but there are many some other rings. What is this triangle-shaped gasket in this kit for?
    I guess I'll stick to 04112-37254 kit.
  6. Carall
    316
    104
    Harrisonburg, VA
    The failing of the head gasket is needed to be discussed separately. I already have two of them (failed) and I have questions about them.
    This is the head gasket I installed in my prius, a 2012 prius v with 231k miles, from 04112-37254 kit
    This is the head gasket I installed in another prius, a 2013 prius v with almost 212k miles, from another 04112-37254 kit.
    This is the head gasket i removed from my prius, a 2012 prius v with 231k miles.
    I'm wondering what those numbers on top of the gasket mean? I searched online and found numbers that matched mine from the kit. There is also a number that starts from 8.
    I'll stop by the Toyota dealer one day and ask about the updated head gasket.
    #46 Carall, Jul 30, 2025
  7. Mendel Leisk
    41,808
    That looks like the updated one, per The Car Care Nut's video:
    Starts at the relevant point. I'm not that sure about his "reason" for the failure, but as you say, for another discussion.
    It'd be good to know the part no for the one in the video. I asked the question, in the comments.
    Does the gasket kit not disclose part numbers of the content? Frustrating.
    #47 Mendel Leisk, Jul 30, 2025
  8. Carall
    316
    104
    Harrisonburg, VA
    According to the Toyota dealer website, the latest cylinder head gasket part number is 11115-37062.
    11115-37062 - Head Gasket 2008-2022 Toyota | Longo Toyota Parts
    I'll talk to my local Toyota parts department. We'll see what they say.
    I'll check the package of the kit to see if there's any paper with part numbers in it.
  9. Carall
    316
    104
    Harrisonburg, VA
    I stopped by the dealer and asked about the latest part number for the cylinder head gasket for the 2012 Prius. I asked him to tell me the number so that I could compare it with the one I had, and it was 11115-37062. Then he asked me for the vin number of the car to try another way. I gave him the vin # for 2015 Prius and the computer gave him the same gasket number 11115-37062.
    I asked him if he could find a list of gasket numbers from the 04112-37254 kit. He couldn't find it.
    I think that for such information you need to contact the Toyota corporation itself.
  10. Bill Norton
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    Felpro has a whole line of products called 'Problem Solvers'. I've used some of their upgraded suspension components on an old Element.
    Maybe trying some American Engineering might be a viable reason to not use the OEM head gaskets. How many chances do they get?
  11. Noahdoge
    Noahdoge Active Member
    211
    147
    Mississippi
    I think you’re referring to MOOG problem solver line? But felpro and MOOG are owned by the same parent company Federal-Mogul
    Bill Norton likes this.
  12. Mendel Leisk
    41,808
    Maybe the head gaskets are the "canaries"?
  13. Bill Norton
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    I don't know what you are saying.
    I'm just saying there's a problem with the OEM, so why not try a brand that addresses that problem... What can you lose?
  14. Carall
    316
    104
    Harrisonburg, VA
    Are there any examples of how long the fel-pro gasket has worked on the Prius 30?
    The Toyota head gasket that is installed on prius 30 engines is also installed on other Toyota engines, from 2008 to 2022, but there is no such problem with them as with the prius 30 engine, which means that the problem lies not in the head gasket, but in the engine and the design of the car itself. Even the Prius C does not have this head gasket problem, although the design of the engine is very similar to the Prius 30.
  15. Bill Norton
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    First, I'm not familiar with 'prius 30' or the canary above now.
    Let's assume it's the Gen3. But this basic engine is used elsewhere in the fleet.
    Does it have EGR and Hybrid duties in those other models? If so, what does that tell us?
    The Prius C uses the Gen2 engine, iirc.
    I'm giving another manufacturer a try on this component, just because..(y)
    It's all that Gasket Masters uses. They may have some unofficial data.
    I have a friend that drives a lot and is at +200k miles on a Felpro in his Gen 3. But that's just one example that proves nothing, so far. I haven't checked in with him in a while.
  16. Mendel Leisk
    41,808
    It's like saying every time our coal mine canaries die, next thing you know there's a coal dust explosion. So let's get those canaries some teeny gas masks.
    Is the problem with the OEM gasket, or would any gasket fail under the conditions that developed with a long-clogged EGR system?
    #56 Mendel Leisk, Aug 4, 2025
  17. Carall
    316
    104
    Harrisonburg, VA
    XW30 (2010-2015 prius), XW35 (plug-in version), XW40 (prius V) and so on. It's probably better to discuss the model of the engine that was installed on the Prius and Lexus.
    In Japan, these models were also manufactured in hybrid versions.
    The Prius C uses more Yaris engine than Gen2 engine.
    It depends on where the prius has been driven, in the city or on the highway. I know a Prius that drove 270k on the original head gasket, most of highway miles.
  18. Bill Norton
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    Thanks for the explanation. But your method is different than most on talking about models.
    I don't understand this: In Japan, these models were also manufactured in hybrid versions.
    All the models you listed are only "hybrid versions".
    270k mi on the original HG. That may be a record!
    And you're saying this engine in a non-hybrid may go longer?
  19. ASRDogman
    ASRDogman Senior Member
    7,747
    3,964
    It is likely they all use the same head gasket.
    I got to 301,000 on my head gasket....
    Bill Norton, Mendel Leisk and Carall like this.
