Slow Smart Key
Discussion in 'Gen 2 Prius Main Forum' started by qmanqman, Jul 21, 2025.
  1. qmanqman
    qmanqman Active Member
    354
    119
    CO
    The unlock feature of my smart key is becoming slower and slower. This morning I had to pull on the door handle 3 times before the door finally unlocked. For a second I thought I didn't have my key on me. Is this a sign the battery is wearing out in the key fob?
  2. dolj
    dolj Senior Member
    8,253
    4,204
    Wellington, New Zealand
    Could be. If you test the fob battery with a voltmeter, replace it if it is under 3 volts.
    qmanqman likes this.
  3. Mendel Leisk
    40,703
    When I'm replacing I've found the outgoing batteries still display quite good voltage, over 3.0 volts. but they are crapping out.
  4. bisco
    51,258
    fob key, 12 volt, lock motor, in that order
  5. qmanqman
    354
    119
    CO
    OK so on our other Prius it must be the lock motor. Neither battery fob will open the doors and the 12 volt holds steady a 13.8V. Found this diagram on the interweb. Also found a Reddit that says the "Room Oscillator" is not where this diagram says it is.
    1. If it's one of the oscillator's how do you know and how do you know which one?
    2. Is it safe to assume replacing one also means the system has to be reprogrammed?
    3. What is the purpose of the "Security Indicator Light" to this system?
    #5 qmanqman, Jul 29, 2025 at 11:33 AM
  6. bisco
    51,258
    don't test the 12 volt with the car on. test it with the car off. best to get a free load test at most auto parts stores, or buy a load tester100-amp-612v-battery-load-tester-61747.html
    same thing with fob batteries. without a load, they can read nominal 3.3 volts.
    if more than one door won't unlock, it isn't likely the actuators
  7. qmanqman
    354
    119
    CO
    Tested 12 V with car off and white clip unplugged. I might have the voltage wrong but it was solid and strong and this issue with the doors has been happening for a couple years now.
    Good to know. Didn't test that out. Can the fob itself wear out? Her fobs are pretty beat up.
  8. bisco
    51,258
    not really. you can try cleaning the inside and making sure the battery is tight. generally speaking, if the red light flashes when you press a button, it is working
  9. qmanqman
    354
    119
    CO
    Where is this red light you speak of? If it's on the fob I've never noticed because I usually press it while its in my pocket.
  10. bisco
    51,258
    yes, on the front corner, iirc
  11. dolj
    dolj Senior Member
    8,253
    4,204
    You remember correctly. ;)(y)
  12. qmanqman
    354
    119
    CO
    Thank you guys. I did find the light. On my fob the red light comes on when I push a button. On hers there is no light. What is the fix?
  13. bisco
    51,258
    make sure battery polarization is correct, new battery, clean the contacts, replace the fob, in that order
  14. bisco
    51,258
    try searching fob repair
