Fuel pump replaced/ now/ pedal sensor
Discussion in 'Gen 3 Prius Technical Discussion' started by davev1pa, Jul 26, 2025.
  1. davev1pa
    davev1pa Junior Member
    34
    Lincoln,NE
    Two Eco
    2010 Prius base . Son was 700 miles away . Died on interstate: hybrid battery needs checked. Towed to dealership. Fuel pump failure. Had it towed to small shop: fuel pump now replaced but now reads a code for accelerator pedal and sensor. Dealership said they only read a code for fuel pump.. order the pedal.The car runs for 30 seconds then dies.Pretty sure the hybrid is going to be too low with all these non regenerative start ups. Thoughts?
  2. ChapmanF
    18,538
    Make sure the shop tells you the actual five-character trouble code, not just what they think it "means".
    Then look for that code in this post.
    The Prius has both a throttle position sensor and a pedal position sensor, completely different parts in completely different places, and because of the way SAE standardizes trouble codes, all the trouble codes for those two different things have fortune cookies starting with the words "throttle/pedal position sensor/switch".
    If you're not paying real close attention to exactly which code(s) you have, you end up wasting time and money on the wrong part in the wrong place.
  3. Eddie25
    Eddie25 Active Member
    502
    212
    MI
    Make sure it has gas, the gas gauge can "get stuck" making it look like it has gas when it doesn't.
    Edit: Actually it's the part of the fuel pump that informs the gas gauge that gets stuck so if they replaced the entire pump then that's not it.
  4. ChapmanF
    18,538
    The level sender and the pump are both parts of the same assembly you pull out of the tank, but can be replaced separately, so the shop might not have replaced the whole enchilada.
    Don't forget to check the exact "throttle / pedal sensor" trouble code, using the link in #2 above, to be sure whether it is about the throttle sensor or the pedal sensor.
    Don't put off checking that.
    #4 ChapmanF, Jul 26, 2025
  5. davev1pa
    34
    Lincoln,NE
    Two Eco
    I appreciate everyone’s input. So now they’ve replaced the fuel pump. Also the accelerator pedal and sensor. Now they say the 12 V battery is without a charge and put it on a slow trickle charger to see if they can get the car to start. They also have no battery in a town of 65,000 and it would require them to order it . They will call if it starts after a charge today. I’m currently looking up new battery possibilities
  6. ChapmanF
    18,538
    Any word yet on what the trouble code was?
    If they haven't been in the habit of telling you what the trouble codes were up to this point, you might want to advise them of a new rule.
  7. davev1pa
    34
    Lincoln,NE
    Two Eco
    Well no unfortunately.. they replaced the fuel pump, Then read the code for the accelerator pedal sensor ( gave me a code but I didn’t write it down) the the 12v was super weak so they did a slow trickle charge which read 12.2 v static and the car started and ran for 30 seconds. The 12 v battery is dated 2017 but this shop thinks that it should be able to initiate the start up. He stated that he has no experience with hybrids and up to this point he’s only replacing the codes ie fuel pump, accelerator sensor and pedal. He’s feels that it may need attention from someone well versed in the state of the hybrid battery but that the local Toyota dealer may not be that great either. I’d thought about towing it back over there butt it’s a quandary.
  8. ChapmanF
    18,538
    It's unfortunate not to have written that down. Has he told you the "code for the accelerator pedal sensor" has gone away now that he changed that? Is the car giving any codes now?
    When somebody says that, and especially when somebody seems to think the codes tell him what to replace, it's very likely he's never learned that the Prius has seventeen different trouble codes whose fortune cookies all start with "Throttle / Pedal Position Sensor", but eight of them are about the throttle sensor (on the engine) and nine are about the pedal sensor (on the pedal). It is very easy to bark up the wrong tree if you don't have the actual trouble code(s) to look up in this post.
  9. davev1pa
    34
    Lincoln,NE
    Two Eco
    I can appreciate those concerns. But the initial code for the fuel pump was at the Toyota dealership. They told me there were no other codes. Their estimate was 1500. I had it towed to a shop that said they don’t do hybrids but could do the fuel pump for 800. They soon realized following the fuel pump that it ran the code for the accelerator sensor as well. Well it’s still not running. Also the 12v is weak at 12.2 ( imo) The car is 400 miles away I can’t deal directly and it’s a town with no hybrid shop other than the dealership. It’s unfortunate as I’m sure it was here I could delineate and take a lil time to sort thru the nonsense.
  10. ChapmanF
    18,538
    I know you've said that several times. All I can do is reiterate that unless the shop was very knowledgeable about the Prius (which they don't say they are), their ability to tell the difference between a code for the throttle sensor and a code for the accelerator sensor is probably nil, and there's a very good chance they guessed wrong about the code they saw.
  11. ASRDogman
    ASRDogman Senior Member
    7,818
    3,982
    Have them charge the 12v battery at 5 amps or less for 6 hours.
    How old is that battery? If it's 5 or so years old, it probably should be replaced.
    And the NEW battery needs to be charges also.
  12. davev1pa
    34
    Lincoln,NE
    Two Eco
    Folks this is just plain ridiculous. Car dies on interstate. Son said there’s 2 bars on gas gauge ( his words) . Towed to dealer - (coded fuel pump) 1600. I had it towed to a non hybrid shop to replace the fuel pump. 800. No go ran 30 seconds. Code read accelerator sensor. No go ..ran 30 seconds . Fuel was brisk at the engine. The shop said they didn’t know what to do. I asked what’s the fuel pressure and how much gas is in it? The shop bought 5 gallons of fuel and put it in…runs perfectly. lol that was a 1500$ tank of gas now and - it’s only half full….. well I guess my son wasn’t cognizant that it takes gas to run….. and all the scanners and dealers and repair shops don’t have enough sense to check the actual amount of gas that it takes to create pressure to the front….i personally apologize for asking for help as my first question to my son was - are you out of gas?
    Brian1954 likes this.
  13. ChapmanF
    18,538
    By this point, the OP's issue seems resolved, and this last reminder is more for others who might come across this thread in the future.
    Never let anybody tell you "code read accelerator sensor" or "code read throttle sensor" and not tell you the actual code.
    Prius has at least 17 different codes that all read "throttle / pedal position sensor" and that slash means one or the other.
    About half of those codes are about the throttle sensor and about half are about the pedal sensor. These are two completely different sensors in two completely different places in the car.
    The actual code has to be looked up somewhere like here to find out whether it is about the throttle sensor or about the pedal sensor.
    If you are ever having a Prius problem and about to post on PriusChat about it, you can save everyone time by never making a post that says "code read accelerator sensor" or "code read throttle sensor" and doesn't say what the actual code was.
    If some shop read the code for you and told you that, and didn't tell you the code, the best thing is to go back and ask, and then post the actual code.
    If you aren't able to find out what the actual code was, then just post that you got one of the codes for the throttle sensor or for the pedal sensor and you never got the actual code and so don't know which sensor it was about.
    That way, at least, we all start off knowing what information we do and don't have.
    And, of course, never let a shop spend your money changing a pedal sensor, or a throttle sensor, because they got a "throttle / pedal position sensor" code and didn't take the time to look the actual code up to see which sensor it was about. (Not to mention further troubleshooting the wiring, and so on, before condemning either sensor itself.)
  14. davev1pa
    34
    Lincoln,NE
    Two Eco
    Excellent advice
  15. ASRDogman
    7,818
    3,982
    Shouldn't the driver check the fuel level?
    You should ALWAYS start with the easiest and quickest things first.
    There could be some moisture in the fuel tank, so when it gets low, it is using that fuel mix.
    Perhaps some of the stp fuel treatment stuff that helps remove the moisture would help.
    Did you at least get your old good parts back?
    And did you get your money back from the ones that told you it was this or that and it didn't
    resolve the issue?
  16. Eddie25
    502
    212
    MI
    I spent money on a tow and a days worth of troubleshooting the same thing. It's tough to convince yourself that you might not have gas when the gas gauge says you do, so you can't really be too hard on your son. You have a right to be upset at the dealer though, that's crazy.
  17. davev1pa
    34
    Lincoln,NE
    Two Eco
    Well, no. I can’t say I attempted a refund…. I do regret not being able to be on site as I would have at the very least tried gas as a first attempt…. as it was my first question to my son…
    ASRDogman likes this.
