Featured Nissan motor analysis Munro
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Aug 1, 2025 at 9:32 PM.
  1. bwilson4web
    16,046
    Nissan is producing a motor using an electro-magnet rotor which eliminates the need for permanent magnets:
    The same as running an alternator as a motor, this is a brilliant solution as it also solves the problem of back-EMF that requires 'field weakening' in traditional motors. There is no free lunch as the rotor coils require power but the dynamic range of efficient power production is well worth it.
    51,259
    does it reduce rare element usage?
    bwilson4web likes this.
  3. bwilson4web
    16,046
    Yes. By orders of magnitude.
  4. bisco
    51,259
    i wonder if they are expensive motors to build. ariya is not an inexpensive car, for what you get
  5. T1 Terry
    T1 Terry Active Member
    783
    414
    I like the rational they used, reduce the supply chain issues and make highway driving energy efficient by not needing to waste battery capacity using field weakening. As said in the video, no one really cares about town energy consumption, plenty of recharge facilities in the city, not so much out on the freeways.
    T1 Terry
