Featured Nissan motor analysis Munro
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Aug 1, 2025.
  1. bwilson4web
    16,520
    Nissan is producing a motor using an electro-magnet rotor which eliminates the need for permanent magnets:
    The same as running an alternator as a motor, this is a brilliant solution as it also solves the problem of back-EMF that requires 'field weakening' in traditional motors. There is no free lunch as the rotor coils require power but the dynamic range of efficient power production is well worth it.
    Gokhan likes this.
    52,807
    does it reduce rare element usage?
    bwilson4web likes this.
  3. bwilson4web
    16,520
    Yes. By orders of magnitude.
    PrimeDan, Isaac Zachary and bisco like this.
    52,807
    i wonder if they are expensive motors to build. ariya is not an inexpensive car, for what you get
    hill likes this.
  5. T1 Terry
    T1 Terry Senior Member
    966
    546
    I like the rational they used, reduce the supply chain issues and make highway driving energy efficient by not needing to waste battery capacity using field weakening. As said in the video, no one really cares about town energy consumption, plenty of recharge facilities in the city, not so much out on the freeways.
    T1 Terry
    bwilson4web and PrimeDan like this.
  6. bwilson4web
    16,520
    It should be slightly more than an induction but significantly less expensive than a PM.
    The carbon slip rings are a wear item but having a pair of brushes for each should help. Efficiency TBD but should be on par with a quality induction motor.
    Munro makes money selling their tear-down reports. Perhaps call them Monday?
  7. Isaac Zachary
    Isaac Zachary Senior Member
    2,779
    1,501
    I'm not sure what field weekening is, but Tesla and Toyota both use a type of motor that changes from PM (low end torque) to reluctance (high end power) by changing the phase angle in relation to the rotor.
  8. Gokhan
    Gokhan Senior Member
    6,710
    2,660
    Paramount CA
    So, then, it will require replacement every three years/30,000 miles like alternators. It sounds like typical Nissan reliability. LOL
  9. bwilson4web
    16,520
    As long as they easily replaced, like tires and wipers, a nit.
  10. bisco
    52,807
    and not like the cabin filter on an id buzz
  11. Isaac Zachary
    2,779
    1,501
    Or like a timing belt on a Chevy Trax.
  12. bwilson4web
    16,520
    Curious, I've only had one alternator failure due to a bad bearing from a poorly adjusted belt. All the other worked much longer than the old style, brushed, generators. One of those failed in my Cherokee 140 about 4-5 hours from home ... got to do a lot of dead reckoning that night.
    Gokhan likes this.
  13. T1 Terry
    966
    546
    The dual brushes are carrying very little current so the should last a reasonable time, and the cover comes off easy enough to replace the whole assembly ..... I can't see that being serious issue.
    I think it will a few yrs before we see very many of these turning up at salvage auctions, so I won't hold out waiting to get one to put in my VW Kombi.
    T1 Terry
  14. Gokhan
    6,710
    2,660
    Paramount CA
    A neighbor had a Nissan Maxima. The alternator and starter would fail every other year (like everything else in the car such as the transmission, electrical systems, etc.). He never paid for them because the auto parts stores had warranties for alternators and starters; so, he would just return the old one and get a new one. Eventually, the car became undrivable due to transmission issues, and he got rid of it.
    That's why we buy Toyotas here. LOL
    bwilson4web and T1 Terry like this.
  15. austingreen
    austingreen Senior Member
    13,713
    4,231
    Austin, TX, USA
    induction motors are very old. the trade off is a slight loss of efficiency and added weight versus the ability to have higher less efficient power. If rare earth magnets get whacked by the trade war again then these induction motors should be relatively less expensive.
    Dual motor tesla's use one of each a permanant magnet motor in back and an induction motor up front.
    T1 Terry and bisco like this.
  16. T1 Terry
    966
    546
    Do you understand why they do that?
    I know that the aim is to length the max torque at a given speed. Field weakening in a permanent magnet motor reduces torque and at the same time, an induction motor has less torque at low speed so requires more energy input compared to the performance output. There is a point where this swaps over between the two types of motor design.
    By using the rear permanent magnet motor to provide peak torque up to the point the back EMF would limit any further rpm increase without field weakening .... at the same point, the front induction motor comes into its own and can have the magnetic field weakened by simply reducing the voltage in the stator .....
    I watched a few You Tube videos that explained field weakening to make it easier to explain .... and ...... yeah, it didn't refresh the memory or make any lights turn on .... it just gave me a headache as my eyes rolled back .... can't believe I once understood all this stuff :eek:
    T1 Terry
  17. Trollbait
    12,817
    There is also the lack of drag from permanent magnets when the induction motor isn't being used.
    Isaac Zachary likes this.
  18. Isaac Zachary
    2,779
    1,501
    Personally I don't see the huge advantage of having a slightly more efficient motor when there are bigger fish to fry.
    A 99% efficient motor will give around 10% range than an 89% efficient motor, so a 300 mile car gets to go another 30 miles. And after that there really isn't any more to squeeze out, that's it.
    But we have a bunch of energy going to rolling resistance and likely even more going to air drag, yet everything has to look like an SUV instead of being aerodynamic.
    I sure hope Aptera succeeds.
  19. bwilson4web
    16,520
    The strongest reason is reducing the supply chain risk. However, there are manufacturing advantages too. Everything has to work.
    T1 Terry and Isaac Zachary like this.
  20. austingreen
    13,713
    4,231
    Austin, TX, USA
    The benefit of the PM motor is higher efficiency and lower weight. The weight of the motor doesn't really matter though but the system weight is lower for similar range and acceleration because it can use a smaller battery. When it comes to adding a second motor, the ability to turn it off and lower costs are key for the use case of an induction motor up front as the rear motor will mainly power the vehicle so it mainly has the efficiency of the PM motor. I believe on the model 3 the difference is about 6% less efficient on dual vs rwd, but some of this is the added weight. Yes absolutely it is advantageous to have different torque and hp peaks, but this can be taken care of by different gearing as it was in the model S when both were induction motors.
    I don't think we have to worry that much about Neodymium availability in the supply chain. Companies can buy ahead, but with tarrifs who knows the price. I doubt given experience that tesla, toyota, and others have with these motors that manufacturing is a problem.
