ABS lights, Brake Power low, ICS sytem
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Warren Gerhardt, Aug 3, 2025 at 9:43 AM.
  1. Warren Gerhardt
    Warren Gerhardt New Member
    Today
    2018 Prius Prime
    I have a 2018 prius prime advanced (120K) and my teen daughter has the 2018 prius prime plus (132K).
    I changed her brakes (pads and rotors) after getting the car in October, 2024. I finally got around to changing mine yesterday, August 2nd 2025. I am quite confident I repeated the process step for step but my prius is flashing a plethora of warnings, making a constant alert noise, and telling me to stop driving b/c of low brake power.
    I tried the 4,13 pin reset to no avail. I welcome any advice from this wise crowd. I am no expert but interested in learning.
    There are additional sensors on my Advanced. Do these differences required different behavior on my part or did I incidentally disturb a sensor, or something else?...Thank you
    51,266
    do the wheels spin freely when you jack it up? if so, i would go through your installation carefully, check the speed sensor wiring and harnesses, and if necessary, scan the trouble codes with tech stream or autel
  3. Brian1954
    Brian1954 Senior Member
    1,870
    736
    South Central PA, USA
    Start by connecting a scanner to the OBD2 port and read the trouble codes that the car is trying to tell you about.
