Featured Nissan motor analysis Munro
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Aug 1, 2025 at 9:32 PM.
  1. bwilson4web
    16,049
    Nissan is producing a motor using an electro-magnet rotor which eliminates the need for permanent magnets:
    The same as running an alternator as a motor, this is a brilliant solution as it also solves the problem of back-EMF that requires 'field weakening' in traditional motors. There is no free lunch as the rotor coils require power but the dynamic range of efficient power production is well worth it.
    Gokhan likes this.
    51,277
    does it reduce rare element usage?
    bwilson4web likes this.
  3. bwilson4web
    16,049
    Yes. By orders of magnitude.
    PrimeDan, Isaac Zachary and bisco like this.
  4. bisco
    51,277
    i wonder if they are expensive motors to build. ariya is not an inexpensive car, for what you get
  5. T1 Terry
    T1 Terry Active Member
    783
    416
    I like the rational they used, reduce the supply chain issues and make highway driving energy efficient by not needing to waste battery capacity using field weakening. As said in the video, no one really cares about town energy consumption, plenty of recharge facilities in the city, not so much out on the freeways.
    T1 Terry
    bwilson4web and PrimeDan like this.
  6. bwilson4web
    16,049
    It should be slightly more than an induction but significantly less expensive than a PM.
    The carbon slip rings are a wear item but having a pair of brushes for each should help. Efficiency TBD but should be on par with a quality induction motor.
    Munro makes money selling their tear-down reports. Perhaps call them Monday?
  7. Isaac Zachary
    Isaac Zachary Senior Member
    2,368
    1,171
    I'm not sure what field weekening is, but Tesla and Toyota both use a type of motor that changes from PM (low end torque) to reluctance (high end power) by changing the phase angle in relation to the rotor.
  8. Gokhan
    Gokhan Senior Member
    5,804
    2,291
    Paramount CA
    So, then, it will require replacement every three years/30,000 miles like alternators. It sounds like typical Nissan reliability. LOL
  9. bwilson4web
    16,049
    As long as they easily replaced, like tires and wipers, a nit.
  10. bisco
    51,277
    and not like the cabin filter on an id buzz
  11. Isaac Zachary
    2,368
    1,171
    Or like a timing belt on a Chevy Trax.
