Wheel-bearing question; can you switch out entire hub-assembly?
Discussion in 'Gen 2 Prius Main Forum' started by priuslyfe, Aug 1, 2025 at 9:50 AM.
  1. priuslyfe
    priuslyfe Member
    215
    53
    I'll buy some and hopefully when the Amazon 19mm extractor gets here...it'll work. These kinds of problems are why car-repair is not practical or enjoyable, I don't understand why manufacturers don't apply anti-seize to any prone to fuse-together nut/bolt tbh.
  2. xw20_driver
    xw20_driver Junior Member
    53
    PNW
    PB Blaster and air impact wrench would be my go-to if I couldn't get the breaker bar to take that off. I haven't bought WD40 in years it is not a good lubricant nor penetrant product IMO.
    When I did the struts on an older Corolla that had lived 12 years on the east coast through salty roads, having the impact with a strong 19mm deep impact socket saved me. Use the correct tool for the job from the get go. But at this point if the nut is mangled and rounded off you might have to take a cutter to it and grind it off.
    priuslyfe likes this.
  3. priuslyfe
    priuslyfe Member
    215
    53
    I was just about to go spray the nut again with PBblaster. I think the extractor arrives on Thursday. I need to buy an impact wrench so I should look into that. I checked for new wheel-bearings today and as I suspected they cost around $180 (there are lower-tier bearings available but I figure with bearings probably not a good idea to buy the less-expensive).
    What BRAND of lubricant is better than WD40, that's the only kind I'm familiar with? Moreover, is there a one-fits-all for both lubricant and penetration (well other than KY)?
    thanks.
  4. Tombukt2
    12,362
    2,187
    I'm using the junk bearing supposedly I got 70,000 on them I changed them at 300K on three. The other has 535K on originals as far as I can tell .
  5. dolj
    dolj Senior Member
    8,256
    4,207
    Wellington, New Zealand
    CRC 5-56
  6. Tombukt2
    12,362
    2,187
    Kroil is to separate .WD is cleaner they're are many alum to steel is tricky .
  7. Mendel Leisk
    40,719
    That’s a good step. Also use impact-rated sockets, thicker walled. Besides being sturdier, I’ve just been reading, that they have more mass, which helps. A deep socket even more so.
    An impact with good torque, more mass, hammering the nut with rapid jolts, will hopefully do the trick.
    playing a torch on the nut may help some too, expanding it slightly.
  8. ChapmanF
    17,517
    I'm not sure what good a more-massive socket does you (besides being less likely to shatter on you). The socket's inertia will act against the impulses from the impact driver.
    Now, having the impact driver itself, and its internal rotating parts, be extra massive does help.
