Front Wheel Bearing - Directional?
Discussion in 'Prius c Technical Discussion' started by CMJAnew, Aug 6, 2025 at 6:14 AM.
  1. CMJAnew
    CMJAnew Junior Member
    88
    17
    Just had the driver front wheel bearing (just the bearing) replaced. It required HEAT and HAMMER and PRESS.
    My question…..is the bearing directional? That is, is it required to go in with an inside vs outside, one way only. The reason I ask is…the wheel speed sensor on the driver front is throwing a code, and I’ve lost cruise, traction, and stability control functions.
    Thanks for the help.
