Hybrid battery refresh gone wrong, jumping SOC, codes,12v=0v
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by EricGroce, Aug 6, 2025.
  1. EricGroce
    EricGroce Junior Member
    Independence, MO
    So I'm very familiar with batteries I rebuilt three Gen 2 Prius batteries over the years and always had wonderful results.. most recent one lasted a solid 90,000 miles on its refresh with used cells
    Anyway I'm running into a problem where I'm getting p3000 and p0a80
    Now I can reset the codes and they're fine as long as I don't run the battery down to a really low state of charge and then demand a lot from it
    Additionally I'm noticing that if I decelerate off the highway I will see as much as 94% state of charge on Dr Prius... And it will jump down to the lower 30s as well
    Then I may see it report between 30 and 40% state of charge but it's packed voltage be up in the 250s... This makes no sense
    Additionally after the swap I'm now getting a report of zero volts on the 12 volt battery.. of course my multimeter tells me that is completely inaccurate, at rest with the vehicle off I see about 12.5 volts, and with the car running somewhere between 14 and 14.2
    I suspect that there is an issue with one of the connections on one of the cells or possibly even a bad cell
    This also doesn't make a whole lot of sense because I did this the exact same way I've done them before, I rack all the cells into a pack and apply normal compression.. then I use an RC car charger to discharge and charge several times, this unit keeps track of how much capacity is going in and then how much is going out and gives you a report...
    All of these cells were at minimum 5000 mAh, additionally these cells came out of a gen 3 and have been transplanted into a Gen 2 battery shell
    I cleaned all the connections
    The only thing that I did different this time, normally the sensor wires will be connected directly to the battery terminal and then the bus bars go over the terminal
    But to me that doesn't make sense for current flow, so instead I changed this and it's now attached terminal to busbar, sensor wire on top of the bus bar
    Could this be potentially my problem?
    Additionally I am noticing that block number 11 shows particularly low, a few tenths of a volt lower than the rest of the blocks
    Oddly, yesterday when I first drove it about 20 miles, the codes would show up whenever I would get down to one bar, such as idling with the air conditioner on... The codes of course would clear and everything would be fine
    Also, yesterday Dr Prius was reporting between 14 and 14.2 volts on the 12 volt battery, but today it's zero, how does it even start if it's zero?
  2. EricGroce
    Independence, MO
    Well to make things more confusing now the 12 volt battery is recording somewhere between 13.8 and 14.2 volts in Dr Prius
  3. bisco
    52,393
    the charging voltage of the 12v fluctuates based on its current charge level
  4. Hayslayer
    Hayslayer Active Member
    465
    265
    The only thing that I did different this time, normally the sensor wires will be connected directly to the battery terminal and then the bus bars go over the terminal But to me that doesn't make sense for current flow, so instead I changed this and it's now attached terminal to busbar, sensor wire on top of the bus bar
    You've got this backwards. In stock form, the order is module terminal, busbar, sensor tab, nut. The sensor tabs are ALWAYS directly under the nut. You want the busbar to be in contact with the full surface of the module terminal. Although the actual current flow is more complicated, you can think of it as this way there is only one 'joint' the current must pass through. In reality, the majority will pass through this joint, plus some will pass through a parallel path of the threaded stud, to the nut, through the sensor tab, into the busbar.
  5. gdanner
    gdanner Member
    134
    51
    Central Illinois
    Have you looked at the orange plug and socket where the HV battery sensing wires go into the hybrid battery ECU module?
    Also take a look inside the battery ECU.
    Are there any signs of corrosion, overheating, or burning?
    Check out this thread for more info:
    (Although the following thread is in the Gen 1 sub-forum, the exact same issue exists in Gen 2)
    The battery fires at ECU sense connector thread | PriusChat
  6. PriusTech
    PriusTech Active Member
    259
    119
    Reno
    When you say cell you mean module.
    14 blocks, 28 modules, 168 cells. A module has 6 cells with a terminal on either end.
    Test the modules in block 11 separately, volts, CCA. and internal resistance. sounds like a bad module
    Confirm other answers, it's buss bar, sensor wire, nut
