DIY Grid Reconditioning Charger
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Abarnabe, Sep 13, 2020.
  1. Abarnabe
    Abarnabe Member
    165
    97
    Netherlands
    I can confirm that this is not what prolong instructions says and can potentially damage the battery.
    Brian1954 and johnHRP like this.
  2. johnHRP
    johnHRP Active Member
    628
    179
    KA, DE
    Excel
    Yeah..., just sell the prolong and cash it to add funds for new battery
  3. A.J
    A.J Junior Member
    36
    Worldwide
    You mean the bulb discharge wattage or which?
    Saw this video of a guy who used the Automated Prolong Charger and Discharger
    1st: Charge-Discharge 240+-~ to 134vdc.
    2nd: Charge-Discharge 240+~ to 101vdc
    3rd: Charge-Discharge 240+~ to 84vdc
    Then Charge
    UPDATE:
    My latest bulb arrangement for 220v bulbs:
    First Discharge:
    240+-~ to 196v: 400w or less bulb
    196v to 134v: 150w or less bulb
    Second Discharge:
    134v to 101v: 50w or less bulb
    Third Discharge:
    134v to 84v: 50w or less bulb
    But i use 60w in replacement for the 50w because i can't get a 50w bulb around.
    I have now attached the Prolong bulb charge voltage and wattage guide too.
    #83 A.J, Jul 24, 2025
  4. PriusII&C
    PriusII&C Active Member
    416
    136
    San Jose, California
    @Abarnabe Care to elaborate what's not right in @A.J's statement?
  5. PriusII&C
    416
    136
    Another question: do you need to turn on the traction battery fan during discharge, assume the light bulbs are located away from the battery and the surrounding is not extremely hot? I know you need the fan during charging to keep the battery from overheating.
  6. A.J
    A.J Junior Member
    36
    Worldwide
    I have updated my post above with an updated wattage arrangement, it seem to revolve around the bulb wattage change arrangement.
  7. Abarnabe
    Abarnabe Member
    165
    97
    Netherlands
    thiz is correct
    You don' t need the fan while discharging, in my experience
  8. Abarnabe
    Abarnabe Member
    165
    97
    Netherlands
    Prolong has all the instructions on their website. Just follow the instructions as Brian said, what is worng in your first and second statements are wattage and voltages, below certain voltages you should lower the bulb wattages to reduce the risk of cell damage and pole inversion
