2011 engine rattles HARD on startup after sitting a couple of days
Discussion in 'Gen 3 Prius Main Forum' started by BlackPrius001, Aug 8, 2025.
  1. BlackPrius001
    BlackPrius001 Junior Member
    Austin, TX
    My 2011 Prius has a very hard engine shake / rattle for seconds upon startup after it has sat unused for just a couple of days. When driven daily it starts smoothly and normally. It does seem to "chunk" harder than it used to when going from battery power to starting the engine to recharge (when sitting in Park). The car has about 140K miles. I did the EGR service several years ago, and I also recently did the brake booster / accumulator replacement very recently after that problem popped up. The car does burn some oil, but outside of that and this really aggressive shake / rattle on startup it is running great. Just worried that this is indicative of the next significant problem. Anyone have any idea what might be causing this or whether it is a concern? Alternatively, anyone have any soothing words of solace suggesting it's not a problem at all? Appreciate any insight.
  2. bettergolf
    bettergolf Active Member
    487
    366
    Sanford NC
    Likely it is a problem. This is the major symptom of your head gasket leaking coolant into the cylinder ...a known problem on the 2010 through at least the 2014 Prius. it causes this rattle until the coolant is expelled from the cylinder a few moments later. It will likely get worse over time until you must replace the head gasket.
  3. Mendel Leisk
    41,001
    Probably the head gasket.
    You did "EGR service several years ago": this was DIY? Did the intake manifold with it's EGR passages get cleaned as well? Can you recall the miles on the odometer?
    To check head gasket, on the day after car's been driven, pressurize the engine coolant system (remove reservoir cap and install stopper of some sort and apply sustained air pressure), remove wipers/cowl and spark plugs*, and run borescope into combustion chambers, looking for exceptionally clean piston top(s), coolant weeping from head gasket seam.
    diy coolant pressurizing gizmo:
    * See video #13 here: Nutz About Bolts Prius Maintenance Videos | PriusChat
    #3 Mendel Leisk, Aug 8, 2025
  4. Leadfoot J. McCoalroller
    8,013
    7,492
    Pennsylvania
    2018 Prius c
    Sorry for the bad news but yeah, that's a primary symptom of head gasket failure.
    The best test to confirm this is to remove the sparkplugs and use a video borescope to inspect the inside of the cylinders while the cooling system is pressurized with a test pump.
    Good luck!
  5. BlackPrius001
    Austin, TX
    This is suuuuuper bad news. Thanks to all for pointing this out, but man, what a bummer. I did the EGR cleanout myself at 117K and did the manifold as well, but didn't put in an oil catch can. I did the brake booster / actuator (DIY) about 1 month / 2000 miles ago (just did a road trip) at 146K, and the car has ~148.5K miles right now.
    I just watched the first video on the head gasket and that job appears to be at a completely different level from the other two. Not sure I have the skills to pull that one off.
    So if I do a head gasket, does the car last me another 100K problem free miles or what's the next big problem awaiting me? I feel like I've put quite a bit of time and money into this thing already as parts on that brake job were not cheap.
    Thanks again to all for the quick diagnosis of the most likely scenario.
  6. BlackPrius001
    Austin, TX
    Just got through reading this thread:
    Seems like the head gasket replacement is really expensive. Engine replacement w/ used Gen IV is a legitimate option (still very expensive), and my next major problem is probably the battery going out. Seems like it's going to cost a lot to keep this one running.
  7. Grit
    Grit Senior Member
    6,571
    4,223
    Wilkes Land
    The next big problem will be replacing th hv battery. Nimh battery typically good for 10 years so I’ll
    Let you do the math for 2011. And then brake booster replacemen if the brake fluid had never been changed.
    Because saving gas cost a lot of money.
  8. Leadfoot J. McCoalroller
    8,013
    7,492
    Pennsylvania
    2018 Prius c
    The real economic benefits of hybrid ownership go to those who buy new and unload it before its 15th birthday.
    If the car is already burning oil, I'd go for the engine replacement... but honestly I think replacing the whole car is an even better move.
    Sorry & good luck!
    Brian1954 likes this.
  9. Mendel Leisk
    41,001
    Just curious, which video?
  10. BlackPrius001
    Austin, TX
    This is the first of three videos by Nutz about Bolts detailing a head gasket replacement:
  11. BlackPrius001
    Austin, TX
    So does anyone have an idea on what the deterioration time frame is on that head gasket? Like I said, it's only happening occasionally when I let it sit for a few days (assuming that's how long it takes for significant coolant to build up in the cylinders). Do I have a month? A year? Is there a way to slow down the process by avoiding some specific behavior (like letting the car sit)? And then is there a market for a Prius with a bad head gasket?
    If I replace the engine does that resolve the EGR cooler issue as well?
  12. Mendel Leisk
    41,001
    Do you mean will a head gasket replacement prevent the EGR cooler from clogging up with carbon? ;)
    My hunch: it’s the carbon-clogged EGR system that’s causing the head gasket failures.
    your head gasket has developed a path, or paths, allowing coolant to make it into the combustion chambers. Likely started at the wall between cylinders one and two, on the exhaust side. Leaving it thus is starting the cascade of subsequent failures.
  13. BlackPrius001
    Austin, TX
    Sorry - wasn't clear enough. I meant "Will a replacement gen 4 engine quit blowing so much oil into the EGR cooler that it ceases to become clogged and need to be removed and cleaned every 50K miles, thus eliminating many problems of the gen 3 car?"
    After looking at the prices of newer priuses on Craigslist a gen 4 motor replacement is looking more appealing.
  14. Leadfoot J. McCoalroller
    8,013
    7,492
    Pennsylvania
    2018 Prius c
    A post-2014 engine should do better with all oil-control issues- they changed the rings. That's all 4th generation engines and the last of the 3rd.
    There's no precise timeline for how long an engine with a leaky gasket lasts. Most of it comes down to how well you keep up with the coolant loss, which itself is variable. If you are very diligent about it, you can probably stretch it out quite a ways. Generally speaking, the coolant gets too low, engine overheats, burns a rod bearing and blows a hole through the block.
    Some drivers have stayed ahead of it for many months.
    Personally I'm not convinced that EGR clogging is doing that much to cause gasket failure. It's an interesting theory, but there's just no data.
    Uneven heat distribution and thermal cycling has been popping head gaskets for 100+ years, so that's my own bet.
  15. Mendel Leisk
    41,001
    Neither gen “blows oil into the EGR cooler”. The cylinders are called combustion chambers for a reason: they incinerate anything combustible, hydrocarbons, oxygen.
    the EGR system will clog with dry, powdery carbon, because that’s the nature of pre-catalytic exhaust, regardless of engine burning oil or not. Because Toyota (obviously in hindsight) designed a flawed system and compounded the error by neglecting to test it sufficiently.
    Putting in a fourth gen salvage engine will not resolve the EGR system shortcomings, and will add compatibility issues. A common issue post-transplant is overheating.
    where you’re at I would just replace the head gasket, using the Toyota gasket kit (includes head gasket and everything else pliable that you’ll encounter in the process. And use new head bolts. Those two parts are about $300~400 USD.
    I can’t recall, did you mention moderate oil consumption as well? If it’s getting out of hand, replacement pistons/rings, the revised ones, is another $200~300 USD for the parts. If the cylinder walls are scored/scuffed, a new short block is around $2k USD.
    Machine shop “may” be worthwhile, if any of the machined mating surfaces are distorted enough to be out of spec, specifically at head-to-block and head-to-exhaust. You need a machinist’s straight edge and feeler gauges for that. It’s also good to spray some sort of solvent on the underside of upside down head, see if it leaks through. Last link in my signature has all the specs for mating surfaces. (On a phone turn it landscape to see signatures)
  16. BlackPrius001
    Austin, TX
    Thanks super-much Mendel. And thanks a ton to you too, Leadfoot. All of this feedback is super helpful.
    So, if I hire someone to do a new headgasket, new rings, new head bolts, go ahead and clean the EGR cooler again while it's being worked on, replace sway bar links (I've heard that's a good maint item to do), do I have car that runs well for another 100K miles? Obv there are no guarantees, but with what I've done so far and with the "reliability" that everyone reports w/ their priuses, would that be a reasonable expectation? Are there other big shortcomings I'm overlooking? I'll have to clean EGR every 50K, probably need some new suspension stuff likes shocks / struts, but other than that? Spending a few $K for 100K miles seems like a good trade-off, but I said that 2K miles ago when I spent $1500 on brake booster & actuator parts.
    Thanks again for all of the feedback.
    *EDIT: Oh, and of course I will still need a battery someday. I need to go check it's health today when I get a few minutes.
    #16 BlackPrius001, Aug 9, 2025
  17. Mendel Leisk
    41,001
    What’s the oil consumption? I recall someone mentioning 2 quarts every 5k miles, but not sure if it was you. 2011 for sure will have the low-friction piston rings, prone to developing oil consumption issues. 10k oil changes don’t help either.
    elephant in the room with a lot of this, the deadbeat company that built these cars, leaving owners to pick up the pieces when their mpg experiments implode.
    you have to weigh and decide the viability of repairs. It’s especially tough if you’re paying someone market labour. Consider DIY’ing at least part will help.
    #17 Mendel Leisk, Aug 9, 2025
  18. Leadfoot J. McCoalroller
    8,013
    7,492
    Pennsylvania
    2018 Prius c
    Really I hate to be the rain on your parade, but I say no. Personally, I think a Prius is a phenomenally reliable vehicle for roughly the first 15 years of its life, and sometimes you can carry them out to year 20- your chances are best when you started from new and aged it yourself.
    But I think yours has passed through that golden window and is now nosing down into money-pit mode.
    I would not sink more money into that car. Top up the coolant and stretch it for a while, but put the money towards the replacement car.
  19. BlackPrius001
    Austin, TX
    Unfortunately I haven't been monitoring it that closely. I just buy a five quart bottle and top it (and my 2013 Prius V) off every now and then. But it's not a trivial amount.
    Unfortunately after watching the head gasket video it appears like this one might be out of my league, or at least well out of my comfort zone and probably will require some additional tools that I don't realize I need until the last minute. Don't know that I've got the right combo of confidence and motivation.
    Appreciate the frank opinion. It's a bummer to be hitting that at 150K. And it would've been nice if the head gasket started presenting itself before the brake booster / accumulator problems.
    Again, thanks to both of your for the ongoing feedback. I'm going to just drive it for now as I consider my options until the head gasket is something I can't ignore.
  20. Mendel Leisk
    41,001
    It is daunting, for sure. I've never taken it on, and hoping I never have to. The main tools you might not have:
    Torx socket set
    Torque wrench(es)
    10 mm double hex driver (for the head bolts)
    Suitable form-in-place gasket (Gasket Masters recommend Permatex Ultra-Black, it's slow curing, allows much more leisurely assembly)
    I'd assume you've got floor jack, safety stands, the normal oil-change stuff?
    Again, last link in my signature is the full engine section from repair manual.
    I wasn't sure I could something, maybe the EGR cleaning. Anyway, @NutzAboutBolts told me something like "you can do it", and what do you know, I could. :)
    #20 Mendel Leisk, Aug 9, 2025
