Front suspension clunk is driving me nuts!
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Aug 7, 2025.
  1. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    Most of these items were replaced due to wear, a few to try and "fix the noise".
    The clunk can be heard from the front end over the smallest of bumps.
    It's heard more than felt, if that makes sense. Don't really feel it in the steering wheel or brake pedal.
    -Complete left and right front strut assemblies with springs and mounts.
    -Left and right sway bar links.
    -Left and right sway bar bushings.
    -Left and right ball joints.
    -Left and right inner and outer tie rods.
    -Left and right control arms.
    - Left and right CV axles.
    Tomorrow I'm going to check for loose bolts at the k-frame and control arms.
  2. T1 Terry
    T1 Terry Active Member
    929
    491
    Can you feel it at all in the steering, rocked back and forth with someone feeling different areas on the front cross member and chassis and the steering rack itself?
    T1 Terry
  3. pasadena_commut
    pasadena_commut Senior Member
    2,765
    828
    Southern California
    Clunks can also be silly things like a chunk of loosely fastened plastic bouncing up and down. Check the license plate, bumper cover, the plastic shields underneath the engine compartment, the wheel well liners, and the fuse box lid. Check that all parts of the air intake are properly assembled.
    Check that the hood latches down tightly. Grab both sides of the front edge of the hood and see if it can be moved up and down on either side. (Rubber mount may have moved or fallen off one side.)
  4. qmanqman
    qmanqman Active Member
    438
    152
    CO
    If it were control arms you'd be having vibrating steering wheel when braking. Replaced the control arms in wife's 2011 ES350 to fix steering wheel vibration and didn't tighten down the rear mounting bolt on the control arm. Vibration came back soon and I found it by jacking up the front end and pry barring things til I heard the clunk.
    If your Prius is high mileage try swapping out front struts. Strut swap got rid of the clunks I was having on my Accord. Plus it makes the ride a little nicer. They're not crazy expensive and the job isn't all that tough.
  5. T1 Terry
    929
    491
    That's a thought, as a mechanic in my own workshop, loose cartridges in front struts occurred every so often, as well as loose valve bodies in OEM struts. Hard to diagnose when the spring is still loading the strut, but once it is compressed, the clunk can be felt when moving the strut cap up and down ....
    T1 Terry
  6. Prius92
    595
    122
    Iowa
    I found a few things that all could be causing it, as well as a bad wheel bearing.
    The brand name was "TRQ" and it has less than 500 freaking miles on it.
    Grease was slinging out of it.
    The whole knuckle has a lot of material loss. Personally I think aluminum is a terrible choice for a steering knuckle because it's softer than steel and thusly wears easier.
    The lower control, the nut would not fully tighten again once it was removed, there are some issues with the threads, caused either by the nut or some kind of factory defect.
    You can see where the nut sat, the threads are much shallower.
    The 2 bolt holes for the strut on the knuckle have started to lobe out, again aluminum is a poor choice for this. You'd think Toyota would of been smart enough to install steel sleeves for this area.
    Here's what a new one looks like.
  7. T1 Terry
    929
    491
    What is the rusted steel part in the 4th photo? That certainly shows signs of constant impact ....
    T1 Terry
  8. Prius92
    595
    122
    Iowa
    That's just the end of one of the bolts that holds the strut to the knuckle, looks like that because you have to sometimes tap them out with a hammer.
  9. qmanqman
    438
    152
    CO
    FYI the lower control arm nut doesn't tighten because the other end of it is a ball joint which spins endlessly. If you look at your picture you'll see right above the rubber boot the body of it is tapered. That tapered part fits into a tapered hole and if it doesn't "grab" or "bite" it will spin freely. You need an impact wrench to get it to tighten. Trying to get it to tighten with a socket or wrench is a waste of time. You need that quick "blam" with the impact to pull it up snug into the joint.
    #9 qmanqman, Aug 16, 2025
  10. Mr.Vanvandenburg
    1,357
    578
    2020 Prius Prime
    On a Volt I started having a clunk like you described. The solution was to retighten the front wheel bearing with a torque wrench. It sounds like you would already have done that, but on the Volt the torque is very high, and it wasn’t tightened nearly enough from the factory. The other side was torqued fine. No more clunks on every little bump.
  11. richard203
    richard203 Member
    276
    60
    SF
    i have this noise too. trying to find out where it coming from
  12. T1 Terry
    929
    491
    I'd think twice about tightening the ball joint with an impact gun, unless you have a torque bar in between like the good tyre places use to avoid over tightening the nut and spreading the taper in the new section you are fitting.
    Jack the car up enough to get a number of good size wood blocks under the tyre, then let the jack down until the ball joint is loaded, forcing the taper into a spot where it will grip, then the nut will tighten properly ....... don't forget to have a jack stand under the body each side to support it if the tyre decides to roll off the timber blocks
    T1 Terry
  13. Prius92
    595
    122
    Iowa
    The weather is finally cool today so I set out to install things.
    I like this design of the lower ball joint better. It uses two clips. The old one, the bottom of the knuckle would squish the boot.
    The new knuckle installed.
    I did notice the metal bushing on the lower control arm sticks out. I'm not sure if this is normal or not, but could explain what was clunking, I will test drive it later today.
    Some of the ones for sale online show that lip sticking out, so I'm not sure. It's not a OEM LCA.
  14. Prius92
    595
    122
    Iowa
    My new tie rod end came with this style of nut:
    Will this cause issues?
    The factory ones have more of a "flange", I think.
  15. richard203
    richard203 Member
    276
    60
    SF
    any more noise when over bump? after the new item install?
  16. Prius92
    595
    122
    Iowa
    No more clunking. After still clunking with new struts and sway bar links, I'm 99% sure it was the ball joint.
  17. richard203
    richard203 Member
    276
    60
    SF
  18. Prius92
    595
    122
    Iowa
