Update on my "head gasket" issue (=not a head gasket issue)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AJP, Aug 20, 2025.
  1. AJP
    AJP Member
    160
    Central Pennsylvania
    So first of all, I'd like to thank Iron Man Prius here because you literally saved me junking my car by recommending Butler County Hybrid near Pittsburgh. Tom knows his STUFF and was able to diagnose in 24 hours what TWO dealerships could not. Turns out I had a bad fuel injector, not a bad head gasket. This isn't a common issue with Gen 2 but I've been driving it around for a few days now and she's running smooth as can be.
    Old thread here for anyone following the story: Just need confirmation that junking the car is the best option... | PriusChat
    PriusCamper likes this.
  2. ChapmanF
    18,102
    This classic story deserves to get recirculated every now and then. It's about a Prius that a shop got hold of for cheap because the owner really had let it go for scrap price, and a careful diagnosis led to one spark plug that fixed it.
    The way a Prius engine and transmission are coupled, any cause of engine misfiring can lead to banging that sounds like the end of the world.
  3. PriusCamper
    PriusCamper Senior Member
    12,712
    5,137
    Pacific Northwest, USA
    Even a perfectly heathly near new Atkinson engine can lead to some pretty strange noises... I'm grateful for that because it's why I suspect someone sold my 07 at 100K and now I'm at 300K with still no issues any only basic maintenance.
  4. Carall
    Carall Active Member
    308
    104
    Harrisonburg, VA
    This is not a common issue for Gen 2 but it is not an exception either. I have seen 2 Priuses with a bad injector and one in the initial stage, shuddering for half a minute on cold start.
  5. pasadena_commut
    pasadena_commut Senior Member
    2,591
    768
    Southern California
    The injectors can get trashed by putting gas with insufficient detergent through them. That is, not "Top Tier" or an equivalent. It used to be a big problem. I think all the major gas brands are "Top Tier" now, so not very common anymore. But if you buy at Sam's Club or some little independent station heaven only knows what is in the tank. Most likely it is "Top Tier" too, but there's nothing to prevent the refinery from doing "Chevron's order is full, sell the rest of this batch to the secondary market, and hold the detergent package."
